1N4007G L
1N4007G L
    MDD(辰达半导体)
    DO-204AL
    GENERAL DIODE 1KV 1A DO-41
1N4007G L 数据手册
PART CODE: DO41N4007GA10A SPECIFICATION SHEET SPECIFICATION SHEET NO. N0729-DO41N4007GA10A DATE July 29, 2021 REVISION A0 DESCRIPITION Axial Lead General Purpose Silicon Rectifier, DO-41 series, 1N4007G L Type 2 Pins Reverse Voltage 1000V Max. Forward Current 1.0A Max. Operating Temp. Range -65°C ~+150°C Package in AMMO Pack, 5000pcs/Tape, Tape/Box RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER MDD 1N4007G L PART CODE DO41N4007GA10A VENDOR APPROVE Issued/Checked/Approved DATE: July 29, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41N4007GA10A GENERAL PURPOSE SILICON RECTIFIER DO-41 SERIES MAIN FEATURE • The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 • Fast switching for high efficiency • High forward surge current capability • High temperature soldering guaranteed, 250 °C/10 seconds at terminals • Low reverse leakage APPLICATION • For printed circuit board RFQ PART CODE GUIDE Request For Quotation DO41 N4007G A 10A 1 2 3 4 1) DO41: Axial Lead General Purpose Silicon Rectifier, 2 Pins, DO-41 series 2) N4007G: Type code for original part number 1N4007G L 3) A: Package code, Package in AMMO Pack, 5000pcs/Tape, Tape/Box 4) 10A: Specification code for Reverse Voltage 1000V Max. Forward Current 1.0A Max. MORE ITEMS AVAILABLE DO41N4001GA105 DO41N4002GA110 DO41IN4003A120 DO41N4004GA140 DO41N4005GA160 DO41N4007GA10A NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41N4007GA10A GENERAL PURPOSE SILICON RECTIFIER DO-41 SERIES DIMENSION (Unit: Inch/mm) Image for reference Marking: 1N4007G DO-41 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41N4007GA10A GENERAL PURPOSE SILICON RECTIFIER DO-41 SERIES MECHANICAL DATA Case Terminals Polarity Mounting Position Weight per piece JEDEC DO-41 molded plastic body Solder plated, Solderable per MIL-STD-750, Method 2026 Polarity symbol marking on case Any 0.012 Ounce, 0.373 grams VALUE UNITS MAX. RATING & CHARACTERISTICS Parameter SYMBOLS Min. Typical Max. Repetitive peak reverse voltage V RRM 1000 Volts RMS voltage V RMS 700 Volts DC blocking voltage V DC 1000 Volts Average forward output rectified current I AV 1.0 A at TL= 110°C I FSM Peak forward surge current 8.3ms single half 30 A sine-wave superimposed on rated load (JEDEC Method) Instantaneous forward voltage at 1.0A DC reverse current at rated DC blocking voltage TA=25℃ VF 1.10 Volts IR 5.0 µA 50.0 µA TA=100℃ Junction capacitance (Note 2) CJ 15 pF Thermal resistance (Note 3) R QJA 50 °C/W Operating junction temperature range Storage temperature range TJ -65 +150 °C T STG -65 +150 °C Note 1. Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. 2. Measured at 1.0MHz and applied reverse voltage of 4.0Voltage 3. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length, PCB. Mounted. NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41N4007GA10A GENERAL PURPOSE SILICON RECTIFIER DO-41 SERIES RELIABILITY Number Experiment Items Experiment Method And Conditions Reference Documents 1 Solder Resistance Test Test 260°C± 5°C for 10 ± 2 sec. Immerse body into solder 1/16” ± 1/32" MIL-STD-750D METHOD-2031.2 2 Solderability Test 230°C ±5°C for 5 sec. MIL-STD-750D METHOD-2026.1 0 3 Pull Test 1 kg in axial lead direction for 10 sec. MIL-STD-750D METHOD-2036.4 4 Bend Test 0.5Kg Weight Applied To Each Lead, Bending Arcs 90 °C ± 5 °C For 3 Times MIL-STD-750D METHOD-2036.4 5 High Temperature Reverse Bias Test TA=100°C for 1000 Hours at VR=80% Rated VR MIL-STD-750D METHOD-1038.4 6 Forward Operation Life Test TA=25°C Rated Average Rectified Current MIL-STD-750D METHOD-1027.3 7 Intermittent Operation Life Test On state: 5 min with rated IRMS Power Off state: 5 min with Cool Forced Air. On and off for 1000 cycles. MIL-STD-750D METHOD-1036.3 8 Pressure Cooker Test 15 PSIG, TA=121°C, 4 hours MIL-S-19500 APPENOIXC 9 Temperature Cycling Test -55°C~+125°C; 30 Minutes For Dwelled Time 5 minutes for transferred time. Total: 10 cycles. MIL-STD-750D METHOD-1051.7 10 Thermal Shock Test 0°C for 5 minutes., 100°C for 5minutes, Total: 10 cycles MIL-STD-750D METHOD-1056.7 11 Forward Surge Test 8.3ms Single Sale Sine-wave One Surge. MIL-STD-750D METHOD-4066.4 12 Humidity Test TA=65°C, RH=98% for 1000 hours. MIL-STD-750D METHOD-1021.3 13 High Temperature Storage life Test 150°C for 1000 Hours MIL-STD-750D METHOD-1031.5 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41N4007GA10A GENERAL PURPOSE SILICON RECTIFIER DO-41 SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41N4007GA10A GENERAL PURPOSE SILICON RECTIFIER DO-41 SERIES AMMO BOX (Unit: mm) • All Devices are packed in accordance with EIA standard RS-296-D and specifications. • Each component lead shall be sandwiched between taps for A minimum of 3.2 mm (-.126”) Item Symbol DO-41 Uni(mm) DO-41 Unit (Inch) Component Alignment Z 1.2 Max. 0.048 Max. Tape Width T 6.0 +/- 0.4 0.236 +/- 0.016 Exposed Adhesive E 0.8 Max. 0.032 Max. Body Eccentricity L1 – L2 1.0 Max. 0.040 Max. Component Pitch A (2.0mm/20 pitch) A 5.0 0.197 Component Pitch B (2.0mm/20 pitch) B 26.0 1.023 Component Pitch A (2.0mm/10 pitch) A 5.0 0.197 Component Pitch B (2.0mm/10 pitch) B 52.4 2.063 Box Length L 255.0 +/- 5.0 10.04 +/- 0.197 Box Width W 78.0 +/- 5.0 3.07 +/- 0.197 Box Height H 150.0 +/- 5.0 5.91 +/- 0.197 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: DO41N4007GA10A GENERAL PURPOSE SILICON RECTIFIER DO-41 SERIES AMMO PACK IN TAPE/BOX (Unit: mm) Case Code DO-41 Qty. Per Reel (pcs) Component Space (mm) Tape Space (mm) Inner Box L*W*H (mm) Carton size L*W*H (mm) Qty. Per Carton (pcs) G. W 5000 5.0 52.4 260*150*80 420*280*300 50,000 12.45 (kg) DISCLAIMER NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
1N4007G L 价格&库存
很抱歉,暂时无法提供与“1N4007G L”相匹配的价格&库存,您可以联系我们找货
