FL450K0000S105
FL450K0000S105
    NEXTGEN
    SMD3
    450KHZ SMD FILTER 3 PADS
FL450K0000S105 数据手册
PART CODE: FL450K0000S105 SPECIFICATION SHEET SPECIFICATION SHEET NO. N00504-FL450K0000S105 DATE May 04, 2021 REVISION A0 DESCRIPITION KHz SMD Ceramic Filter 6560 Type L6.5*W6.0*H4.2mm 3 Pads CFTC U Series 450.0KHz, Impedance, 1.5KOhm, Insertion Loss. 2.0dB Max. Operating Temp. Range -20°C ~+80°C Reflow Profile Condition(260 °C Max. Tape/Reel, RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS CFTC 450EU TLF PART CODE FL450K0000S105 VENDOR APPROVE Issued/Checked/Approved DATE: May 04, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: FL450K0000S105 KHZ SMD CERAMIC SMD CRYSTAL FILTER 6560 2520 TYPE 34 PADS MAIN FEATURE • KHz SMD Ceramic Filter 6560 Type 3 pads • White case, L6.5*W6.0*H4.2mm • Low cost and short shipment • Reflow Profile Condition 260 °C Max. • Cross more competitors part CFUKG • RoHS/RoHS III compliant APPLICATION • Bluetooth, wireless communication set • Communication Electronics RFQ PART CODE GUIDE Request For Quotation FL 450K0000 S 105 1 2 3 4 1) FL: Part family Code for KHz SMD Ceramic Filter 6560 Type L6.5*W6.0*H4.2mm 3 Pads CFTC U Series 2) 450K0000: Frequency range code for 450.0000KHz 3) S: SMD type, Package Tape/Reel, 1000pcs/Reel 4) 105: Specification code for original part No.: TGS CFTC 450EU TLF MORE FREQUENCY RANGE AVAILABLE (KHz) 450.00 455.00 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: FL450K0000S105 KHZ SMD CERAMIC FILTER 6560 TYPE 3 PADS DIMENSION (Unit: mm, Tol. +/-0.15mm) Image for reference Marking Line 1: Series Code Line 2: Frequency Range +Internal Code CFTC U Connection Pin 1: Input Pin 2: Output Pin3: Ground Measuring Circuit Rg+R1=R2=Output/input Impedance NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com FL450K0000S105 PART CODE: KHZ SMD CERAMIC FILTER 6560 TYPE 3 PADS ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Typical Condition Max. Original Manufacturer TGS TGS Crystals Holder Type CFTC KHz SMD Ceramic Filter L6.5*W6.0*H4.2mm 3 Pads Frequency Range (f0) 450 KHz 450.000 Temperature Stability % Operation Temperance °C -20 +80 Storage Temperance °C -40 +85 Stop Band Attenuation dB 27 @fo±100KHz KHz ±5.0 @3 dB KHz ±7.5 @6 dB KHz ±15.0 @40 dB Bandwidth E ±0.5 Insertion Loss (At minimum loss point) dB 5.0 Ripple dB 2.0 Input/Output Impedance Ω Insulation Resistance Pads Code Other MΩ @-20℃~ +80℃ @f0±5.0khz 1500 100 @DC 25V 1 minute) U 3 pads Package T Tape/Reel, 1000pcs/Reel RoHS Status LF RoHS III compliant Add Value N/A Internal Control Code * N/A Note: Original Part Number: TGS CFTC 450EU TLFDC NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: FL450K0000S105 KHZ SMD CERAMIC FILTER 6560 TYPE 3 PADS RELIABILITY Test Items Humidity Test Method And Conditions Requirement After being placed in a chamber with 90-95% R.H. at 40±2℃ for 100 hours and then being placed in room temperature for 1 hour, filter shall be measured. It shall meet Table 1. High Temperature After being placed in a chamber with 80±2 ℃,for 100 hours and then being placed in room temperature for 1 hour, filter shall be measured. It shall meet Table 1. Low Temperature After being placed in a chamber with -20±2 ℃,for 100 hours and then being placed in room temperature for 1 hour, filter shall be measured. It shall meet Table 1. Heat Shock After being kept at room temperature, filter shall be placed at temperature of –55 ℃ , for 30 minutes, then be placed at temperature. 85 ℃, for 30 minutes. After that returned to –55 ℃ again. Repeated above cycle for 5 times. After being kept in room temp. for 1 hour, filter shall be measured It shall meet Table 1. Resistance to Solder Heat Lead terminals are immersed up to 1.5mm from filter’s body in soldering bath of 350± 10℃, for 3±0.5 sec. And then filter shall be measured after being placed in room temperature for 1 hour. It shall meet Table 1. Solderability Lead terminals are immersed in aide solder for 5 sec and then immersed in soldering bath of 230±5℃, for 3±0.5 sec. At least 95% lead terminals shall be covered with solder. Drop Test Filter shall be measured after 3 times random drops from the height of 30 cm on concrete floor No visible damage and it meet Table 1 Adhesion A static load of 20N to the direction of the arrow (see Fig. 4) shall be applied on the core of the Component and hold for 10 seconds. Filter shall be soldered correctly and tightly to PCB. It shall meet Table 1. Vibration Filter shall be measured after being applied vibration of amplitude of 1.5mm with 10-55Hz band of vibration frequency to each of 3 perpendicular directions for 2 hours No visible damage and it meet Table 1 Apply pressure in the direction of arrow (see Fig. 3) at a rate of about 0.5mm per second until it reaches a bend of 3mm and hold for 30 seconds. It shall meet Table 1. Substrate Bending Test Table1 Item Center Frequency Band width (6dB) Selectivity(50 dB) Stop Band Attenuation (fo±100KHz) Ripple Insertion Loss Specification 450±1.0K Hz Max. ±7.5KHz Min. ±15.0KHz Max. 27dB Min. 2.0dB Max 5.0dB Max NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: FL450K0000S105 KHZ SMD CERAMIC FILTER 6560 TYPE 3 PADS SUGGESTED REFLOW PROFILE (For Reference Only) Total time: 200 Sec. Max. Solder melting point: 220℃ Profile Feature Pb-Free Assembly Average Ramp-up Rate (Ts Max to Tp) 3℃/second Max Preheat Temperature Min (Ts Min.) 125℃ Temperature Max (Ts Max.) 200℃ Time (ts Min. to ts Max.) 60~180 seconds Temperature (TL) 217℃ Time (tL) 60~150 seconds Time maintained above Peak/Classification Temperature (Tp) 260 ℃ Time within 5℃ of actual Peak Temperature (tp) 20~40 seconds Ramp-down rate 6 ℃ /Second Max. Time 25 ℃ to Peak Temperature 8 minutes Max. Suggest reflow times 3 Times Max. NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: FL450K0000S105 KHZ SMD CERAMIC FILTER 6560 TYPE 3 PADS TAPE/REEL (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-2 and specifications, 1000pcs/Reel DISCLAIMER NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
FL450K0000S105 价格&库存
很抱歉,暂时无法提供与“FL450K0000S105”相匹配的价格&库存,您可以联系我们找货
