03510SS-05L-AA-00
03510SS-05L-AA-00
    NMBTECHNOLOGIESCORPORATION
    风扇 管轴式 5VDC 方形 - 35mm 长 x 35mm 高 套管 2 引线
03510SS-05L-AA-00 数据手册
SLEEVE BEARING 03510SS-05x (35 X 10L) NMBTC.COM / 248.919.2250 Characteristic Curves Motor Protection: Auto Restart/Polarity Protection P-Q Curve (in H2O) (Pa) Insulation Resistance: 0.24 Static Pressure Ps Allowable Ambient Temperature Range: -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) 12,000 60 0.20 N 50 0.16 40 0.12 30 0.08 20 0.04 10 0 Expected Life 6,000 30,000 Hours (L10) 4,000 N 2,000 M 0 .05 .10 .15 .20 0 1.77 3.53 5.30 7.06 (m3/min) (CFM) Air Flow Q Outline Material min 200 Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Sleeve Bearing Lead Wire : UL1061, AWG26, +Red, -Black, (Tach) White (7.87) 40°C 8,000 L L 0 10,000 M ROTATION 4- 3.2±0.3 4- 3.2 4- (.126) (1.14) NAME PLATE 3.2 10±0.5 (.39) .4 29±0.3 (1.14) 35±0.5 (1 29 (1.14) 33 (1.30) .4 0) 0) 35 35 .6 .6 (.126) (1 29 (1.14) 33 (1.30) 35±0.5 Unit: mm (inch) AIR 29±0.3 Panel Cut-Outs (1.38) (.094) (1.38) Name Plate 29 29 LOT No. (1.14) 33 (1.30) (1.14) 33 (1.30) INLET SIDE FACTORY ID. 7:CHINA C:JAPAN U:CAMBODIA XXXXXXX 7 MODEL 5V OUTLET SIDE (A) DC (B) A (A) Model Name 03510SS-05L-AT 03510SS-05M-AT 03510SS-05N-AT (B) Current 0.13 0.16 0.28 EP 00 MADE IN +:RED, -:BLACK CHINA or JAPAN or CAMBODIA R VDE 94518 C US CE MARK cULus MARK VDE MARK Specifications Rated Operating Voltage Voltage (V) (V) (A)*1 (W)*1 03510SS-05L-AT-00 5 4.5 ~ 5.5 0.08 0.40 7000 3.88 0.11 0.12 03510SS-05M-AT-00 5 4.5 ~ 5.5 0.12 0.60 8000 4.24 0.12 0.16 03510SS-05N-AT-00 5 4.5 ~ 5.5 0.20 1.00 10000 5.65 0.16 0.23 56.3 MODEL Current Input Speed Power Max. Max. Static Air Flow Pressure Noise Mass (dB)*1 (g) 30.9 19.0 10.5 39.4 22.4 10.5 27.0 10.5 (min-1)*1 (CFM) (m3/min) (in H2O) (Pa) *1: Average Values in Free Air Note: Locked Rotor/Tach Available DC Axial Fans 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s or AC 500V 1min (min-1) Speed Curve Speed N General Specifications SLEEVE BEARING 03510SS-05x (35 X 10L) NMBTC.COM / 248.919.2250 TACHO Specification TACHOMETER SIGNAL 1. 2. OUTPUT CIRCUIT : OPEN COLLECTOR VCE max +15V Ic max 5mA R DC FAN INSIDE ALARM OUTPUT ALARM SIGNAL CIRCUIT -1 DC Axial Fans SPECIFICATION Absolute Maximum Ratings at Ta=25℃ VCE max : +15V Ic max : 5mA [VCE(sat)max = 0.5V]
03510SS-05L-AA-00 价格&库存
很抱歉,暂时无法提供与“03510SS-05L-AA-00”相匹配的价格&库存,您可以联系我们找货
