NJM592M8-TE1
NJM592M8-TE1
    JRC(⽇本无线)
    SOIC-8
    IC VIDEO AMP BIPO 8DMP
NJM592M8-TE1 数据手册
NJM592 VIDEO AMPLIFIER ■ GENERAL DESCRIPTION The NJM592 is a video amplifier of differential input and differential output. The NJM592 is suitable for a preamplifier of memory equipment and video and pulse signal amplifer. ■ FEATURES ● Wide Fregueney Range (40MHz, 90MHz typ.) ● Differential Input, Differential Output. ● With Gain Select Terminal ● Package Outline DIP8/14, DMP8/14, SSOP8/14. ● Bipolar Technology ■ PACKAGE OUTLINE NJM592D NJM592M NJM592D8 NJM592M8 NJM592V8 NJM592V ■ PIN CONFIGURATION NJM592D NJM592M NJM592V NJM592D8 NJM592M8 NJM592V8 ■ EQUIVALENT CIRCUIT Ver.2004-02-17 -1- NJM592 ■ ABSOLUTE MAXIMUM RATINGS PARAMETER (Ta=25°C) SYMBOL RATINGS UNIT Supply Voltage + - V /V ±8 V Differential Input Voltage VDIEF ±5 V Common Mode Input Voltage VCM ±6 V IO 10 mA Operating Temperature Range Topr -40 to +85 °C Storage Temperature Range Tstg Power Dissipation PD Output Current -2- -40 to +125 °C (DIP14) 500 mW (DMP14) 300 mW (SSOP14) 300 mW (DIP8) 500 mW (DMP8) 300 mW (SSOP8) 250 mW Ver.2004-02-17 NJM592 (Ta=25°C, V+=±6V, VCM=0) ■ ELECTRICAL CHARACTERISTICS PARAMETER Differential Voltage Gain 1 (note 1) TEST CONDITION R1=2kΩ, VOUT=3VP-P Differential Voltage Gain 2 (note 2, 4) MIN. TYP. MAX. 250 400 600 80 100 120 UNIT V/V Bandwidth (note 1) - 40 - Bandwidth 2 Gain 2 (note 2, 4) - 90 - - 10.5 - - 4.5 - 7.5 - Propagation Delay 2 Gain 2 (note 2, 4) - 6.0 - Input Resistance Gain 1 (note1) - 4.0 - Input Resistance Gain 2 (note 2, 4) - 30 - Input Capacitance Gain 2 (note2, 4) - 2.0 - pF Input Offset Current - 0.4 5.0 µA Rise Time Gain 1 (note 1) VOUT =1VP-P Rise Time Gain 2 (note 2, 4) Propagation Delay 1 Gain 1 (note 1) VOUT =1VP-P Input Bias Current Input Noise Voltage BW=1kHz to 10MHz Input Voltage Range Common Mode Rejection Radio Gain 2 (note 4) VCM=±1V, f
NJM592M8-TE1 价格&库存
很抱歉,暂时无法提供与“NJM592M8-TE1”相匹配的价格&库存,您可以联系我们找货
