NJM2406F3-TE1
NJM2406F3-TE1
    JRC(⽇本无线)
    SC-70-5
    IC COMPARATOR SGL BIPO SC-88A
NJM2406F3-TE1 数据手册
Designated client product This product will be discontinued its production in the near term. And it is provided for customers currently in use only, with a time limit. It can not be available for your new project. Please select other new or existing products. For more information, please contact our sales office in your region. New Japan Radio Co.,Ltd. www.njr.com NJM2406 SINGLE COMPARATOR ■ GENERAL DESCRIPTION ■ PACKAGE OUTLINE The NJM2406 is a single comparator of ultra miniature surface mount package. The NJM2406 is suitable for small electronic equipments and hybrid circuits. ■ FEATURES ● Operating Voltage ( 2.5V to 7V ) ● Single Supply Operation ● Mounted in Ultra Miniature Package 2.0x1.25mm ( 1/8 of DMP8 package ) ● Ground Shield Plate between +Input and Output ● Ground Shield Plate between +Input and -Input ● Suitable Pin Arrangement for Application ● Package Outline SOT-23-5,SC88A ● Bipolar Technology NJM2406F NNJM2406F3 ■ PIN CONFIGURATION NJM2406F NJM2406F3 PIN FUNCTION 1. -INPUT 2. GND 3. +INPUT 4. OUTPUT + 5. V ■ EQUIVALENT CIRCUIT Ver.2012-10-31 -1- NJM2406 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Input Voltage SYMBOL V+ VID VIN Power Dissipation PD Output to Negative Supply Voltage Operating Temperature Range Storage Temperature Range VSUS Topr Tstg RATINGS 7 7 -0.3~7 (SOT-23-5 ) 200 ( SC88A ) 250 ( note1 ) 20 -40~+85 -40~+125 UNIT V V V mW V ˚C ˚C ( note1 ) On glass epoxy board. ( 50x50x1.6mm ) ■ ELECTRICAL CHARACTERISTICS ( V+=5V,Ta=25˚C ) PARAMETER Input Offset Voltage Input Offset Current Input Bias Current Input Common Mode Voltage Range Large Signal Voltage Gain Response Time Output Sink Current Output Saturation Voltage Output Leakage Current Operating Current -2- SYMBOL VIO IIO IB VICM AV tR ISINK VSAT ILEAK ICC TEST CONDITION RS=0Ω,VO=1.4V RL=15kΩ RL=5.1kΩ VIN-=1V,VIN+=0V,VO=1.5V VIN-=1V,VIN+=0V,ISINK=5mA VIN-=0V,VIN+=1V,VO=20V MIN. 0~3.5 6 200 TYP. 1 1 20 106 1.5 300 400 MAX. 7 50 250 500 1 800 UNIT mV nA nA V dB µs mA mV µA µA Ver.2012-10-31 NJM2406 ■ TYPICAL CHARACTERISTICS Ver.2012-10-31 -3- NJM2406 ■ TYPICAL CHARACTERISTICS [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -4- Ver.2012-10-31
NJM2406F3-TE1 价格&库存
很抱歉,暂时无法提供与“NJM2406F3-TE1”相匹配的价格&库存,您可以联系我们找货
