TCON-SL-8MM-60
TCON-SL-8MM-60
    LEDLIGHTING
    CBL ASSY SSL BLK/RED 60
TCON-SL-8MM-60 数据手册
LED LINEAR LIGHTING CONNECTORS Slide Connectors for LED linear lighting | not to be used in wet locations SIZE ACTUAL WIDTH 8MM 13.6mm / 0.53” 10MM 15.52mm / 0.61” 14MM 19.55mm / 0.77” PRODUCT COMPATIBILITY DRIVER COMPATIBILITY FLYING WIRE LEAD LENGTH T150, T300, THL480, TSHL5050 series, TSHL600, TSHL2835 series, TUB5630 series, TUHL1200, T150RGB, T300RGB only class 2 power unit 3”, 6”, 12”, 24”, 36”, 60” or specify custom length (not available for TSPLICE connector) TCON-SL TPWR-SL TPOWERCONNECT TCONNECT single slide linear lighting connector to flying wire lead linear lighting to power supply slide connector TYCON-SL TYPWR-SL TYPOWERCONNECT TYCONNECT single slide linear lighting connector to 2 additional linear lighting runs single power connector to 2-way split slide linear lighting connectors TCOR-SL TSPL-SL TCORNER ORDER single slide linear lighting connector to additional linear lighting run code lighting type T sample order: [BLANK] RGB leave blank for noncolor-changing lighting 1555 BARCLAY BLVD. BUFFALO GROVE, IL 60089 TSPLICE single connector for 2 runs of linear lighting (the top of the connector has a red dot) connector type size length (inches) YCON-SL 8MM 12 CON-SL YCON-SL COR-SL PWR-SL YPWR-SL SPL-SL 8MM 10MM 14MM 3 6 12 24 36 60 Custom SALES@LEDLIGHTINGINC.COM 847 412 4880 WWW.LEDLIGHTINGINC.COM
TCON-SL-8MM-60 价格&库存
很抱歉,暂时无法提供与“TCON-SL-8MM-60”相匹配的价格&库存,您可以联系我们找货
