NJM2520V-TE1
NJM2520V-TE1
    JRC(⽇本无线)
    IC AUDIO SWITCH 2-IN/1-OUT 8SSOP
NJM2520V-TE1 数据手册
NJM2520 2-INPUT 1-OUTPUT AUDIO SWITCH ■ GENERAL DESCRIPTION The NJM2520 is 58kΩ input impedance 2-input 1-output audio switch. It contains two bias-type inputs and one buffer-type output. ■ FEATURES ● Operating Voltage ● Crosstalk ● Input Impedance ● 2-Input,1-Output ● Bipolar Technology ● Package Outline ■ PACKAGE OUTLINE NJM2520D NJM2520M ( +4.75V~+13V ) ( -70dB typ. ) ( 58kΩ typ. ) DIP8,DMP8,SSOP8 NJM2520V ■ PIN CONFIGURATION PIN FUNCTION 1. NC 2. Vin1 3. SW1 4. Vin2 5. NC + 6. V 7. Vout 8. GND NJM2520D NJM2520M NJM2520V Ver.2003-09-12 -1- NJM2520 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage SYMBOL + V Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS +15 ( DIP8 ) 500 ( DMP8 ) 300 ( SSOP8 ) 250 -20~+75 -40~+125 UNIT V mW ˚C ˚C ■ ELECTRICAL CHARACTERISTICS ( V+=5V,Ta=25˚C ) PARAMETER Operating Voltage Operating Current Frequency Characteristics Voltage Gain Total Harmonic Distortion Output Offset Voltage Switching Voltage Input Impedance Output Impedance SYMBOL + V ICC Gf GV THD Voff VCH VCL RI RO TEST CONDITIONS VIN=2VP-P,VO=10MHz / 100kHz VIN=2VP-P,100kHz VIN=2.5VP-P,1kHz ■ CONTROL SIGNAL-OUTPUT SIGNAL SW1 L H MIN. +4.7 -1.0 -0.5 -35 2.4 - TYP. 8.5 0 0 0.01 0 58 10 MAX. +13.0 11.0 +1.0 +0.5 +35 0.8 - UNIT V mA dB dB % mV V V kΩ Ω ■ TEST CIRCUIT OUTPUT SIGNAL VIN1 VIN2 ■ APPLICATION Oscillation Prevention on light loading conditions Recommended under circuit [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -2- Ver.2003-09-12
NJM2520V-TE1 价格&库存
很抱歉,暂时无法提供与“NJM2520V-TE1”相匹配的价格&库存,您可以联系我们找货
