NJM741M-TE2
NJM741M-TE2
    JRC(⽇本无线)
    IC OP AMP SGL GEN PURP 8DMP
NJM741M-TE2 数据手册
NJM741 SINGLE GENERAL PURPOSE OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM741 is a high performance Monolithic Operational Amplifier constructed using the New JRC Planar epitaxial process.It is intended for a wide range of analog applications.High common mode voltage range and absence of latch-up tendencies make the NJM741 ideal for use as a voltage follower.The high gain and wide range of operating voltage provides superior performance in integrator,summing amplifier,and general feedback applications. ■ FEATURES ● Operating Voltage ● Single Supply ● With VIO Trim Terminal ● Package Outline ● Bipolar Technology ■ PACKAGE OUTLINE NJM741D NJM741M ( ±3V~±18V ) DIP8,DMP8 ■ PIN CONFIGURATION NJM741D NJM741M PIN FUNCTION 1.VOS Trim 2.-INPUT 3.+INPUT 4.V 5.VOS Trim 6.OUTPUT + 7.V 8.NC ■ EQUIVALENT CIRCUIT Ver.2003-03-18 -1- NJM741 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Input Voltage Differential Input Voltage SYMBOL + V /V VIC VID Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS ± 18 ± 15 ( note ) ± 30 ( DIP8 ) 500 ( DMP8 ) 300 -40~+85 -40~+125 UNIT V V V mW ˚C ˚C ( note ) For supply voltage less than ±15V. the absolute maximum input voltage is equal to the supply voltage. ■ ELECTRICAL CHARACTERISTICS ( Ta=+25˚C,V+/V-=±15V ) PARAMETER Input Offset Voltage Input Offset Current Input Bias Current Input Resistance Large-signal Voltage Gain Maximum Output Voltage Swing 1 Maximum Output Voltage Swing 2 Input Common Mode Voltage Range Common Mode Rejection Ratio Supply Voltage Rejection Ratio Operating Current Slew Rate Transient Response ( Unity Gain )( Rise Time ) Transient Response ( Unity Gain )( Overshoot ) -2- SYMBOL VIO IIO IIB RIN AV VOM1 VOM2 VICM CMR SVR ICC SR tR to TEST CONDITION RS≤10kΩ RL≥2kΩ,VO=±10V RL≥10kΩ RL≥2kΩ RS≤10kΩ RS≤10kΩ RL≥2kΩ VIN=20mV,RL=2kΩ,CL=100pF VIN=20mV,RL=2kΩ,CL=100pF MIN. 0.3 86 ± 12 ± 10 ± 12 70 76.5 - TYP. 2.0 5 30 2.0 110 ± 14 ± 13 ± 13 100 100 1.7 0.5 0.3 5.0 MAX. 6.0 200 500 2.8 - UNIT mV nA nA MΩ dB V V V dB dB mA V/µs µs % Ver.2003-03-18 NJM741 ■ TYPICAL CHARACTERISTICS Ver.2003-03-18 -3- NJM741 ■ TYPICAL CHARACTERISTICS ■ OFFSET ADJUSTMENT CIRCUIT [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -4- Ver.2003-03-18
NJM741M-TE2 价格&库存
很抱歉,暂时无法提供与“NJM741M-TE2”相匹配的价格&库存,您可以联系我们找货
