ESD5Z7V0
ESD5Z7V0
    MDD(辰达半导体)
    SOD-523(SC-79)
    TVS DIODE 7VWM 13.5VC SOD523
ESD5Z7V0 数据手册
ESD5Z Series Transient Voltage Suppressors SOD-523 Plastic-Encapsulate ESD Protection Diodes DESCRIPTION The ESD5Z Series is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Because of its small size, it is suited for use in cellular phones, portable devices, digital cameras, power supplies and many other portable applications.. Features Pin Configuration  IEC61000-4-2 Level 4 ESD Protection  Protects one directional I/O line  Low clamping voltage  Working voltages : 2.5V,3.3V,5V,6V,7V, 12V,15V  Low leakage current) Circuit Diagram 2 1 Applications       Cell Phone Handsets and Accessories Microprocessor based equipment Personal Digital Assistants (PDA’s) Notebooks, Desktops, and Servers Portable Instrumentation Peripherals Mechanical Characteristics  Package: SOD-523  Flammability Rating: UL 94V-0  High temperature soldering guaranted: 260℃/10s  Packaging: Tape and Reel Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) ESD Voltage per human body model ESD Voltage per machine model Total Power Dissipation on FR-5 Board (Note 1) @ Ta=25°C Junction and Storage Temperature Lead Solder Temperature – Maximum (10 Second Duration) Symbol Value Unit VESD ± 30 ± 22 kV ESD 16 400 kV PD 150 mW TJ,TSTG −55 to +150 °C TL 260(10S) °C V hese ratings are limiting values above which the serviceability of the diode may be impaired Note:1.FR-5=1.0x0.75x0.62 in 2.The above data above is for reference only. http://www.microdiode.com Rev:2025A3 Page :1 ESD5Z Series Transient Voltage Suppressors ESD5Z12V ESD5Z15V (V) M Max ax Max Min (mA) Max @A Max 6 ESD5Z7V0 (μA) 2.5 6.0 4.0 1 9.0 5.0 8 ESD5Z6V0 (V) 3.3 0.90 5.0 1 10.0 8 ESD5Z5V0 VB 5.0 0.08 6.2 1 5 ESD5Z3V3 IR 6.0 0.05 6.8 8 ESD5Z2V5 VRWM 7.0 0.03 8 PART NUMBER 12.0 8 Electrical Characteristics (TA=25°C unless otherwise specified) 15.0 DEVICE MARKING ZD ·· ZE ·· ZF ·· ZG ·· ZH ·· ZM ·· ZN ·· http://www.microdiode.com VC VC PPK CJ (V) (V) (W) (pF) @A Max Max 11.5 9.0 104 145 5.0 14.0 7.5 .5 105 105 11.6 5.0 15.0 7.0 .0 105 80 1 13.5 5.0 17.5 6.0 .0 105 70 7.5 1 14.0 5.0 18.0 6.0 .0 108 65 0.03 14.1 1 20.0 1.0 26.0 4.0 104 45 0.50 16.0 1 23.0 1.0 30.0 4.0 120 28 IT Rev:2025A3 Page :2 ESD5Z Series Transient Voltage Suppressors ELECTRICAL CHARACTERISTICS CURVE http://www.microdiode.com Rev:2025A3 Page :3 ESD5Z Series Transient Voltage Suppressors Outlitne Drawing SOD-523 Package Outline Dimensions Suggested Pad Layout Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. PACKAGE SPECIFICATIONS Package Reel Size SOD-523 7' http://www.microdiode.com REF mm inch A 0.99+/-0.10 0.036+/-0.004 B 1.85+/-0.10 0.072+/-0.004 d 1.55+/-0.10 0.060+/-0.004 D 178.00+/-1.00 7.008+/-0.039 D1 54.20+/-2.00 2.134+/-0.079 D2 13.50+/-0.20 0.532+/-0.008 E 1.75+/-0.10 0.068+/-0.004 F 3.50+/-0.10 0.136+/-0.004 P 2.00+/-0.10 0.078+/-0.004 P0 4.00+/-0.10 0.156+/-0.004 P1 2.00+/-0.10 0.078+/-0.004 W 8.00+/-0.10 0.312+/-0.004 W1 9.30+/-0.50 0.366+/-0.020 Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) 178 3000 190×190×190 QTY/Box (pcs) 18,000 Carton Size (mm) Q'TY/Carton (pcs) 400×400×220 108,000 Rev:2025A3 Page :4
ESD5Z7V0 价格&库存
很抱歉,暂时无法提供与“ESD5Z7V0”相匹配的价格&库存,您可以联系我们找货
