SIR433M920S046
SIR433M920S046
    NEXTGEN
    SIP4
    433.92 MHz SAW 谐振器 50 Ohms -40°C ~ 85°C 表面贴装型
SIR433M920S046 数据手册
PART CODE: SIR433M920S046 SPECIFICATION SHEET SPECIFICATION SHEET NO. Q0528-SIR433M920S046 DATE May 28, 2023 REVISION A0 DESCRIPITION SMD SAW Resonator L5.0*W3.5*H1.5mm 5035 Type 4 Pads SIR Series 433.9200000MHz, 1-Port, Insertion Loss: 2.0 dB Max. Tolerance ±30KHz Operating Temp. Range -40°C ~+85°C, Reflow Profile Condition 260 °C Max. Tape/Reel, 1000pcs/Reel RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS SIR 433.92MF TLF PART CODE SIR433M920S046 VENDOR APPROVE Issued/Checked/Approved DATE: May 28, 2023 CUSTOMER APPROVE DATE: 5/28/2023 NextGen Components, Inc. 1 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR433M920S046 SMD SAW RESONATOR SMD CRYSTAL 5035 2520 TYPE TYPE SIR 4SERIES PADS MAIN FEATURE • SMD SAW Resonator L5.0*W3.5*H1.5mm 5035 Type 4 Pads • Package Code QCC4A • One Port SAW Resonator • Electrostatic Sensitive Device(ESD) • Low-loss and Short Lead time • Cross more competitors part • RoHS/RoHS III compliant APPLICATION • Bluetooth, wireless communication set • Communication Electronics RFQ PART CODE GUIDE Request For Quotation SIR 433M920 S 046 1 2 3 4 1) SIR: Series Code, SMD SAW Resonator L5.0*W3.5*H1.5mm 5035 Type 4 pads 2) 433M920: Frequency range code for 433.9200MHz 3) S: SMD type, Package Tape/Reel, 4) 046: Internal code (A~Z or 1~9 or Blank) 5/28/2023 NextGen Components, Inc. 2 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR433M920S046 SMD SAW RESONATOR 5035 TYPE SIR SERIES DIMENSION (Unit: mm, Tol.: +-0.15mm) Image for reference SIR series, Package Code QCC4A L5.0*W3.5*H1.5mm 5035 Type Pin Configuration 1 Input/Output 3 Output/Input 2,4 Ground Marking: Standard + ● : Pin 4 Test Circuit 5/28/2023 NextGen Components, Inc. 3 sales@NextGenComponent.com www.NextGenComponent.com SIR433M920S046 PART CODE: SMD SAW RESONATOR 5035 TYPE SIR SERIES ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Typical Max. Original Manufacturer TGS TGS Crystals Holder Type SIR SMD SAW Resonator L5.0*W3.5*H1.5mm 5035 Type 4 Pads Frequency Range (f0) 433.92M MHz 433.92 Frequency Tolerance F KHz ±30 Operation Temperance °C -40 +85 Storage Temperance °C -55 +125 DC Voltage V ±30 dBm 10 dB 1.7 RF Power Dissipation Insertion Loss Quality Factor (Q) @Unload 12366 Quality Factor (Q) @50 Ω Loaded 1642 ℃ Turnover Temperature Frequency Temp. Coefficient Aging (Absolute Value during the First Year) DC Insulation Resistance 25 40 ppm/℃ 0.032 ppm/Year ≤±10 MΩ 2.0 55 1.0 RF Equivalent RLC Model @Motional Resistance Ω 17.0 RF Equivalent RLC Model @Motional Inductance µH 69.5 RF Equivalent RLC Model @Motional Capacitance fF 1.94 Static Capacitance pF 2.0 2.3 Package T Tape/Reel RoHS Status LF RoHS III compliant Add Value Blank: N/A Internal Control Code Blank: N/A 25.0 2.6 Note: 1) Test Temperature: 25℃±2℃, Terminating source impedance: 50Ω Terminating load impedance: 50Ω 2) Original Part Number: TGS SIR 433.92MF TLF 5/28/2023 NextGen Components, Inc. 4 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR433M920S046 SMD SAW RESONATOR 5035 TYPE SIR SERIES FREQUENCY RESPONSE 5/28/2023 NextGen Components, Inc. 5 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR433M920S046 SMD SAW RESONATOR 5035 TYPE SIR SERIES EQUIVALENT LC MODEL TEMPERATURE CHARACTERISTICS Note: The curve shown above accounts for resonator contribution only and does not include LC component temperature contributions. PLICTYPCIAL APATION CIRCUITS Typical Low-power Transmitter Application Typical Local Oscillator Application 5/28/2023 NextGen Components, Inc. 6 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR433M920S046 SMD SAW RESONATOR 5035 TYPE SIR SERIES RELIABILITY Test Items Test Method And Conditions Requirement Temperature (1) Temperature: 85℃±2℃ , Duration: 250h , Recovery time: 2h±0.5h It shall remain Storage (2) Temperature: –40℃±3℃ , Duration: 250h ,Recovery time: 2h±0.5h electrical performance Humidity Test Conditions: 60℃±2℃ , 90~95% RH Thermal Shock Heat cycle conditions: TA=-40℃±3℃, TB=85℃±2℃, t1=t2=30min, after tests Duration: 250h Switch time: ≤3min, Cycle time: 100 times, Recovery time: 2h±0.5h. Vibration Fatigue Frequency of vibration: 10~55Hz Directions: X,Y and Z Drop Test Solderability Amplitude:1.5mm Duration: 2h Cycle time: 10 times Height: 1.0m Temperature: 245℃±5℃ Duration: 3.0s--5.0s Depth: DIP--2/3 , SMD--1/5 Resistance to Soldering Heat (1)Thickness of PCB:1mm , Solder condition: 260℃±5℃ , Duration: 10±1s (2)Temperature of Soldering Iron: 350℃±10℃ , Duration: 3~4s , Recovery time : 2 ± 0.5h 5/28/2023 NextGen Components, Inc. 7 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR433M920S046 SMD SAW RESONATOR 5035 TYPE SIR SERIES SUGGESTED REFLOW PROFILE (For Reference Only) 5/28/2023 NextGen Components, Inc. 8 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR433M920S046 SMD SAW RESONATOR 5035 TYPE SIR SERIES TAPE DIMENSION (Unit: mm, 1000pcs/Reel) Code Dimension W 12.0+/-0.30 F 5.50+/-0.10 E 1.75+/-0.10 P0 4.00+/-0.10 P1 8.00+/-0.10 P2 2.00+/-0.10 D0 Ø1.5+/-0.10 D1 Ø1.5+/-0.25 t1 0.30+/-0.01 t2 1.90+/-0.05 A 3.70+/-0.10 B 5.20+/-0.10 REEL DIMENSION (Unit: mm) Code 5/28/2023 NextGen Components, Inc. Dimension A Ø178.0+/-2.0 B Ø60.0+/-0.5 C Ø13.0+/-0.5 D Ø21+/-0.8 E 2.00+/-0.5 T 15.4+/-1.00 t 0.31 Max. 9 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR433M920S046 SMD SAW RESONATOR 5035 TYPE SIR SERIES CAUTION 1. As a result of the particularity of inner structure of SAW products, it easy to be breakdown by electrostatic, so we should pay attention to ESD protect in the test. 2. Static voltage between signal load and ground may cause deterioration and destruction of the component. Please avoid static voltage. 3. Ultrasonic cleaning may cause deterioration and destruction of the component. Please avoid ultrasonic cleaning. 4. Only leads of component may be soldered. Please avoid soldering another part of component. 5. There is a close relationship between the device's performance and matching network. The specifications of this device are based on the test circuit shown above. L and C values may change depending on board layout. Values shown are intended as a guide only. 6. The temperature of manual welding should not exceed 300 ℃. 7. The specifications of this device are based on the test circuit shown above and subject to change or obsolescence without notice. 8. All equipment designs utilizing this product must be approved by the appropriate government agency prior to manufacture or sale. 9. Our liability is only assumed for the Surface Acoustic Wave (SAW) component(s) perse, not for applications, processes and circuits implemented within components or assemblies. 10. For questions on technology, prices and delivery, please contact our sales offices or e-mail: sales@NextGenComponent.com. DISCLAIMER NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information 5/28/2023 NextGen Components, Inc. 10 sales@NextGenComponent.com www.NextGenComponent.com
SIR433M920S046
物料型号:SIR433M920S046
器件简介:SMD SAW Resonator,尺寸为5.0mm x 3.5mm x 1.5mm,属于5035 Type 4 Pads SIR系列,频率为433.92MHz,1端口,最大插入损耗为2.0dB,公差±30KHz,工作温度范围-40°C至+85°C,最大再流温度260°C,符合RoHS/RoHS III标准。
引脚分配:1号引脚为输入/输出,3号引脚为输出/输入,2号和4号引脚为接地。
参数特性:包括频率范围433.92MHz,频率公差±30KHz,操作温度-40°C至+85°C,存储温度-55°C至+125°C,直流电压+30V,射频功率耗散10dBm,品质因数(Q)在未加载时为12366,50欧姆加载时为1642,频率温度系数0.032,老化(第一年内绝对值)≤+10ppm,直流绝缘电阻≥1.0MΩ,射频等效RLC模型包括动态电阻17.0至25.0欧姆,动态电感69.5亨利,动态电容1.94皮法,静态电容2.0至2.6皮法。
功能详解:该器件为表面声波(SAW)谐振器,具有低损耗和短的交货时间,可交叉多个竞争对手的部件,适用于蓝牙、无线通信设备、通信电子等。
应用信息:适用于蓝牙、无线通信设备、通信电子。
封装信息:封装代码QCC4A,采用胶带/卷轴封装,每卷1000件。
SIR433M920S046 价格&库存
很抱歉,暂时无法提供与“SIR433M920S046”相匹配的价格&库存,您可以联系我们找货
