SDR868M350S014
SDR868M350S014
    NEXTGEN
    SMD6
    868.35 MHz SAW 谐振器 50 Ohms -40°C ~ 85°C 表面贴装型
SDR868M350S014 数据手册
PART CODE: SDR868M350S014 SPECIFICATION SHEET SPECIFICATION SHEET NO. Q0526-SDR868M350S014 DATE May 26, 2023 REVISION A0 DESCRIPITION SMD SAW Resonator L3.0*W3.0*H1.25mm 3030 Type 6 Pads SDR Series 868.350000MHz, 1-Port, Insertion Loss: 2.0 dB Max. Tolerance ±150KHz Operating Temp. Range -40°C ~+85°C, Reflow Profile Condition 260 °C Max. Tape/Reel, 3000pcs/Reel RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS SDR 868.35MC TLF PART CODE SDR868M350S014 VENDOR APPROVE Issued/Checked/Approved DATE: May 26, 2023 CUSTOMER APPROVE DATE: 5/26/2023 NextGen Components, Inc. 1 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SDR868M350S014 SMD SAW RESONATOR SMD CRYSTAL 30302520 TYPETYPE SDR 4SERIES PADS MAIN FEATURE • SMD SAW Resonator L3.0*W3.0*H1.25mm 3030 Type 6 Pads • One Port SAW Resonator • Electrostatic Sensitive Device(ESD) • Low-loss and Short Lead time • Cross more competitors part • RoHS/RoHS III compliant APPLICATION • Bluetooth, wireless communication set • Communication Electronics RFQ PART CODE GUIDE Request For Quotation SDR 868M350 S 014 1 2 3 4 1) SDR: Series Code: SMD SAW Resonator L3.0*W3.0*H1.25mm 3030 Type 6 Pads 2) 868M350: Frequency range code for 868.3500MHz 3) S: SMD type, Package Tape/Reel, 4) 014: Internal code (A~Z or 1~9 or Blank) 5/26/2023 NextGen Components, Inc. 2 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SDR868M350S014 SMD SAW RESONATOR 3030 TYPE SDR SERIES DIMENSION (Unit: mm, Tol.: +-0.15mm) Image for reference Marking Standard SDR series L3.0*W3.0*H1.25mm 3030 Type Pin Configuration 2 Input 5 Output 1,3,4,6 Ground Test Circuit 5/26/2023 NextGen Components, Inc. 3 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SDR868M350S014 SMD SAW RESONATOR 3030 TYPE SDR SERIES ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Typical Max. Original Manufacturer TGS TGS Crystals Holder Type SDR SMD SAW Resonator L3.0*W3.0*H1.25mm 3030 Type 6 Pads Frequency Range (f0) 868.35M MHz 868.35000 Frequency Tolerance C KHz ±150 Operation Temperance °C -40 +85 Storage Temperance °C -40 +85 DC Voltage V ±30 dBm 15 dB 1.0 RF Power Dissipation Insertion Loss Quality Factor (Q) @Unload 9400 Quality Factor (Q) @50 Ω Loaded 1500 ℃ - ppm/℃ - ppm/Year ≤±10 Turnover Temperature Frequency Temp. Coefficient Aging (Absolute Value during the First Year) DC Insulation Resistance MΩ 2.0 1.0 RF Equivalent RLC Model @Motional Resistance Ω 12.0 RF Equivalent RLC Model @Motional Inductance µH 32.6 RF Equivalent RLC Model @Motional Capacitance fF 1.05 Static Capacitance pF 2.1 2.4 Package T Tape/Reel RoHS Status LF RoHS III compliant Add Value Blank: N/A Internal Control Code Blank: N/A 22.0 2.7 Note: 1) Test Temperature: 25℃±2℃, Terminating source impedance: 50Ω Terminating load impedance: 50Ω 2) Original Part Number: TGS SDR 868.35MC TLF 5/26/2023 NextGen Components, Inc. 4 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SDR868M350S014 SMD SAW RESONATOR 3030 TYPE SDR SERIES FREQUENCY RESPONSE 5/26/2023 NextGen Components, Inc. 5 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SDR868M350S014 SMD SAW RESONATOR 3030 TYPE SDR SERIES EQUIVALENT LC MODEL TEMPERATURE CHARACTERISTICS Note: The curve shown above accounts for resonator contribution only and does not include LC component temperature contributions. PLICTYPCIAL APATION CIRCUITS Typical Low-power Transmitter Application Typical Local Oscillator Application 5/26/2023 NextGen Components, Inc. 6 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SDR868M350S014 SMD SAW RESONATOR 3030 TYPE SDR SERIES RELIABILITY Test Items Test Method And Conditions Requirement Temperature (1) Temperature: 85℃±2℃ , Duration: 250h , Recovery time: 2h±0.5h It shall remain Storage (2) Temperature: –40℃±3℃ , Duration: 250h ,Recovery time: 2h±0.5h electrical performance Humidity Test Conditions: 60℃±2℃ , 90~95% RH Thermal Shock Heat cycle conditions: TA=-40℃±3℃, TB=85℃±2℃, t1=t2=30min, after tests Duration: 250h Switch time: ≤3min, Cycle time: 100 times, Recovery time: 2h±0.5h. Vibration Fatigue Frequency of vibration: 10~55Hz Directions: X,Y and Z Drop Test Solderability Amplitude:1.5mm Duration: 2h Cycle time: 10 times Height: 1.0m Temperature: 245℃±5℃ Duration: 3.0s--5.0s Depth: DIP--2/3 , SMD--1/5 Resistance to Soldering Heat (1)Thickness of PCB:1mm , Solder condition: 260℃±5℃ , Duration: 10±1s (2)Temperature of Soldering Iron: 350℃±10℃ , Duration: 3~4s , Recovery time : 2 ± 0.5h 5/26/2023 NextGen Components, Inc. 7 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SDR868M350S014 SMD SAW RESONATOR 3030 TYPE SDR SERIES SUGGESTED REFLOW PROFILE (For Reference Only) 5/26/2023 NextGen Components, Inc. 8 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SDR868M350S014 SMD SAW RESONATOR 3030 TYPE SDR SERIES TAPE DIMENSION (Unit: mm, 3000pcs/Reel) Code Dimension W 12.0+/-0.30 F 5.50+/-0.10 E 1.75+/-0.10 P0 4.00+/-0.10 P1 8.00+/-0.10 P2 2.00+/-0.10 D0 Ø1.5+/-0.10 D1 Ø1.5+/-0.25 t1 0.30+/-0.01 t2 1.90+/-0.05 A 3.35+/-0.10 B 3.35+/-0.10 Code Dimension A Ø330+/-1.0 B Ø100+/-0.5 C Ø13.0+/-0.5 D Ø21+/-0.8 E 2.00+/-0.5 T 13.0+/-0.50 t 3.00 Max. r 1.00 Max. REEL DIMENSION (Unit: mm) 5/26/2023 NextGen Components, Inc. 9 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SDR868M350S014 SMD SAW RESONATOR 3030 TYPE SDR SERIES CAUTION 1. As a result of the particularity of inner structure of SAW products, it easy to be breakdown by electrostatic, so we should pay attention to ESD protect in the test. 2. Static voltage between signal load and ground may cause deterioration and destruction of the component. Please avoid static voltage. 3. Ultrasonic cleaning may cause deterioration and destruction of the component. Please avoid ultrasonic cleaning. 4. Only leads of component may be soldered. Please avoid soldering another part of component. 5. There is a close relationship between the device's performance and matching network. The specifications of this device are based on the test circuit shown above. L and C values may change depending on board layout. Values shown are intended as a guide only. 6. The temperature of manual welding should not exceed 300 ℃. 7. The specifications of this device are based on the test circuit shown above and subject to change or obsolescence without notice. 8. All equipment designs utilizing this product must be approved by the appropriate government agency prior to manufacture or sale. 9. Our liability is only assumed for the Surface Acoustic Wave (SAW) component(s) perse, not for applications, processes and circuits implemented within components or assemblies. 10. For questions on technology, prices and delivery, please contact our sales offices or e-mail: sales@NextGenComponent.com. DISCLAIMER NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information 5/26/2023 NextGen Components, Inc. 10 sales@NextGenComponent.com www.NextGenComponent.com
SDR868M350S014 价格&库存
很抱歉,暂时无法提供与“SDR868M350S014”相匹配的价格&库存,您可以联系我们找货
