1N4148W T4
1N4148W T4
    MDD(辰达半导体)
    SOD123
    SWITCHING SOD-123, 100V
1N4148W T4 数据手册
PART CODE: SOD1234148WST4 SPECIFICATION SHEET SPECIFICATION SHEET NO. N0729-SOD1234148WST4 DATE July 29, 2021 REVISION A0 DESCRIPITION SMD Fast Switching diodes, SOD-123 series, 2 pads, Type 1N4148W T4 Reverse Voltage 100V Max. Forward Current 0.30A Max. Operating Temp. Range -65°C ~+150°C, Package in Tape/Reel, 3000pcs/Reel RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER MDD 1N4148W T4 PART CODE SOD1234148WST4 VENDOR APPROVE Issued/Checked/Approved DATE: July 29, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOD1234148WST4 SMD FAST SWITHING DIODES SOD123 SERIES MAIN FEATURE • Fast switching speed • Surface mount package ideally suited for automatic insertion • High conductance APPLICATION • For general purpose switching applications RFQ PART CODE GUIDE Request For Quotation SOD123 4148W S T4 1 2 3 4 1) SOD123: SMD Small Signal Fast Switching diodes, 2 pads, SOD-123 series code 2) 4148W: Type Code for original part number 1N4148W T4 3) S: Package code, Tape/reel, 3000pcs/reel. 4) T4: Marking code for “T4” on the case surface, Different Marking for different specification. NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOD1234148WST4 SMD FAST SWITHING DIODES SOD123 SERIES DIMENSION (Unit: Inch/mm) Image for reference Marking: T4 SOD-123 Recommend Pad Layout NextGen Components, Inc. sales@NextGenComponent.com Symbo l Unit (inch) Unit (mm) A 0.047 1.20 B 0.047 1.20 C 0.126 3.20 D 0.079 2.00 E 0.173 4.40 www.NextGenComponent.com SOD1234148WST4 PART CODE: SMD FASTSMD SWITHING SCHOTTKY SMD DIODES GENERAL BARRIER SOD123 RECTIFER RECTIFER SERIES MECHANICAL DATA Case Terminals Polarity Mounting Position Weight per piece JEDEC SOD-123 molded plastic body Solder plated, Solderable per MIL-STD-750, Method 2026 Polarity symbol marking on case Any 0.0007 Ounce, 0.0021 grams VALUE UNITS ABSOLUTE MAX. RATING AT 25 °C Parameter SYMBOLS Min. Typical Max. Repetitive peak reverse voltage V RRM 100 Volts RMS voltage V RMS 75 Volts Forward continuous current I FM 150 mA Non-reptitive Peak Forward Surge Current @=1.0 s @1.0µs I FSM 1.0 2.0 A Power Dissipation Ptot 400 mW Thermal resistance junction to ambient R QJA 250 °C/W Operating Junction temperature range TJ -65 +150 °C T STG -65 +150 °C Storage temperature range CHARACTERISTICS at Ta= 25 °C Parameter SYMBOLS VALUE Min. Forward Voltage Reverse Current Junction Capacitance Reverse Breakdown Voltage Reverse recovery time NextGen Components, Inc. Typ. UNIT Condition Max. V F1 0.720 V I F= 10 µA V F2 0.855 V IF= 5 mA V F3 1.00 V IF = 100 mA V F4 1.25 V IF 150 mA I R1 25 nA at VR= 20 V, Tj= 25°C I R2 1.0 µA at VR= 75 V, Tj= 25°C C tot 2 pF V (BR)R 75 V t rr 4 ns sales@NextGenComponent.com at IR=1μ www.NextGenComponent.com PART CODE: SOD1234148WST4 SMD FAST SWITHING DIODES SOD123 SERIES RELIABILITY Number Experiment Items Experiment Method And Conditions Reference Documents 1 Solder Resistance Test Test 260°C± 5°C for 10 ± 2 sec. Immerse body into solder 1/16” ± 1/32" MIL-STD-750D METHOD-2031.2 2 Solderability Test 230°C ±5°C for 5 sec. MIL-STD-750D METHOD-2026.1 0 3 Pull Test 1 kg in axial lead direction for 10 sec. MIL-STD-750D METHOD-2036.4 4 Bend Test 0.5Kg Weight Applied To Each Lead, Bending Arcs 90 °C ± 5 °C For 3 Times MIL-STD-750D METHOD-2036.4 5 High Temperature Reverse Bias Test TA=100°C for 1000 Hours at VR=80% Rated VR MIL-STD-750D METHOD-1038.4 6 Forward Operation Life Test TA=25°C Rated Average Rectified Current MIL-STD-750D METHOD-1027.3 7 Intermittent Operation Life Test On state: 5 min with rated IRMS Power Off state: 5 min with Cool Forced Air. On and off for 1000 cycles. MIL-STD-750D METHOD-1036.3 8 Pressure Cooker Test 15 PSIG, TA=121°C, 4 hours MIL-S-19500 APPENOIXC 9 Temperature Cycling Test -55°C~+125°C; 30 Minutes For Dwelled Time 5 minutes for transferred time. Total: 10 cycles. MIL-STD-750D METHOD-1051.7 10 Thermal Shock Test 0°C for 5 minutes., 100°C for 5minutes, Total: 10 cycles MIL-STD-750D METHOD-1056.7 11 Forward Surge Test 8.3ms Single Sale Sine-wave One Surge. MIL-STD-750D METHOD-4066.4 12 Humidity Test TA=65°C, RH=98% for 1000 hours. MIL-STD-750D METHOD-1021.3 13 High Temperature Storage life Test 150°C for 1000 Hours MIL-STD-750D METHOD-1031.5 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOD1234148WST4 SMD FAST SWITHING DIODES SOD123 SERIES SUGGESTED REFLOW PROFILE (For Reference Only) • Recommended peak temperature is over 245℃, If peak temperature is below 245 ℃, you may adjust the following parameters; time length of peak temperature (longer), time length of soldering (longer), thickness of solder paste (thicker) • Welding shall not exceed 2 times • Remark: lead free solder paste (96.5 sn/3.0 Ag/0.5Cu) NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOD1234148WST4 SMD FAST SWITHING DIODES SOD123 SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOD1234148WST4 SMD FASTSMD SWITHING SCHOTTKY DIODES BARRIER SOD123 RECTIFER SERIES TAPE/REEL (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-A and specifications. Item Symbol Tolerance SO-123 Carrier width A 0.1 2.10 Carrier Length B 0.1 4.00 Carrier Depth C 0.1 1.60 Sprocket hole d 0.05 1.55 13”Reel outside diameter - - - 13”Reel inner diameter - - - 7”Reel outside diameter D 2.0 178.00 7”Reel inner diameter D1 Min. 50.00 Feed hole diameter D2 0.5 13.00 Sprocket hole position E 0.1 1.75 Punch hole position F 0.1 3.50 Punch hole pitch P 0.1 4.00 Sprocket hole pitch P0 0.1 4.00 Embossment center P1 0.1 2.00 Overall tape thickness T 0.1 0.25 Tape width W 0.3 8.15 Reel width W1 1.0 10.50 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SOD1234148WST4 SMD FAST SWITHING DIODES SOD123 SERIES PACKAGE Case Code SOD-123 Reel Size 7” MPQ Qty. Per Box (pcs) Inner Box L*W*H (mm) Reel Size (mm) Carton size L*W*H (mm) Qty. Per Carton (pcs) G. W (pcs) Component Spacing (mm) 3,000 - 24,000 210*208*203 178 400*400*250 180,000 9.0 (kg) DISCLAIMER NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
1N4148W T4 价格&库存
很抱歉,暂时无法提供与“1N4148W T4”相匹配的价格&库存,您可以联系我们找货
