NJM2265M-TE2
NJM2265M-TE2
    NJR(新日本无线)
    IC VIDEO SUPERIMPOSER 3-IN 8MP
NJM2265M-TE2 数据手册
Designated client product This product will be discontinued its production in the near term. And it is provided for customers currently in use only, with a time limit. It can not be available for your new project. Please select other new or existing products. For more information, please contact our sales office in your region. New Japan Radio Co.,Ltd. www.njr.com NJM2265 3-INPUT VIDEO SUPER IMPOSER WITH 6dB AMPLIFIER ■ GENERAL DESCRIPTION NJM2265 is 3-input, 1-output video switch with 6dB amplifier. Two inputs are provided with sink chip clamp function which adjust the DC level of video signal. The other input of transistor open base can make control of luminance signal. This video switch can be connected to TV monitor directly, as it has 6dB amplifier circuit internally. NJM2265 is a high performance video switch which is operated with 5V supply voltage. ■ FEATURES ● Wide Operating Voltage (4.75V to 13V) ● 3 Input, 1 – Output ● Internal 6 dB Amplifier Circuit ● Internal Sink Chip Clamp Function (VIN1, VIN2) ● Internal Luminance Signal Control Function (VIN3) ● Crosstalk 65dB (at 4.43MHz) ● Package Outline DIP8, DMP8, SIP8 ● Bipolar Technology ■ PACKAGE OUTLINE NJM2265D NJM2265M NJM2265L ■ APPLICATIONS ●VCR, Video Camera, AV-TV, Video Disc Player. ■ BLOCK DIAGRAM Ver.2004-02-17 -1- NJM2265 ■ ABSOLUTE MAXIMUM RATINGS PARAMETER (Ta=25°C) SYMBOL + RATINGS UNIT V mW mW mW Supply Voltage Power Dissipation V PD Operating Temperature Range Topr 15 (DIP8) 500 (DMP8) 300 (SIP8) 800 -40 to +85 Storage Temperature Range Tstg -40 to +125 °C °C (V+=5V, Ta=25±2°C) ■ ELECTRICAL CHARACTERISTICS PARAMETERS SYMBOLS TEST CONDITIONS + MIN. TYP. MAX. UNIT 4.75 - 13.0 V - 15 21.0 mA Recommended Supply Voltage V Operating Current ICC S=1=S2=S3=S4=S5=2 Voltage Gain GV Vin=1.0VP-P, 1MHz, VO / VI 5.7 6.2 6.7 dB Frequency Characteristics Gf Vin=1.0VP-P, VO(5MHz ) / V1(1MHz) -1.0 0 +1.0 dB Differential Gain DG Vin =1.0VP-P, Staircase, RL=1kΩ - 0.2 - % Differential Phase DP Vin =1.0VP-P, Staircase, RL=1kΩ - 0.1 - deg VOS S1=S2=S3=2, S4=2→1 Vin=1.0VP-P, 4.43MHz -60 0 +60 mV Crosstalk CT VO / VI Vin3 Biased (note 2) - -6.5 - dB Switch Change Voltage VCH Switch High Level Voltage 2.4 - - V Switch High Level Voltage VCL Switch Low Level Voltage - - 0.8 V Output Offset Voltage Note 1 Unless otherwise specified, tested with the following conditions. a) S1=1, S2=S3=S4=S5=2 b) S2=S4=1, S1=S3=S5=2 c) S3=S5=1, S1=S2=1, S4=1 or 2 Note 2 Tested with the following conditions. a) S1=S4=1, S2=S3=2, S5=1 and 2 b) S2=1, S1=S3=S4=2, S5=1 and 2 c) S3=1, S1=S2=S5=2, S4=1 and 2 Note 3 The Clamp Input Voltage of Vin 1 and Vin 2 is approximately (2.1×V+) / 5 (In case of V+=5V, about 2.1V) ■ SWITCH CONTROL SIGNAL-OUTPUT SIGNAL -2- SW 1 SW 2 OUTPUT SIGNAL L L Vin 1 H L Vin 2 L/H H Vin 3 Ver.2004-02-17 NJM2265 ■ TEST CIRCUIT ■ APPLICATION Oscillation Prevention It is much effective to insert LPF (Cutoff Frequency 70MHz) under light loading conditions (RL » 1kΩ) Ver.2004-02-17 -3- NJM2265 ■ APPLICATION This IC requires 1MΩ resistance between INPUT and GND pin for clamp type input since the minute current causes an unstable pin voltage. This IC requires 0.1uF capacitor between INPUT and GND, 1MΩ resistance between INPUT and GND for clamp type input at mute mode. [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -4- Ver.2004-02-17
NJM2265M-TE2 价格&库存
很抱歉,暂时无法提供与“NJM2265M-TE2”相匹配的价格&库存,您可以联系我们找货
