NL-SW-EVDO-S
NL-SW-EVDO-S
    NIMBELINK
    Module
    RF TXRX MOD CELL SPRINT U.FL ANT
NL-SW-EVDO-S 数据手册
Skywire™ 3G EVDO Embedded Cellular Modem Datasheet NimbeLink Corp Updated: March 2017 PN 30006 rev 6 ​© NimbeLink Corp. 2017. All rights reserved. 1 Table of Contents 1. INTRODUCTION 1.1 1.2 1.3 1.4 2. TECHNICAL SPECIFICATIONS 2.1 2.2 2.3 3. CARRIER SPECIFIC GEOGRAPHY SPECIFIC FEDERAL REGULATORY LICENSING 7​.1 7​.2 8​. PRIMARY ANTENNA REQUIREMENTS GNSS ANTENNA REQUIREMENTS RECOMMENDED ANTENNAS CERTIFICATIONS 6.1 6.2 7. BOARD TO BOARD CONNECTORS APPROACH SOLDER TO BOARD CONNECTION APPROACH ANTENNA CONSIDERATIONS 5.1 5.2 5.3 6. PWR_ON SIGNAL POWER SUPPLY REQUIREMENTS NETWORK CONNECTION STATUS LED MOUNTING GUIDELINES 4.1 4.2 5. ELECTRICAL SPECIFICATIONS MECHANICAL SPECIFICATIONS ENVIRONMENTAL SPECIFICATIONS IMPORTANT DESIGN CONSIDERATIONS 3.1 3.2 3.3 4. ORDERABLE PART NUMBERS ADDITIONAL RESOURCES PRODUCT OVERVIEW BLOCK DIAGRAM ECCN ​NUMBER HTS CODES END PRODUCT LABELING REQUIREMENTS PN 30006 rev 6 ​© NimbeLink Corp. 2016. All rights reserved. 2 1. Introduction 1.1 Orderable Part Numbers Orderable Device NL-SW-EVDO-V NL-SW-EVDO-A NL-SW-EVDO-S Operating Temperature -40 to +85˚C -40 to +85˚C -40 to +85˚C Carrier Verizon AERIS Sprint Network Type CDMA EVDO & 1xRTT CDMA EVDO & 1xRTT CDMA EVDO & 1xRTT 1.2 Additional Resources The following documents or documentation resources are referenced within this document. ● Telit’s ​DE910 Hardware User Guide 1.3 Product Overview Add robust cellular connectivity to your M2M devices without the cost, delay, and hassle of federal and carrier certifications. Extensive experience in designing and building embedded product solutions makes the NimbeLink Skywire™ embedded cellular modem the smallest on the market. It complies with the popular XBEE® interface standard and supports CDMA EV-DO Rev. A and 1xRTT communication, minimizing costs of hardware and network access. The module is designed for volume production and is intended for OEMs to embed into end equipment designs. PN 30006 rev 6 ​© NimbeLink Corp. 2016. All rights reserved. 3 1.4 Block Diagram PN 30006 rev 6 ​© NimbeLink Corp. 2016. All rights reserved. 4 2. Technical Specifications 2.1 Electrical Specifications 2.1.1 Absolute Maximum Ratings Parameter Signal Maximum Rating Main Power Supply I/O Voltage Reference VCC VREF 4.3V 5.5V 2.1.2 Recommended Ratings & Module Pin out 2.1.2.1 Pin Name Direction 1 VCC Input 2 DOUT Output Connectors J1 and J2 Description Min Typical Max If not used Main Power supply 3.5V 3.9V 4.3V Must be implemented VOH: VREF x 0.67 to VREF VIH: VREF-0.4 V to VREF Must be implemented if USB not used, No connection UART data out, I/O level tied to VREF 3 DIN Input UART data in, I/O level tied to VREF 4 GND Input Ground Pin 5 RESET_nIN Input Controls HW_SHUTDOWN input on Telit DE910-DUAL, tie low for 200mS to activate. Internally pulled up to VCC. Drive with open collector output. Assert only in an emergency as the module will not gracefully exit the cellular network when asserted. 6 VUSB Input Supply for USB interface 7 USB_D+ I/O USB differential Data + signal 8 USB_D- I/O USB differential Data + signal VOL: GND to 0.55V VIL: GND to 0.15V 0 Must be implemented VREF 4.4V Must be implemented if USB not used, No connection No connection 5V 5V No connection No connection No connection VIL: GND to 0.15V VIH: VREF-0.4 V to VREF 9 DTR Input Modem Data Terminal Ready input 10 GND Input Ground Pin 0 Must be implemented 11 GND Input Ground Pin 0 Must be implemented 12 CTS Output PN 30006 rev 6 Modem Clear to Send hardware flow control output VOL: GND to 0.55V VOH: VREF x 0.67 to VREF ​© NimbeLink Corp. 2016. All rights reserved. Tie to GND No connection 5 13 ON/nSLEEP Output 14 VREF Input 15 GND Input Signal drives the onboard LED indicating network status. OFF = Device OFF, Fast blink = Searching for Network & Not Registered, Slow Blink = Registered with full service, Permanently on = call is active. See Telit DE910-DUAL manual for additional information. Voltage reference for offboard I/O signals. This signal drives the input voltage side of an onboard buffer which converts all external I/O voltage from VREF range to 1.8V range to drive the onboard Telit DE910-DUAL modem module. 0 1.65V Ground Pin 1.8V or 3.3V 1.8V No connection 5.5V Must be implemented 0 Modem Request to Send hardware flow control input Must be implemented VIL: GND to 0.15V VIH: VREF-0.4 V to VREF 16 RTS Input 17 DIO3 I/O Programmable GPIO_03 on Telit DE910-DUAL module 0 1.8V No connection 18 DIO2 I/O Programmable GPIO_02 on Telit DE910-DUAL module 0 1.8V No connection 19 ADC1 Input 0 1.2V No connection 20 ON_OFF Input 0 1.8V Must be implemented. 2.1.2.2 ADC_IN1 input on TelitDE910-DUAL module (12bit resolution, 24.4dBm 24.4dBm 3.0 or 5.0V 5.3 Recommended Antennas Type Manufacturer Part Number Primary & Diversity Taoglas​ TG.30.8113 Taoglas​ MA.301.A.AB.001 Primary & Diversity Primary & GNSS 1 MobileMark1​ 1 PSKN3-900/1900S Note 1​: U.FL to SMA adapter required. PN 30006 rev 6 ​© NimbeLink Corp. 2016. All rights reserved. 12 6. Certifications 6.1 Carrier Specific NL-SW-EVDO-V: ​Verizon ODI Certified NL-SW-EVDO-S: ​Sprint Certified 6.2 Geography Specific Federal Communications Commission (FCC47) part 22, 24 Complies with FCC47 Part 15 Class B Radiated and Conducted Emissions 7. Federal Regulatory Licensing 7.1 Export Control Classification Number (ECCN) ECCNs are five character alpha-numeric designations used on the Commerce Control List (CCL) to identify dual-use items for export control purposes. An ECCN categorizes items based on the nature of the product, i.e. type of commodity, software, or technology and its respective technical parameters. All Skywire Modems: 5A992.c 7.2 Harmonized Tariff Schedule Code HTS Code: 8517.62.0010 8. End Product Labeling Requirements Device Uses Approved Radio: NL-SW-EVDO Contains FCC ID: RI7DE910-DUAL and IC ID: 5131A-DE910DUAL This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interferences, and (2) this device must accept any interference received, including interference that may cause undesired operation. PN 30006 rev 6 ​© NimbeLink Corp. 2016. All rights reserved. 13
NL-SW-EVDO-S 价格&库存
很抱歉,暂时无法提供与“NL-SW-EVDO-S”相匹配的价格&库存,您可以联系我们找货
