NJM3777E3-TE2
NJM3777E3-TE2
    NJR(新日本无线)
    IC STEPPER MOTOR DVR DUAL 24EMP
NJM3777E3-TE2 数据手册
NJM3777 DUAL STEPPER MOTOR DRIVER ■ GENERAL DESCRIPTION ■ PACKAGE OUTLINE The NJM3777 is a switch-mode (chopper), constant-current driver with two channels: one for each winding of a two-phase stepper motor. The NJM3777 is equipped with a Disable input to simplify half-stepping operation. The NJM3777 contains a clock oscillator, which is common for both driver channels, a set of comparators and flip-flops implementing the switching control, and two output H-bridges, including recirculation NJM3777E3 diodes. Voltage supply requirements are + 5 V for logic and + 10 to + 45 V for the motor. Maximum output current is 900mA per channel. ■ FEATURES • Dual chopper driver • 900 mA continuous output current per channel • Digital filter on chip eliminates external filtering components • Package EMP24(Batwing) ■ BLOCK DIAGRAM Phase 1 Dis1 VR1 E1 C1 NJM3777 VCC – V CC + R S Q M A1 M B1 Logic V MM1 + VMM2 – M B2 Logic M A2 RC + – Phase 2 Figure 1. Block diagram Dis 2 VR2 C2 S R GND Q E2 NJM3777 ■ PIN CONFIGURATION NC 1 24 NC MB1 2 23 MB2 E1 3 22 E2 MA1 4 21 MA2 20 VMM2 19 GND 18 GND VR1 8 17 VR2 C1 9 16 C2 Phase1 10 15 Phase2 Dis1 11 14 Dis2 RC 12 13 Vcc VMM1 5 GND 6 GND 7 NJM 3777E3 Figure 2. Pin configuration ■ PIN DESCRIPTION EMP 1 2 3 4 5 6, 7, 18, 19 Symbol NC MB1 E1 MA1 VMM1 GND 8 9 VR1 C1 10 Phase1 11 Dis1 12 RC 13 14 VCC Dis2 15 Phase2 16 C2 17 20 21 22 23 24 VR2 VMM2 MA2 E2 MB2 NC Description Not connected Motor output B, channel 1. Motor current flows from MA1 to MB1 when Phase1 is HIGH. Common emitter, channel 1. This pin connects to a sensing resistor RS to ground. Motor output A, channel 1. Motor current flows from MA1 to MB1 when Phase1 is HIGH. Motor supply voltage, channel 1, +10 to +40 V. VMM1 and VMM2 should be connected together. Ground and negative supply. Note: these pins are used thermally for heat-sinking. Make sure that all ground pins are soldered onto a suitably large copper ground plane for efficient heat sinking. Reference voltage, channel 1. Controls the comparator threshold voltage and hence the output current. Comparator input channel 1. This input senses the instantaneous voltage across the sensing resistor, filtered by the internal digital filter or an optional external RC network. Controls the direction of motor current at outputs MA1 and MB1. Motor current flows from MA1 to MB1 when Phase1 is HIGH. Disable input for channel 1. When HIGH, all four output transistors are turned off, which results in a rapidly decreasing output current to zero. Clock oscillator RC pin. Connect a 12 kohm resistor to VCC and a 4 700 pF capacitor to ground to obtain the nominal switching frequency of 23.0 kHz and a digital filter blanking time of 1.0 µs. Logic voltage supply, nominally +5 V. Disable input for channel 2. When HIGH, all four output transistors are turned off, which results in a rapidly decreasing output current to zero. Controls the direction of motor current at outputs MA2 and MB2. Motor current flows from MA2 to MB2 when Phase2 is HIGH. Comparator input channel 2. This input senses the instantaneous voltage across the sensing resistor, filtered by the internal digital filter or an optional external RC network. Reference voltage, channel 2. Controls the comparator threshold voltage and hence the output current. Motor supply voltage, channel 2, +10 to +40 V. VMM1 and VMM2 should be connected together. Motor output A, channel 2. Motor current flows from MA2 to MB2 when Phase2 is HIGH. Common emitter, channel 2. This pin connects to a sensing resistor RS to ground. Motor output B, channel 2. Motor current flows from MA2 to MB2 when Phase2 is HIGH. Not connected NJM3777 ■ FUNCTIONAL DESCRIPTION Each channel of the NJM3777 consists of the following sections: an output H-bridge with four transistors and four recirculation diodes, capable of driving up to 800 mA continuous current to the motor winding, a logic section that controls the output transistors, an S-R flip-flop, and a comparator. The clock-oscillator is common to both channels. Constant current control is achieved by switching the output current to the windings. This is done by sensing the peak current through the winding via a current-sensing resistor RS, effectively connected in series with the motor winding. As the current increases, a voltage develops across the sensing resistor, which is fed back to the comparator. At the predetermined level, defined by the voltage at the reference input VR, the comparator resets the flipflop, which turns off the upper output transistor. The turn-off of one channel is independent of the other channel. The current decreases until the clock oscillator triggers the flip-flops of both channels simultaneously, which turns on the output transistors again, and the cycle is repeated. To prevent erroneous switching due to switching transients at turn-on, the NJM3777 includes a digital filter. The clock oscillator provides a blanking pulse which is used for digital filtering of the voltage transient across the current sensing resistor during turn-on. The current paths during turn-on, turn-off and phase shift are shown in figure 3. V MM 1 2 3 RS Motor Current 1 2 3 Fast Current Decay Slow Current Decay Figure 3. Output stage with current paths during turn-on, turn-off and phase shift. Time NJM3777 ■ ABSOLUTE MAXIMUM RATINGS Parameter Voltage Logic supply Motor supply Logic inputs Analog inputs Current Motor output current Logic inputs Analog inputs Temperature Operating junction temperature Storage temperature Power Dissipation (Package Data) Power dissipation at TGND = +25°C Power dissipation at TGND = +125°C Pin No. Symbol Min Max Unit 13 5, 20 10, 11, 14, 15 8, 9, 16, 17 VCC VMM VI VA 0 0 -0.3 -0.3 7 45 6 VCC V V V V 2, 4, 21, 23 10, 11, 14, 15 8, 9, 16, 17 IM II IA -900 -10 -10 +900 - mA mA mA TJ TS -40 -55 +150 +150 °C °C PD PD - 5 2 W W Min 4.75 10 -800 -20 2 Typ 5 12 ■ RECOMMENDED OPERATING CONDITIONS Parameter Logic supply voltage Motor supply voltage Output emitter voltage Motor output current Operating junction temperature Rise and fall time logic inputs Oscillator timing resistor Symbol VCC VMM VE IM TJ tr,, tf RT Max 5.25 40 1.0 +800 +125 2 20 Unit V V V mA °C µs kΩ | V MA – V MB | Phase 1 Dis1 VR1 10 11 8 C1 E1 9 3 t on NJM3777 t off 50 % VCC I CC – V CC 13 + R S Q Logic 4 M A1 2 M B1 5 VMM1 20 V MM2 23 M B2 21 M A2 t VE ( I M ) td 12 kΩ + RT – Logic I RC RC I MM IM V CH I OL 12 + – S R Q 4 700 pF VCC CT 15 Phase 2 II I IH I IL IR IA 14 6, 7, 18, 19 22 C2 GND E2 V t tb RC IC IA VM V V V 16 VCH VI IH 17 Dis 2 V R2 VA VRC VE C V V MA V MM V IL R A RS t 1 fs = t + t on off Figure 4. Definition of symbols D= ton ton + t off Figure 5. Definition of terms NJM3777 ■ ELECTRICAL CHARACTERISTICS Electrical characteristics over recommended operating conditions, unless otherwise noted. - 20°C ≤ Tj ≤ + 125°C. Parameter Symbol General Supply current Supply current Total power dissipation ICC ICC PD Total power dissipation PD Thermal shutdown junction temperature Turn-off delay td Logic Inputs Logic HIGH input voltage Logic LOW input voltage Logic HIGH input current Logic LOW input current VIH VIL IIH IIL Analog Inputs Threshold voltage Input current |VC1—VC2| mismatch VCH IA VCdiff Motor Outputs Lower transistor saturation voltage Lower transistor leakage current Lower diode forward voltage drop Upper transistor saturation voltage Upper transistor leakage current Upper diode forward voltage drop Chopper Oscillator Chopping frequency Digital filter blanking time fs tb Conditions Min Typ Max Unit Note 4. Dis1= Dis2= HIGH. VMM= 24 V, IM1= IM2= 650 mA. Notes 2, 3, 4. VMM= 24 V, IM1= 800 mA, IM2= 0 mA. Notes 2, 3, 4. - 85 7 2.9 99 10 3.4 mA mA W - 2.3 2.7 W - 160 1.1 2.0 °C µs 2.0 -0.2 -0.1 0.6 20 - V V µA mA 480 - 500 500 5 520 20 mV µA mV IM = 500 mA VMM=41 V,Dis1= Dis2= HIGH. IM = 500 mA IM = 500 mA. VMM=41 V, Dis1= Dis2= HIGH. IM = 500 mA. - 0.5 1.2 1.4 1.3 0.8 50 1.3 1.6 50 1.5 V µA V V µA V CT = 4 700 pF, RT = 12 kohm CT = 4 700 pF. Note 3. 21.5 - 23.0 1.0 24.5 - kHz µs dVC/dt ≥ 50 mV/µs, IM = 100 mA. Note 3. VI = 2.4 V VI = 0.4 V VR= 5 V VR= 5 V ■ THERMAL CHARACTERISTICS Parameter Thermal resistance Symbol RthJ-GND RthJ-A Conditions Note 2. Min - Notes 1. All voltages are with respect to ground. Currents are positive into, negative out of specified terminal. 2. All ground pins soldered onto a 20 cm2 PCB copper area with free air convection, TA = + 25° C. 3. Not covered by final test program. 4. Switching duty cycle D = 30 %, fs = 23.0 kHz. Typ 13 42 Max - Unit °C/W °C/W NJM3777 ■ APPLICATIONS INFORMATION Current control The regulated output current level to the motor winding is determined by the voltage at the reference input and the value of the sensing resistor, RS. The peak current through the sensing resistor (and the motor winding) can be expressed as: IM,peak = 0.1•VR / RS [A] With a recommended value of 0.5 ohm for the sensing resistor RS, a 2.5 V reference voltage will produce an output current of approximately 500 mA. RS should be selected for maximum motor current. Be sure not to exceed the absolute maximum output current which is 900 mA. Chopping frequency, winding inductance and supply voltage also affect the current, but to much less extent. For accurate current regulation, the sensing resistor should be a 0.5 - 1.0 W precision resistor, i. e. less than 1% tolerance and low temperature coefficient. V MM +5 V + 0.1 µF 0.1 µF 13 V 10 5 V CC 20 V MM1 MM2 Phase 1 11 Dis1 8 V R1 15 M A1 4 M B1 2 NJM3777E3 21 M A2 Phase 2 14 Dis 2 17 V R2 RC GND 12 +5 V 12 kΩ 6, 7, 18, 19 23 M B2 C1 E1 C2 3 9 10 µF STEPPER MOTOR E2 16 22 Pin numbers refer to EMP package. 4 700 pF RS RS 0.47 Ω 0.47 Ω GND (VCC ) GND (VMM ) Figure 6. Typical stepper motor driver application with NJM3777 V MM V CC (+5 V) + 0.1 F 0.1 F 13 4 13 V DD D0 V Sign1 3 DA1 2 10 To P +2.5V Dis1 8 V R1 1 V Ref Sign2 18 15 Phase 14 VSS 17 DA2 19 MM2 MA1 4 MB1 2 NJM3777E3 NJU39612E2 14 A0 5 WR 16 CS 20 RESET 20 V MM1 Phase1 11 6 D7 5 V CC MA2 2 Dis2 17 V R2 RC GND 12 +5 V 12 k‰ 6, 7, 18, 19 MB2 C1 9 E1 3 C2 16 21 23 E2 STEPPER MOTOR 22 Pin numbers refer to EMP package. 4700 pF GND (VCC ) 10 F 0.47 ‰ RS 0.47 ‰ Figure 7. Typical microstepping application with NJU39612 RS GND (V MM) NJM3777 Current sense filtering At turn-on a current spike occurs, due to the recovery of the recirculation diodes and the capacitance of the motor winding. To prevent this spike from reseting the flip-flops through the current sensing comparators, the clock oscillator generates a blanking pulse at turn-on. The blanking pulse pulse disables the comparators for a short time. Thereby any voltage transient across the sensing resistor will be ignored during the blanking time. Choose the blanking pulse time to be longer than the duration of the switching transients by selecting a proper CT value. The time is calculated as: tb = 210 • CT [s] As the CT value may vary from approximately 2 200 pF to 33 000 pF, a blanking time ranging from 0.5 µs to 7 µs is possible. Nominal value is 4 700 pF, which gives a blanking time of 1.0 µs. As the filtering action introduces a small delay, the peak value across the sensing resistor, and hence the peak motor current, will reach a slightly higher level than what is defined by the reference voltage. The filtering delay also limits the minimum possible output current. As the output will be on for a short time each cycle, equal to the digital filtering blanking time plus additional internal delays, an amount of current will flow through the winding. Typically this current is 1-10 % of the maximum output current set by RS. When optimizing low current performance, the filtering may be done by adding an external low pass filter in series with the comparator C input. In this case the digital blanking time should be as short as possible. The recommended filter component values are 1 kohm and 820 pF. Lowering the switching fre- quency also helps reducing the minimum output current. To create an absolute zero current, the Dis input should be HIGH. Switching frequency The frequency of the clock oscillator is set by the timing components RT and CT at the RC-pin. As CT sets the digital filter blanking time, the clock oscillator frequency is adjusted by RT. The value of RT is limited to 2 - 20 kohm. The frequency is approximately calculated as: fs = 1 / ( 0.77 • RT • CT) Nominal component values of 12 kohm and 4 700 pF results in a clock frequency of 23.0 kHz. A lower frequency will result in higher current ripple, but may improve low level linearity. A higher clock frequency reduces current ripple, but increases the switching losses in the IC and possibly the iron losses in the motor. Phase inputs A logic HIGH on a Phase input gives a current flowing from pin MA into pin MB. A logic LOW gives a current flow in the opposite direction. A time delay prevents cross conduction in the H-bridge when changing the Phase input. Phase 1 Dis 1 Phase 2 Dis 2 V R1 80 Thermal resistance [°C/W] 140% 100% V R2 70 140% 100% 60 I MA1 140% 100% 50 24-pin EMP 40 –100% –140% I MA2 30 140% 100% 20 5 10 15 20 25 30 35 PCB copper foil area [cm 2 ] EMP package Figure 8. Typical thermal resistance vs. PC Board copper area and suggested layout –100% –140% Full step mode Half step mode Figure 9. Stepping modes Modified half step mode NJM3777 Dis (Disable) inputs A logic HIGH on the Dis inputs will turn off all four transistors of the output H-bridge, which results in a rapidly decreasing out- put current to zero. VR (Reference) inputs The Vref inputs of the NJM3777 have a voltage divider with a ratio of 1 to 10 to reduce the external reference voltage to an adequate level. The divider consists of closely matched resistors. Nominal input reference voltage is 5 V. Interference Due to the switching operation of NJM3777, noise and transients are generated and might be coupled into adjacent circuitry. To reduce potential interference there are a few basic rules to follow: • Use separate ground leads for power ground (the ground connection of RS), the ground leads of NJM3777, and the ground of external analog and digital circuitry. The grounds should be connected together close to the GND pins of NJM3777. • Decouple the supply voltages close to the NJM3777 circuit. Use a ceramic capacitor in parallel with an electrolytic type for both VCC and VMM. Route the power supply lines close together. • Do not place sensitive circuits close to the driver. Avoid physical current loops, and place the driver close to both the motor and the power supply connector. The motor leads could preferably be twisted or shielded. Motor selection The NJM3777 is designed for two-phase bipolar stepper motors, i.e. motors that have only one winding per phase. The chopping principle of the NJM3777 is based on a constant frequency and a varying duty cycle. This scheme imposes certain restrictions on motor selection. Unstable chopping can occur if the chopping duty cycle exceeds approximately 50 %. See figure 5 for definitions. To avoid this, it is necessary to choose a motor with a low winding resistance and inductance, i.e. windings with a few turns. It is not possible to use a motor that is rated for the same voltage as the actual supply voltage. Only rated current needs to be considered. Typical motors to be used together with the NJM3777 have a voltage rating of 1 to 6 V, while the supply voltage usually ranges from 10 to 40 V. Low inductance, especially in combination with a high supply voltage, enables high stepping rates. However, to give the same torque capability at low speed, the reduced number of turns in the winding in the low resistive, low inductive motor must be compensated by a higher current. A compromise has to be made. Choose a motor with the lowest possible winding resistance and inductance, that still gives the required torque, and use as high supply voltage as possible, without exceeding the maximum recommended 40 V. Check that the chopping duty cycle does not exceed 50 % at maximum current. Heat sinking NJM3777 is a power IC, packaged in a power EMP package. The ground leads of the package (the batwing) are thermally connected to the chip. External heatsinking is achieved by soldering the ground leads onto a copper ground plane on the PCB. Maximum continuous output current is heavily dependent on the heatsinking and ambient temperature. Consult figures 8, 10 and 11to determine the necessary heat- sink, or to find the maximum output current under varying conditions. A copper area of 20 cm2 (approx. 1.8” x 1.8”), copper foil thickness 35 µm on a 1.6 mm epoxy PCB, permits the circuit to operate at 2 x 450 mA output current, at ambient temperatures up to 85° C. Thermal shutdown The circuit is equipped with a thermal shutdown function that turns the outputs off at a chip (junction) temperature above 160° C. Normal operation is resumed when the temperature has decreased. Programming Figure 9 shows the different input and output sequences for full-step, half-step and modified halfstep operations. NJM3777 Full-step mode Both windings are energized at all the time with the same current, IM1 = IM2. To make the motor take one step, the current direction (and the magnetic field direction) in one phase is reversed. The next step is then taken when the other phase current reverses. The current changes go through a sequence of four different states which equal four full steps until the initial state is reached again. Half-step mode In the half-step mode, the current in one winding is brought to zero before a complete current reversal is made. The motor will then have taken two half steps equalling one full step in rotary movement. The cycle is repeated, but on the other phase. A total of eight states are sequenced until the initial state is reached again. Half-step mode can overcome potential resonance problems. Resonances appear as a sudden loss of torque at one or more distinct stepping rates and must be avoided so as not to loose control of the motor´s shaft position. One disadvantage with the half-step mode is the reduced torque in the half step positions, in which current flows through one winding only. The torque in this position is approximately 70 % of the full step position torque. Modified half-step mode The torque variations in half step mode will be elimi-nated if the current is increased about 1.4 times in the halfstep position. A constant torque will further reduce resonances and mechanical noise, resulting in better performance, life expectancy and reliability of the mechanical system. Modifying the current levels must be done by bringing the reference voltage up (or down) from its nominal value correspondingly. This can be done by using DACs or simple resistor divider networks. The NJM3777 is designed to handle about 1.4 times higher current in one channel on mode, for example 2 x 600 mA in the full-step position, and 1 x 800 mA in the half-step position. NJM3777 ■ TYPICAL CHARACTERISTICS Maximum allowable power dissipation [W] PD (W) 5 3.0 1.2 m 3 pe ra ch tu re ture T 2 1.0 nel an e ch 1.0 pera tem wo te pin n an nt ing 2.0 els bie on Batw Am 4 0 -25 0 0.40 0.60 0.80 25 EMP package I M (A) Figure 10. Power dissipation vs. motor current.Ta = 25°C 0.6 0.2 0 50 75 100 125 150 Temperature [°C] 0.20 0.8 0.4 1 on On 0 VCE Sat (V) 6 0 0 All ground pins soldered onto a 20 cm2 PCB copper area with free air convection. VCE Sat (V) 1.2 1.0 1.0 1.0 0.8 0.8 0.8 0.6 0.6 0.6 0.4 0.4 0.4 0.2 0.2 0.2 0.40 0.60 0.80 I M (A) Figure 13. Typical lower diode voltage drop vs. recirculating current 0.80 Vd, ud (V) 1.2 0.20 0.60 I M (A) 1.2 0 0.40 Figure 11. Maximum allowable power Figure 12. Typical lower transistor saturation voltage vs. output current dissipation Vd, ld (V) 0 0.20 0 0 0 0.20 0.40 0.60 0.80 I M (A) Figure 14. Typical upper transistor saturation voltage vs. output current 0 0.20 0.40 0.60 0.80 I M (A) Figure 15. Typical upper diode voltage drop vs. recirculating current The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights.
NJM3777E3-TE2 价格&库存
很抱歉,暂时无法提供与“NJM3777E3-TE2”相匹配的价格&库存,您可以联系我们找货
