NJM4559M-TE1
NJM4559M-TE1
    JRC(⽇本无线)
    IC OP AMP DUAL BIPO 8DMP
NJM4559M-TE1 数据手册
  NJM4558/4559  DUAL OPERATIONAL AMPLIFIER     ■ GENERAL DESCRIPTION ■ PACKAGE OUTLINE The NJM4558/4559 integrated circuit is a dual high-gain   operational amplifier internally compensated and constructed on a single silicon chip using an advanced epitaxial process.   Combining the features of the NJM741 with the close parameter matching and tracking of a dual device on a monolithic chip results in unique performance characteristics. Excellent channel separation allows the use of the dual device in single NJM741 operational amplifier applications providing density. It is especially well suited for applications in differential-in, differential-out as well as in potentiometric amplifiers and where gain and phase matched channels are mandatory.   ( Top View  )    1  8  ■ FEATURES A  ● Operating Voltage 2  7  ● High ( ±4V~±18V ) B  3  6  Voltage Gain ( 100dB typ. )   4  5  ● High Input Resistance ( 5MΩ typ. )   ● Bipolar Technology   ● Package Outline DIP8, DMP8, SIP8   SOP8 JEDEC 150mil (only NJM4558),   SSOP8 (only NJM4558)     ■ PIN CONFIGURATION             NJM4558D, NJM4558M, NJM4558E, NJM4558V NJM4558L NJM4559L NJM4559D, NJM4559M   ■ EQUIVALENT CIRCUIT ( 1/2 Shown )   Ver.2013-11-05     NJM4558D   NJM4559D   ( DIP8 )     1 2 3 4 5 6 7 8    NJM4558M NJM4559M ( DMP8 )   NJM4558V ( SSOP8 )   8. V+   NJM4558L  NJM4559L  ( SIP8 )     NJM4558E   ( SOP8 )   PIN FUNCTION   1. A OUTPUT   2. A - INPUT   3. A +INPUT   4. V-   5. B +INPUT   6. B - INPUT   7. B OUTPUT   A B - 1 -  NJM4558/4559 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C )   PARAMETER   SYMBOL RATINGS UNIT V+/V- Supply Voltage   Differential Input Voltage   Input Voltage   ± 18 V ± 30 V ± 15 ( note1 ) V ( DIP8 ) 500       ( DMP8 ) 300 mW Power Dissipation   PD ( SOP8 ) 300 ( SSOP8 ) 250   ( SIP8 ) 800 Operating Temperature Range Topr -40~+85 ˚C Storage Temperature Range   Tstg -40~+125 ˚C ( note1 ) For supply voltage less than ±15V,the absolute maximum input voltage is equal to the supply voltage.   VID VIC ■ ELECTRICAL CHARACTERISTICS PARAMETER   TEST CONDITION MIN. Input Offset Voltage   VIO RS≤10kΩ - Input Offset Current   IIO       - Input Bias Current   Input Resistance   IB RIN 0.3 Large Signal Voltage Gain   Maximum Output Voltage Swing 1   Maximum Output Voltage Swing 2   Input Common Mode Voltage Range   AV VOM1 VOM2 VICM RL≥2kΩ,VO=±10V RL≥10kΩ RL≥2kΩ Common Mode Rejection Ratio   CMR RS≤10kΩ 70 Supply Voltage Rejection Ratio   SVR RS≤10kΩ 76.5 Operating Current     SYMBOL ICC     86 ± 12 ± 10 ± 12 - ( V+/V-=±15V,Ta=25˚C )   TYP.   MAX. UNIT 6 mV 0.5   5  200 nA 25   500 nA 5  MΩ 100   dB ± 14   V ± 13   V 14   V 90   dB dB 90   3.5   5.7 mA   Slew Rate     NJM4558   SR   NJM4559   SR Equivalent Input Noise Voltage (note2)   Gain Bandwidth Product   NJM4558   NJM4559   VNI GB                   -  1  -  V/µs   - 2  - V/µs RIAA,RS=2.2kΩ,30kHz LPF - 1.4   - µVrms               3  6          MHz MHz (note2) In regard to Noise Standard, NJRC is preparing for special D Rank type products (VNI=1.8µV max.) except for SSOP package.                   -2- Ver.2013-11-05  + ■ TYPICAL CHARACTERISTICS                 - V /V =±15V, RL=2kΩ, Ta=25ºC 120 100 Open Loop Voltage Gain vs. Frequency  NJM4559 80 60     NJM4558 40 20 0 1 10 100  1k    10 k  100k Frequency f [Hz]        1M 10M    Maximum Output Voltage Swing vs.  Load Resistance                + 30    - V /V =±15V, Ta=25ºC +      - V /V =±15V, RL=2kΩ, Ta=25ºC 30     25 NJM4559 28  20 26  24  15 22  NJM4558   10 20  18  5 16  0 14  12  100  1 1 k  Load Resistance RL [Ω]  10 1k  100 10 k  100 k  1M  Frequency f [Hz]  10k  Equivalent Input Noise Voltage vs. Frequency  +      - V /V =±15V, RS=50Ω, AV=60dB, Ta=25ºC 1000 Operating Current vs. Temperature        + 9  -      V /V =±15V 8  100 7  6  5  10 4  3  2  1 1  0    -50 1   -25 0 25 50 75 100 Ambient Temperature Ta [ºC]  100  10 1k  Frequency f [Hz]  125  Maximum Output Voltage Swing vs. Temperature  + -          V /V =±15V, RL=10kΩ   15 Ver.2013-11-05   -9 +VOM NJM4558/4559  Maximum Output Voltage Swing vs. Frequency  14 -10 13 -11 12 -12 -12 11 -13 -13 -VOM -14 10 -50 -25 0 25 50  75  100  Ambient Temperature Ta [ºC]  -14 125   - 3 -      NJM4558/4559   - 4 -  Input Bias Current vs. Temperature  ■ TYPICAL CHARACTERISTICS   + Input Offset Voltage vs. temperature        +                           - 40    V /V =±15V 2  35 1.5  30 1  25 0.5  20 0  15 -0.5  10 -1  5 -50 -1.5  -25 -25 0 25 50 75 100 25 50 100  125  75    125  Ambient Temperature Ta [ºC]  Operating Current vs. Operating Voltage      Ta=25ºC 9 8 Maximum Output Voltage Swing vs. Operating Voltage           RL=2kΩ , Ta=25ºC 15  10  0 Ambient Temperature Ta [ºC]  -2  -50 - V /V =±15V 45 7   6 5      +VOM 4 5  3 2 0  1 -5  -10  -15  ±6  0 0      -VOM ±8  ±10  ±12  ±14  Operating Voltage V+/V- [V]  ±16 ±2 ±4 ±6 ±8 ±10±12±14±16±18  Operating Voltage V+/V- [V]        [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights.     Ver.2013-11-0
NJM4559M-TE1 价格&库存
很抱歉,暂时无法提供与“NJM4559M-TE1”相匹配的价格&库存,您可以联系我们找货
