SS2200A
SS2200A
    NEXTGEN
    SMA(DO-214AC)
    DIODE SCHOTTKY 200V 2A SMA
SS2200A 数据手册
PART CODE: SMASS2200S2200 SPECIFICATION SHEET SPECIFICATION SHEET NO. P1105- SMASS2200S2200 DATE Nov. 05, 2022 REVISION A1 DESCRIPITION SMD Schottky Barrier Rectifier, 2 Pads, SMA series, SS2200A Type Reverse Voltage 200V Max. Forward Current 2.0A Max. Operating Temp. Range -55°C ~+150°C Package in Tape/Reel, 5000pcs/13” Reel RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER MDD SS2200A PART CODE SMASS2200S2200 VENDOR APPROVE Issued/Checked/Approved DATE: Nov. 05, 2022 CUSTOMER APPROVE DATE: 11/5/2022 NextGen Components, Inc. 1 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMASS2200S2200 SMD SCHOTTKY BARRIER RECTIFIER SMA SERIES MAIN FEATURE • The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 • Low power loss and high efficiency • Built-in strain relief, • High forward surge current capability • Metal silicon junction, majority carrier conduction • High temperature soldering guaranteed: 250℃/ 10 seconds at terminals APPLICATION • For surface mounted applications RFQ PART CODE GUIDE Request For Quotation SMA SS2200 S 2200 1 2 3 4 1) SMA: SMD Schottky Barrier Rectifier, 2 Pads, SMA series, 2) SS2200: Type code for original part number SS2200A 3) S: Package code, Tape/reel, 5000pcs/reel. 4) 2200: Specification code for. Forward Current 2.0A Max, Reverse Voltage 200V Max. 11/5/2022 NextGen Components, Inc. 2 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMASS2200S2200 SMD SCHOTTKY BARRIER RECTIFIER SMA SERIES DIMENSION (Unit: Inch/mm) Image for reference Marking: SS2200 SMA/DO-214AC Recommend Pad Layout 11/5/2022 NextGen Components, Inc. Symbol Unit (Inch) Unit (mm) A 0.066 1.680 B 0.060 1.520 C 0.154 3.900 D 0.095 2.410 E 0.215 5.450 3 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMASS2200S2200 SMD SCHOTTKY BARRIER RECTIFIER SMA SERIES MECHANICAL DATA Case Terminals Polarity Mounting Position Weight per piece JEDEC DO-21AC/SMA molded plastic body Solder plated, Solderable per MIL-STD-750, Method 2026 Color band denotes cathode end mounting Any 0.0021 Ounce, 0.0600 grams MAX. RATING & CHARACTERISTICS Parameter SYMBOLS VALUE Min. Typical UNITS Max. Repetitive peak reverse voltage V RRM 200 Volts RMS voltage V RMS 140 Volts DC blocking voltage V DC 200 Volts Average forward output rectified current I AV 2.0 A at TL(see fig.1) I FSM Peak forward surge current 8.3ms single half 50 A sine-wave superimposed on rated load (JEDEC Method) Instantaneous forward voltage at 2.0A DC reverse current at rated DC blocking voltage TA=25℃ VF 0.95 Volts IR 0.30 mA 3.0 mA TA=100℃ Junction capacitance (Note 2) CJ 80 pF Thermal resistance (Note 3) R QJA 80 °C/W Operating junction temperature range Storage temperature range TJ -55 +150 °C T STG -55 +150 °C Note 1. Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. 2. Measured at 1.0MHz and applied reverse voltage of 4.0Voltage 3. P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas. 11/5/2022 NextGen Components, Inc. 4 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMASS2200S2200 SMD SCHOTTKY BARRIER RECTIFIER SMA SERIES RELIABILITY Number Experiment Items Experiment Method And Conditions Reference Documents 1 Solder Resistance Test Test 260°C± 5°C for 10 ± 2 sec. Immerse body into solder 1/16” ± 1/32" MIL-STD-750D METHOD-2031.2 2 Solderability Test 230°C ±5°C for 5 sec. MIL-STD-750D METHOD-2026.1 0 3 Pull Test 1 kg in axial lead direction for 10 sec. MIL-STD-750D METHOD-2036.4 4 Bend Test 0.5Kg Weight Applied To Each Lead, Bending Arcs 90 °C ± 5 °C For 3 Times MIL-STD-750D METHOD-2036.4 5 High Temperature Reverse Bias Test TA=100°C for 1000 Hours at VR=80% Rated VR MIL-STD-750D METHOD-1038.4 6 Forward Operation Life Test TA=25°C Rated Average Rectified Current MIL-STD-750D METHOD-1027.3 7 Intermittent Operation Life Test On state: 5 min with rated IRMS Power Off state: 5 min with Cool Forced Air. On and off for 1000 cycles. MIL-STD-750D METHOD-1036.3 8 Pressure Cooker Test 15 PSIG, TA=121°C, 4 hours MIL-S-19500 APPENOIXC 9 Temperature Cycling Test -55°C~+125°C; 30 Minutes For Dwelled Time 5 minutes for transferred time. Total: 10 cycles. MIL-STD-750D METHOD-1051.7 10 Thermal Shock Test 0°C for 5 minutes., 100°C for 5minutes, Total: 10 cycles MIL-STD-750D METHOD-1056.7 11 Forward Surge Test 8.3ms Single Sale Sine-wave One Surge. MIL-STD-750D METHOD-4066.4 12 Humidity Test TA=65°C, RH=98% for 1000 hours. MIL-STD-750D METHOD-1021.3 13 High Temperature Storage life Test 150°C for 1000 Hours MIL-STD-750D METHOD-1031.5 11/5/2022 NextGen Components, Inc. 5 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMASS2200S2200 SMD SCHOTTKY BARRIER RECTIFIER SMA SERIES SUGGESTED REFLOW PROFILE (For Reference Only) Profile Feature Pb-Free Assembly Average Ramp-up Rate (Ts Max to Tp) 3℃/second Max Preheat Temperature Min (Ts Min.) 150℃ Temperature Max (Ts Max.) 200℃ Time (ts Min. to ts Max.) 60~180 seconds Temperature (TL) 217℃ Time (tL) 60~150 seconds Time maintained above Peak/Classification Temperature (Tp) 250 ℃ Time within 5℃ of actual Peak Temperature (tp) 10 seconds Ramp-down rate 6 ℃ /Second Max. Time 25 ℃ to Peak Temperature 6 minutes Max. Suggest reflow times 3 Times Max. 11/5/2022 NextGen Components, Inc. 6 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMASS2200S2200 SMD SCHOTTKY BARRIER RECTIFIER SMA SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) 11/5/2022 NextGen Components, Inc. 7 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMASS2200S2200 SMD SCHOTTKY BARRIER RECTIFIER SMA SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) 11/5/2022 NextGen Components, Inc. 8 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMASS2200S2200 SMD SCHOTTKY BARRIER RECTIFIER SMA SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) 11/5/2022 NextGen Components, Inc. 9 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMASS2200S2200 SMD SCHOTTKY BARRIER RECTIFIER SMA SERIES TAPE/REEL (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-A and specifications. Item Symbol Tolerance SMA/DO-214AC Carrier width A 0.1 2.8 Carrier Length B 0.1 5.33 Carrier Depth C 0.1 2.36 Sprocket hole d 0.05 1.50 13”Reel outside diameter D - 330.00 13”Reel inner diameter D1 - 50.00 7”Reel outside diameter D - - 7”Reel inner diameter D1 - - Feed hole diameter D2 0.5 13.00 Sprocket hole position E 0.1 1.75 Punch hole position F 0.1 5.50 Punch hole pitch P 0.1 4.00 Sprocket hole pitch P0 0.1 4.00 Embossment center P1 0.1 2.0 Overall tape thickness T 0.1 0.28 Tape width W 0.3 12.00 Reel width W1 1.0 18.0 11/5/2022 NextGen Components, Inc. sales@NextGenComponent.com 10 www.NextGenComponent.com PART CODE: SMASS2200S2200 SMD SCHOTTKY BARRIER RECTIFIER SMA SERIES PACKAGE For Reference Case Code SMA Reel Size 13” Reel Size 330 mm MPQ/Reel 5000 pcs Qty. /Box 10000 pcs G.W/Box 6 lbs IMPORTANT NOTICE AND DISCLAIMER 1)NextGen Component, Inc. reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. 2)NextGen Component, Inc makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does NextGen Component, Inc assume any liability for application assistance or customer product design. 3)NextGen Component, Inc does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of NextGen Component, Inc 4)NextGen Component, Inc. products are not authorized for use as critical components in life support devices or systems without express written approval of NextGen Component, Inc. 11/5/2022 NextGen Components, Inc. 11 sales@NextGenComponent.com www.NextGenComponent.com
SS2200A 价格&库存
很抱歉,暂时无法提供与“SS2200A”相匹配的价格&库存,您可以联系我们找货
