Y3FSS112DM0L01
Y3FSS112DM0L01
    NEXTGEN
    RELAY GEN PURPOSE SPST 10A 12V
Y3FSS112DM0L01 数据手册
PART CODE: Y3FSS112DM0L01 SPECIFICATION SHEET SPECIFICATION SHEET NO. N0423-Y3FSS112DM0L01 DATE April. 23, 2021 REVISION A0 DESCRIPITION Sealed Subminiature High Power Relay Y3F series, L19.6*W15.4*H15.5mm, 4 Pins Material of contact: Silver Alloy, Contact form: 1A (C/O) Coil power: 0.36 W, Switching current:10A Max Nominal voltage 12 VDC Package: 100pcs/inner box , 1000pcs/Carton in Bulk RoHS III and REACH Compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER Y3F-SS-112DM PART CODE Y3FSS112DM0L01 VENDOR APPROVE Issued/Checked/Approved DATE: Apr.23, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: Y3FSS112DM0L01 SEALED SUBMINIATURESMD HIGHCRYSTAL POWER2520 RELAYTYPE Y3F 4SERIES PADS MAIN FEATURE • Material of contact: Silver Alloy, Contact Form: 1A (C/O) • Coil power: 0.36W • Switching current: 10A Max. • Nominal voltage 12 VDC • Cross main competitors parts HF33F, G5S, PCH and more • RoHS/RoHS III compliant APPLICATION • Office equipment and Security alarm system • Home Appliance Telecommunication Equipment • Automatic electric controlled window, automotive antenna, door lock, etc. RFQ PART CODE GUIDE Request For Quotation Y3F SS112DM0 L 01 1 2 3 4 1) Y3F: Part family Code for Sealed Subminiature High Power Relay, L19.6*W15.4*H15.5mm, 4 Pins 2) SS112DM0: Type code for original part number SS-112DM 3) L: Thru Hole type, Package: 100pcs/inner box , 1000pcs/Carton 4) 01: Internal control code, 2 letter or digits NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: Y3FSS112DM0L01 SEALED SUBMINIATURE HIGH POWER RELAY Y3F SERIES DIMENSION (Unit: mm, Tol: +/-0.4mm Max.) Image for reference Marking Sample Y3F Wiring Diagram (Bottom View) NextGen Components, Inc. sales@NextGenComponent.com PCB Layout ( Bottom View) www.NextGenComponent.com PART CODE: Y3FSS112DM0L01 SEALED SUBMINIATURE HIGH POWER RELAY Y3F SERIES GENERAL PARAMETERS Parameter Part No. Symbol Value Original Manufacturer Y YuanZe Relay Holder Type 3F Size L19.6*W15.4*H15.5mm, 4 Pins Enclosure SS Flux-tight Contact Pole 1 1 Pole Nominal voltage 12 12V Coil Nominal Power D Standard coil power, 0.36W M0 1 Form A, 4 Pins Package L Package: 100pcs/inner box , 1000pcs/Carton Internal Control Code 01 Code- 2 letter or digits Contact arrangement RoHS and REACH Status RoHS III and REACH Compliant UL certified File NO. E341498 10A 250 VAC (Resistive) 15A 125 VAC (Resistive) 6A 277 VAC (Standard Ballast) TV-5 120 VAC (Tungsten Lamp) TUV certified File No. R50197243 10A 250VAC 10 A 30VDC 7 A 250VAC CQC certified File No. CQC11002056154 10 A 250VDC 7 A 250VAC NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: Y3FSS112DM0L01 SEALED SUBMINIATURE HIGH POWER RELAY Y3F SERIES ELECTRICAL PARAMETERS Parameter Unit Value Min. Coil specification Contact specification Typ. Max. Nominal voltage V 12 DC Coil resistance Ω 400 ±10% at 23±5℃ Rated current mA 30 DC ±10% at 23±5℃ Operate voltage V 9.0 Release voltage V Maximum voltage V 15.6 130% of nominal voltage Coil temperature rise K 50K @ Coil:12V Contact configuration DC at 23±5℃ SPDT (1 Form A) Contact rating NO:10A 250VAC (Resistive Load) 15A 125VAC ( Resistive Load) TV-5 120 VAC (Tungsten Lamp) Contact resistance mΩ 100 Operate time ms 10 operating frequency Cycle /hour mΩ 18000 600 Mechanically Electrically 50K @ Contact:10A 100 @ DC 500V Dielectric strength between open contacts between contacts & coil V Ambient temperature ℃ -40 +105 Relative Humidity RH 45% 85% Electrical life Cycle 100K Mechanical life Cycle 10KK Switching Current A Coil Nominal Power W Contact arrangement NextGen Components, Inc. @DC6V 1A 5 Contact temperature rise Insulation resistance DC at 23±5℃ 0.6 Release time General specification Condition 750 1500 AC 50/60 HZ for 1Minute @ NO/NC 10A 250VAC 10 0.36 1 Form C sales@NextGenComponent.com www.NextGenComponent.com PART CODE: Y3FSS112DM0L01 SEALED SUBMINIATURE HIGH POWER RELAY Y3F SERIES ENVIRONMENTAL CHARACTERISTICS Test Items Test Method And Conditions Requirement Vibration resistance Error operation: At constant vibration of double amplitude 1.5mm, 10 ~55 HZ , in each direction of X,Y,Z for 5 minutes. No error operation more than 1 ms. Endurance: No construction trouble when vibrate it from 3 directions for 2 hours.( Amplitude 1.5mm, 10~55 HZ) It shall meet the specification Shock resistance Error operation: At peak acceleration 100m/s2, duration 11ms, 3 shocks is given in each direction of X, Y, Z. No error operation more than 1 ms. Endurance: No construction trouble when shock it from 3 directions 3 times at peak acceleration 1000m/s2,duration 6ms. It shall meet the specification Cold resistance No any trouble on construction or characteristic when leave relay in – 40℃±2℃ for 240h. After that, leave it in standard condition for 2 hours. It shall meet the specification Heat resistance No any trouble on construction or characteristic when leave relay in +85℃±2℃ for 240h. After that, leave it in standard condition for 2 hours. It shall meet the specification After keeping relay for 240h in 40℃, 90%, then leave it in standard condition for 2 hours. Insulation resistance 10MΩ Min. No any trouble on construction or characteristic It shall meet the specification Moisture resistance TERMINAL CHARACTERISTICS Test Items Test Method And Conditions Requirement Terminal strength 5N pushed into any terminals for 10 s. There shall be no abnormalities. The curving of the terminals shall be acceptable Terminal solderability In case of lead free solder 260±5℃, 5±0.5 s , 90% of the dipped portion shall be soldered It shall meet the specification No any trouble on construction or characteristic. When dipped into solder bath 260±5℃, 10±1s. It shall meet the specification Soldering thermal NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: Y3FSS112DM0L01 SEALED SUBMINIATURE HIGH POWER RELAY Y3F SERIES STANDARD TEST CONDITION Test Items Test Method And Conditions Requirement Ambient temperature 23±5℃ It shall meet the specification Relative humidity 25%~75% It shall meet the specification Air pressure 86kPa~106kPa It shall meet the specification Test Items Test Method And Conditions Requirement Ambient temperature -40℃~+85℃ It shall meet the specification Relative humidity 35%~85% It shall meet the specification Environment Store in locations where the product or container is not expose to corrosive gas such as hydrogen sulfide Store in locations where no visible dust exists. Store in locations not subject to direct sunlight. It shall meet the specification STORAGE CONDITION Reminds 1. Any special requirements, please contact us. 2. Under the Environment with dangerous gas such as H2S, SO2 or NO2, fully sealed type is recommended. 3. If the ambience allows, flux proof type is preferentially recommended. 4. If the user washes the PCB and relay in the ultrasonic cleaner, fully sealed type must be selected NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: Y3FSS112DM0L01 SEALED SUBMINIATURE HIGH POWER RELAY Y3F SERIES PACKAGE (Unit: mm) Series No. MPQ Inner Box Pcs Carton Dimension cm MOQ Carton pcs Net Weight Kgs Gross Weight Kgs Y3F 100 L34.0*W22.5*H17.5 1000 7.9 9.0 DISCLAIMER NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
Y3FSS112DM0L01 价格&库存
很抱歉,暂时无法提供与“Y3FSS112DM0L01”相匹配的价格&库存,您可以联系我们找货
