NJM13600M-TE2
NJM13600M-TE2
    JRC(⽇本无线)
    IC OP AMP TRANSCONDUCTANCE 16DMP
NJM13600M-TE2 数据手册
Designated client product This product will be discontinued its production in the near term. And it is provided for customers currently in use only, with a time limit. It can not be available for your new project. Please select other new or existing products. For more information, please contact our sales office in your region. New Japan Radio Co.,Ltd. www.njr.com NJM13600/13700 DUAL OPERATIONAL TRANSCONDUCTANCE AMPLIFIER ■ GENERAL DESCRIPTION The NJM13600/13700 consist of two current controlled trans conductance amplifiers each with differential inputs and a push pull output. The two amplifiers share common supplies but otherwise operate independently. Linearizing diodes are provided at the inputs to reduce distortion and allow higher input levels. The result is a 10 dB signal-to-noise improvement referenced to 0.5 percent THD.Controlled impedance buffers are provided which are especially designed to complement the dynamic range of the amplifiers. ■ FEATURES ● Package Outline ● Bipolar Technology ■ PACKAGE OUTLINE NJM13600M NJM13700M NJM13600D NJM13700D DIP16,DMP16 ■ PIN CONFIGURATION PIN FUNCTION 1. AMP BIAS INPUT A 9. BUFFER OUTPUT B 2. DIODE BIAS A 10. BUFFER INPUT B 3. +INPUT 11. V 4. –INPUT 12. OUTPUT B 5. OUTPUT A 13. -INPUT B 6. V 14. +INPUT B 7. BUFFER INPUT A 15. DIODE BIAS B 8. BUFFER OUTPUT A 16. AMP BIAS INPUT B - + NJM13600D,NJM13600M NJM13700D,NJM13700M ■ EQUIVALENT CIRCUIT Ver.2006-04-06 -1- NJM13600/13700 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Diode Bias Current Amp Bias Current Buffer Output Current SYMBOL + V /V VID ID IABC IO Power Dissipation PD DC Input Voltage Operating Temperature Range Storage Temperature Range VIN Topr Tstg RATINGS 36 or ±18 ±5 2 2 20 ( DIP16 ) 570 ( DMP16 ) 700 (note) + V ~V -40~+85 -40~+125 UNIT V V mA mA mA mW V ˚C ˚C ( note ) At on a ceramic PCB ( 10x20x0.635 mm ) ■ ELECTRICAL CHARACTERISTICS ( V+/V-=±15V,Ta=25˚C,IABC=500µA ) PARAMETER Input Offset Voltage (V O S ) Input Offset Voltage V O S Including Diodes Input Offset Change Input Bias Current Input Bias Current Forward Transconductance gm Tracking Peak Output Current Peak Output Current Peak Output Current Peak Output Voltage Positive Peak Output Voltage Negative Operating Current V O S Sensitivity Positive V O S Sensitivity Negative Input Offset Current CMRR Common Mode Range Cross Talk Differential Input Current Leakage Current Input Resistance Open Loop Bandwidth Slew Rate Buffer Input Current Peak Buffer Output Voltage SYMBOL VIO TEST CONDITION I ABC =5µA Diode Bias Current ,I D =500µA 5µA ≤I ABC ≤500µA IB (-20~+75˚C) gm IOP VOP I CC SVR (-20~+75˚C) R L =0,I ABC =5µA R L =0,I ABC =5µA R L =0,I ABC =500µA R L =0 (-20~+75˚C) R L =∞,5µA ≤I ABC ≤500µA R L =∞,5µA ≤I ABC ≤500µA I ABC =500µA, two circuit + ∆V O S /∆V ∆V O S /∆V IIO CMR VICM CT IID I L EAK RIN 20Hz
NJM13600M-TE2 价格&库存
很抱歉,暂时无法提供与“NJM13600M-TE2”相匹配的价格&库存,您可以联系我们找货
