NL-SW-LTE-WM14
NL-SW-LTE-WM14
    NIMBELINK
    Module
    RF TXRX MODULE CELLULAR U.FL ANT
NL-SW-LTE-WM14 数据手册
Skywire® LTE CAT 1 M14A2A Embedded Cellular Modem Datasheet NimbeLink Corp Updated: December 2017 PN 30264 rev 9 © NimbeLink Corp. 2017. All rights reserved. 1 Table of Contents Table of Contents 2 Introduction Orderable Part Numbers Additional Resources Product Overview Block Diagram 4 4 4 4 5 Technical Specifications Electrical Specifications Absolute Maximum Ratings Recommended Ratings & Module Pin out Connectors J1 and J2 Connectors J3, X1, X2 Typical Power Consumption Mechanical Specifications Mechanical Characteristics Mating Connectors Device Placement Environmental Specifications 6 6 6 6 6 7 8 9 9 9 9 9 Important Design Considerations PWR_ON Signal Power Supply Requirements Serial Communications LED GPIO Control WAKE Pins 10 10 10 10 10 10 11 Mounting Guidelines Board to Board connectors approach Solder to Board connection approach 12 12 13 Antenna Considerations Supported Frequencies Conducted TX Power Conducted RX Sensitivity Primary Antenna Requirements Diversity Antenna Requirements 14 14 14 14 15 15 PN 30264 rev 9 © NimbeLink Corp. 2017. All rights reserved. 2 Recommended Antennas 15 Certifications Carrier Specific Geography Specific 16 16 16 Federal Regulatory Licensing 16 End Product Labeling Requirements 16 PN 30264 rev 9 © NimbeLink Corp. 2017. All rights reserved. 3 1. Introduction 1.1 Orderable Part Numbers Orderable Device Firmware Revision Operating Temperature Bands Fallback Network Type NL-SW-LTE-WM14 NL-SIM-ATT NL-SIM-TMO NL-SIM-VOD v11.50.164451 NA NA NA -25 to +75˚C -25 to +85˚C -25 to +85˚C -25 to +85˚C B2, B4, B12 None LTE AT&T T-Mobile Vodafone 1.2 Additional Resources The following documents or documentation resources are referenced within this document. ● WNC's M14A2A Hardware Design Guidelines ● WNC's M14A2A AT Command Manual 1.3 Product Overview Add robust cellular connectivity to your M2M devices with scalable radio technology with Skywire line of modems including M14A2A-based LTE solutions. Extensive experience in designing and building embedded product solutions makes the NimbeLink Skywire® embedded cellular modem the smallest on the market. It uses the popular Skywire interface and supports multiple LTE bands minimizing costs of hardware and network access. The module is designed for volume production and is intended for OEMs to embed into end equipment designs. PN 30264 rev 9 © NimbeLink Corp. 2017. All rights reserved. 4 1.4 Block Diagram PN 30264 rev 9 © NimbeLink Corp. 2017. All rights reserved. 5 2. Technical Specifications 2.1 Electrical Specifications 2.1.1 Absolute Maximum Ratings Parameter Signal Maximum Rating Main Power Supply I/O Voltage Reference VCC VREF 5.5V 5.5V 2.1.2 Recommended Ratings & Module Pin out 2.1.2.1 Connectors J1 and J2 Pin Name Directi on Description Min Typical 1 VCC Input Main Power supply 3.0V 3.9V UART data out, I/O level tied to VREF VOL: GND to 0.55V Input UART data in, I/O level tied to VREF VIL: GND to 0.15V Input Ground Pin 2 DOUT Output 3 DIN 4 GND Max If not used 5.5V Must be implemented VOH: VREF x 0.67 to VREF VIH: VREF-0.4 V to VREF 0 Must be implemented if USB not used, No connection Must be implemented if USB not used, No connection Must be implemented 5 RESET_nIN Input Controls RESET input on WNC M14A2A, tie low for a minimum of 100msec and released to activate. Internally pulled up to WNC VREF pin. Drive with open collector output. Assert only in an emergency as the module will not gracefully exit the cellular network when asserted. 6 VUSB Input Supply for USB interface 7 USB_D+ I/O USB differential Data + signal No connection 8 USB_D- I/O No connection 9 nWAKE_IN Input 10 GND Input USB differential Data - signal Controls the M14A2A's WAKEUP_IN input. HIGH means the host does not need the MODEM (allowing it to sleep). LOW means the host needs the Skywire or acknowledges it is ready following a wakeup from the Skywire. See WAKE Pins section for more information. Ground Pin 11 GND Input Ground Pin 12 CTS Output Modem Clear to Send hardware flow control output PN 30264 rev 9 VREF 4.4V 5V 0 No connection 5V 5.5V No connection Pulled LOW 0 Must be implemented 0 Must be implemented VOL: GND to 0.55V © NimbeLink Corp. 2017. All rights reserved. VOH: No connection 6 VREF x 0.67 to VREF 13 nWAKE_OUT Output Connects to the M14A2A's WAKEUP_OUT output. HIGH means the Skywire does not need the host (allowing the host to sleep or not attend to the modem).LOW means the Skywire needs the host or acknowledges it is ready following a wakeup from the host. See WAKE Pins section for more information. 0 1.65V 14 VREF Input Voltage reference for off board I/O signals. This signal drives the input voltage side of an onboard buffer which converts all external I/O voltage from VREF range to 1.8V range to drive the onboard M14A2A modem module. 15 GND Input Ground Pin 16 RTS Input 17 GPIO2 I/O 18 GPIO3 I/O 19 ADC1 Input 20 ON_OFF Input 1.8V or 3.3V VREF No connection 5.5V Must be implemented 0 Must be implemented VIL: GND to 0.15V VIH: VREF-0.4 V to VREF 0 1.8V No connection 0 1.8V No connection ADC input on M14A2A module (10-bit resolution) 0 1.8V No connection Modem POWER_ON signal. Modem is ON when ON_OFF is tied to GND. 0 1.8V Must be implemented. Modem Request to Send hardware flow control input Programmable GPIO02 on M14A2A module. See GPIO section for further details Programmable GPIO03 on M14A2A module. See GPIO section for further details 2.1.2.2 Connector Designator J3 Tie to GND Connectors J3, X1, X2 Description Connector Location Micro SIM Connector Bottom Side of Module X1 Primary Antenna Connection Topside of Module X2 Diversity Antenna Connection Topside of Module PN 30264 rev 9 © NimbeLink Corp. 2017. All rights reserved. 7 2.1.2.3 Measurement Attenuation (dB) Typical Power Consumption AT+CSQ Min Current (mA) Average Current (mA) Peak Current (mA) Average Charge (μAh) Socket Dial 0 22 - 152.08 562.9 239.73 Socket Dial 20 10 - 159.02 729.56 251.0 Socket Dial 40 7 - 188.46 729.57 351.57 Off 0 - - 288.8 (μA) 5.05 72.23 Idle 0 22 - 74.59 341.79 18655.76 Idle - Lower Power 0 PN 30264 rev 9 22 - 7.6 339.18 1857.28 © NimbeLink Corp. 2017. All rights reserved. Notes Tested at 3.8V Time elapsed: 5.682s Test: Opening socket, making HTTP POST, reading HTTP response, closing socket. Tested at 3.8V Time elapsed: 5.6616s Test: Opening socket, making HTTP POST, reading HTTP response, closing socket. Tested at 3.8V Time elapsed: 5.724s Test: Opening socket, making HTTP POST, reading HTTP response, closing socket. Tested at 3.8V Connected to power, not turned on. 15 minute sample. Tested at 3.8V Registered on network, 15 minute sample period. Skywire nWAKE_IN pin tied to GND. Tested at 3.8V Registered on network, 15 minute sample period. Skywire nWAKE_IN pin tied to IO HIGH. 8 2.2 Mechanical Specifications 2.2.1 Mechanical Characteristics Parameter Dimensions (excluding pin height, for solder to board applications) Dimensions (including pin height, for board to board connector applications) Weight Connector Insertion/Removal Typical Unit 29.0 x 33.60 x 6.63 29.0 x 33.60 x 10.73 0.4 hundreds mm mm oz Cycles 2.2.2 Mating Connectors Connector Designator Manufacturer J1, J2 3M J3 Molex Hirose X1, X2 Populated on Module 951110-2530AR-PR Recommended Mate Mate Manufacturer 950510-6102-AR Acceptable alternate: NPPN101BFCN-RC 3M Sullins Connector Solutions 786463001 Micro SIM Card Micro SIM Card U.FL-R-SMT(1 0) CAB.011 Taoglas 2.2.3 Device Placement ⚠ Make sure the Skywire is installed in the correct orientation; failure to do so will damage the device and void the warranty. 2.3 Environmental Specifications Parameter Min Typical Max Unit Note Operating Temperature Operating Humidity -25 20 25 +75 90 ˚C % Non-condensing PN 30264 rev 9 © NimbeLink Corp. 2017. All rights reserved. 9 3. Important Design Considerations 3.1 PWR_ON Signal In order to power on the M14A2A, ON_OFF must be tied to GND. This is different than some Skywire models that only require a pulsed low on the PWR_ON Signal. 3.2 Power Supply Requirements The module will regularly consume high amounts of current on the Main Power Supply (VCC), up to 1.5A during active transmits and receives. The baseboard power supply should be designed to support peak currents up to 2 Amps. A 100uF capacitor should be placed near the VCC pin on the module to ensure ample energy is available, with a low inductance path to the VCC pin. For example power supply designs, there are multiple references available. See the NimbeLink Skywire Development Kit schematic for a switching regulator example. 3.3 Serial Communications The M14A2A can communicate over UART and/or USB. Design should implement one or both serial interfaces to be able to send commands to the modem. 3.4 LED The Skywire has an on board LED D1 connected to M14A2A's WWAN_STATE pin. The LED will turn on when the M14A2A is registered on the network, and will turn off indicating no cellular connection. 3.5 GPIO Control Modem interface Pins 17 and 18 can be used as a GPIO input or output via AT Commands. Please consult the WNC M14A2A AT Command Manual for more examples and command specifics: Configure M14A2A GPIO02 as GPIO pin: AT@GPIOREQ=1,2 OK Set GPIO02 as output driving high (1.8V): AT@GPIOCFG=2,1,1 OK Get GPIO02's state: AT@GPIOGET=2 PN 30264 rev 9 © NimbeLink Corp. 2017. All rights reserved. 10 @GPIOGET:1 OK Drive GPIO02's state low (0V): AT@GPIOSET=2,0 OK GET GPIO02's state: AT@GPIOGET=2 @GPIOGET:0 3.6 WAKE Pins The M14A2A has the capability to enter low power states, and awakened when needed via the WAKE_IN and WAKE_OUT pins. This allows an external host controller to wake the M14A2A when needed, as well as allows the M14A2A to wake a host controller when needed. Below is a brief description of the WAKE pin's functions. Please consult the WNC M14A2A Hardware Design Guidelines document for specific information. Note: Due to the inverters placed on the Skywire NL-SW-LTE-WM14 modem, the functionality listed in the WNC M14A2A Hardware Design Guidelines document is inverted from the below information and from the functionality of the Skywire. WAKEUP_IN Pin (Host: Output, Modem: Input): - LOW: Host needs the Skywire or acknowledges it is ready following a wakeup request from the Skywire. HIGH: Host does not need the Skywire (allowing it to sleep). WAKEUP_OUT Pin (Host: Input, Modem: Output): - LOW: Skywire needs the Host or acknowledges it is ready following a wakeup request from the host. HIGH: Skywire does not need the Host (allowing it to sleep). PN 30264 rev 9 © NimbeLink Corp. 2017. All rights reserved. 11 4. Mounting Guidelines The Skywire embedded cellular modem supports multiple connection methods, the two primary methods are board to board connectors and soldering directly to the baseboard. 4.1 Board to Board connectors approach The Skywire interface calls for two, 10 pin, 2mm pitch female receptacles. There are many connector manufacturers that can be used; below is one readily available product: Manufacturer: 3M Alternate: Sullins Connector Solutions Part Number: 950510-6102-AR Alternate P/N: NPPN101BFCN-RC Typical part drawing and footprint information: PN 30264 rev 9 © NimbeLink Corp. 2017. All rights reserved. 12 4.2 Solder to Board connection approach The module can be soldered directly to a PCB. The PCB should be designed with two rows of ten, 0.8mm plated thru holes spaced 2mm apart. The two rows should be 22mm apart. See drawing for recommended footprint. Measurements are in millimeters. U.FL locations are marked with circles, X1 and X2 on top side of board, J3 is Micro SIM card slot on bottom side of board. PN 30264 rev 9 © NimbeLink Corp. 2017. All rights reserved. 13 5. Antenna Considerations 5.1 Supported Frequencies Designers should review latest M14A2A Hardware Design Guidelines to ensure the information is up to date. Band LTE Band 2 Uplink (MHz) Downlink (MHz) 1850 - 1910 1930 - 1990 LTE Band 4 1710 - 1755 2110 - 2155 LTE Band 12 699 - 716 729 - 746 Bandwidth Band LTE Band 2 1.4 MHz 3 MHz 5 MHz 10 MHz 15 MHz 20 MHz X X X X X X LTE Band 4 X X X X X X LTE Band 12 X X X X 5.2 Conducted TX Power Designers should review latest M14A2A Hardware Design Guidelines to ensure the information is up to date. Band LTE Band 2 Items Parameter Unit Min. Typ. Max. Max TX Power 10 MHz 12RBs/QPSK dBm 20.3 23 25.7 LTE Band 4 Max TX Power 10 MHz 12RBs/QPSK dBm 20.3 23 25.7 LTE Band 12 Max TX Power 10 MHz 12RBs/QPSK dBm 20.3 23 25.7 5.3 Conducted RX Sensitivity Designers should review latest M14A2A Hardware Design Guidelines to ensure the information is up to date. Band LTE Band 2 Items Parameter Unit Receive Sensitivity 10 MHz with 50 RBs LTE Band 4 Receive Sensitivity LTE Band 12 Receive Sensitivity PN 30264 rev 9 Typ. Max. dBm -96.3 -94.3 10 MHz with 50 RBs dBm -98.3 -96.3 10 MHz with 50 RBs dBm -95.3 -93.3 © NimbeLink Corp. 2017. All rights reserved. Min. 14 5.4 Primary Antenna Requirements Designers should review latest M14A2A Hardware Design Guidelines to ensure the information is up to date. PRIMARY ANTENNA REQUIREMENTS Frequency Range Bandwidth Impedance Input Power Depending on the frequency bands provided by the network operator, the customer shall use the most suitable antenna for those bands LTE B2(1900): 62MHz LTE B4(1700): 45MHz LTE B12(700a): 17MHz 50 ohm >24 dBm 5.5 Diversity Antenna Requirements Designers should review latest M14A2A Hardware Design Guidelines to ensure the information is up to date. RX DIVERSITY ANTENNA REQUIREMENTS Frequency Range Bandwidth Impedance Depending on the frequency bands provided by the network operator, the customer shall use the most suitable antenna for those bands LTE B2(1900): 62MHz LTE B4(1700): 45MHz LTE B12(700c): 17MHz 50 ohm 5.6 Recommended Antennas Type Manufacturer Primary & Diversity 1 Taoglas Part Number TG.30.8113 Note 1: U.FL to SMA adapter required. For applications not using the recommended antennas, developers must ensure that the selected antenna(s) meet certain requirements. In order to maintain FCC and carrier specific certifications the antennas cannot exceed the maximum gain levels listed here: LTE Band Max Gain (dBi) LTE B2(1900) 9.5 dBi LTE B4(1700) 6.5 dBi LTE B12(700) 10.1 dBi PN 30264 rev 9 © NimbeLink Corp. 2017. All rights reserved. 15 6. Certifications 6.1 Carrier Specific AT&T MBA NL-SW-LTE-WM14 6.2 Geography Specific Federal Communications Commission (FCC47) part 22, 24 Complies with FCC47 Part 15 Class B Radiated and Conducted Emissions 7. Federal Regulatory Licensing 7.1 Export Control Classification Number (ECCN) ECCNs are five character alpha-numeric designations used on the Commerce Control List (CCL) to identify dual-use items for export control purposes. An ECCN categorizes items based on the nature of the product, i.e. type of commodity, software, or technology and its respective technical parameters. NL-SW-LTE-WM14 (and all Skywire Modems): 5A992.c 7.2 Harmonized Tariff Schedule Code HTS Code: 8517.62.0010 8. End Product Labeling Requirements Device Uses Approved Radio: NL-SW-LTE-WM14 Contains FCC ID: NKRM14A2A and IC ID: Altair 1160. This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interferences, and (2) this device must accept any interference received, including interference that may cause undesired operation. PN 30264 rev 9 © NimbeLink Corp. 2017. All rights reserved. 16
NL-SW-LTE-WM14 价格&库存
很抱歉,暂时无法提供与“NL-SW-LTE-WM14”相匹配的价格&库存,您可以联系我们找货
