Designated client product
This product will be discontinued its production in the near term.
And it is provided for customers currently in use only, with a time limit.
It can not be available for your new project. Please select other new or
existing products.
For more information, please contact our sales office in your region.
New Japan Radio Co.,Ltd.
www.njr.com
NJM4560
DUAL OPERATIONAL AMPLIFIER
■ GENERAL DESCRIPTION
The NJM4560 integrated circuit is a high-gain, wide
bandwidth, dual operational amplifier capable of driving 20V
peak-to-peak into 400Ω loads. The NJM4560 combines
many of the features of the NJM4558 as well as providing the
capability of wider bandwidth, and higher slew rate make the
NJM4560 ideal for active filters, data and telecommunications,
and many instrumentation applications. The availability of the
NJM4560 in the surface mounted micro-package allows the
NJM4560 to be used in critical applications requiring very high
packing densities.
■ FEATURES
● Operating Voltage
● Wide Gain Bandwidth Product
● Slew Rate
● Package Outline
● Bipolar Technology
■ PACKAGE OUTLINE
NJM4560D
( DIP8)
NJM4560M
( DMP8 )
NJM4560E
( SOP8 )
NJM4560L
( SIP8 )
( ±4V~±18V )
( 10MHz typ. )
( 4V/μs typ. )
DIP8, DMP8, SIP8, SOP8 JEDEC 150mil
■ PIN CONFIGURATION
PIN FUNCTION
1. A OUTPUT
2. A - INPUT
3. A +INPUT
4. V5. B +INPUT
6. B - INPUT
7. B OUTPUT
8. V+
( Top View )
1
8
A
2
A
B
3
4
B
7
6
5
NJM4560D, NJM4560M, NJM4560E
1
2
3
4
5
6
7
8
NJM4560L
■ EQUIVALENT CIRCUIT ( 1/2 Shown )
V+
- INPUT
+ INPUT
OUTPUT
V-
Ver.2011-12-12
-1-
NJM4560
■ ABSOLUTE MAXIMUM RATINGS
( Ta=25˚C )
PARAMETER
Supply Voltage
Differential Input Voltage
Input Voltage
SYMBOL
V+/VVID
VIC
Power Dissipation
PD
Operating Temperature Range
Storage Temperature Range
Topr
Tstg
RATINGS
± 18
± 30
± 15 ( note )
( DIP8 ) 500
( DMP8 ) 300
( SOP8 ) 300
( SIP8 ) 800
-40~+85
-40~+125
UNIT
V
V
V
mW
˚C
˚C
( note ) For supply voltage less than ±15V,the absolute maximum input voltage is equal to the supply voltage.
■ ELECTRICAL CHARACTERISTICS
( Ta=25˚C,V+/V-=±15V )
PARAMETER
Input Offset Voltage
Input Offset Current
Input Bias Current
Input Resistance
Large Signal Voltage Gain
Maximum Output Voltage Swing 1
Maximum Output Voltage Swing 2
Input Common Mode Voltage Range
Common Mode Rejection Ratio
Supply Voltage Rejection Ratio
Operating Current
Slew Rate
Equivalent Input Noise Voltage
-2-
SYMBOL
VIO
IIO
IB
RIN
AV
VOM1
VOM2
VICM
CMR
SVR
ICC
SR
GB
VNI
TEST CONDITION
RS≤10kΩ
RL≥2kΩ,VO=±10V
RL≥2kΩ
IO=25mA
RS≤10kΩ
RS≤10kΩ
RIAA,RS=2kΩ,30kHz LPF
MIN.
0.3
86
± 12
± 10
± 12
70
76.5
TYP.
0.5
5
40
5
100
± 14
± 11.5
± 14
90
90
4.3
4
10
1.2
MAX.
6
200
500
5.7
UNIT
mV
nA
nA
MΩ
dB
V
V
V
dB
dB
mA
V/μs
MHz
μVrms
Ver.2011-12-12
NJM4560
■ TYPICAL CHARACTERISTICS
Ver.2011-12-12
-3-
NJM4560
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
-4-
Ver.2011-12-12
很抱歉,暂时无法提供与“NJM4560L”相匹配的价格&库存,您可以联系我们找货
