03828DA-12R-AU-00
03828DA-12R-AU-00
    NMBTECHNOLOGIESCORPORATION
    风扇 管轴式 12VDC 方形 - 38mm 长 x 38mm 高 滚珠 21.5 CFM(0.602m³/min) 4 引线
03828DA-12R-AU-00 数据手册
TELECOM NE W ! 03828DA (38 X 28L) NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: (Pa) 3.20 800 24000 2.80 700 21000 2.40 600 18000 2.00 500 10M Ω or over with a DC500V Megger Static Pressure -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Expected Life 40°C Speed Curve 15000 N class P class Q class R class 1.60 400 1.20 300 9000 Ps 0.80 200 6000 0.40 100 0 0 70,000 Hours (L10) 12000 3000 0 0.1 0 3.53 0.2 0.3 0.4 0.5 0.6 0.7 0 7.06 10.59 14.13 17.66 21.19 24.72 (m3/min) CFM Air Flow Material Outline Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL10368, AWG26, +Red, -Black 7.87 min (200) NO SOLDER Panel Cut-Outs .14 (4- 3.5± 0.3) .14 (4- 3.5) 4R3 4R3 .16 (4) 1.18 (30.0) 1.18 (30.0) 1.43 (36.4) 1.43 (36.4) INLET SIDE PLATE 1.50 (38± 0.3) NAME ( 1.18 (30.0) 1.43 (36.4) ( 1.18 (30.0) 1.43 (36.4) 1.5 38 0 .0) 1.5 39 4 .0) AIR 1.18 (30± 0.3) .14 (4- 3.5) ROTATION inch Units: (mm) .16 (4) 1.18 (30± 0.3) 1.50 (38± 0.3) 1.10 (28± 0.5) OUTLET SIDE Specifications MODEL Rated Operating Voltage Voltage (V) (V) Current Input Speed Power (A)*1 (W)*1 Max. Max. Static Air Flow Pressure Noise (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 Mass (g) 03828DA-12N-AA-00 12 7.0 ~ 13.2 0.30 3.60 16000 15.54 0.44 1.41 350 49.0 47 03828DA-12P-AA-00 12 7.0 ~ 13.2 0.37 4.44 18000 17.66 0.50 1.77 440 52.0 47 03828DA-12Q-AA-00 12 7.0 ~ 13.2 0.49 5.88 20000 19.42 0.55 2.17 540 55.0 47 03828DA-12R-AA-00 12 7.0 ~ 13.2 0.63 7.56 22000 21.54 0.61 2.61 650 58.0 47 03828DA-12R-AU-00** 12 7.0 ~ 13.2 0.63 7.56 22000 21.54 0.61 2.61 650 58.0 47 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air **Note: PWM/Locked Rotor/Tach Available DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: P-Q Curve In H2O Speed Auto Restart/Polarity Protection Insulation Resistance: 03828DA (38 X 28L) NE W ! TELECOM NMBTC.COM / 248.919.2250 Reference PWM Duty Vs. Speed Curve 18000 max typ min N class 16000 Speed (min-1) 12000 10000 8000 6000 4000 2000 0 0 20 40 60 Duty (%) 80 100 max typ min Q class 20000 20 40 60 Duty (%) 80 16000 12000 8000 4000 R class 24000 100 max typ min 20000 Speed (min-1) Speed (min-1) 0 28000 24000 0 max typ min P class 16000 12000 8000 4000 0 20 40 60 Duty (%) 80 100 0 0 20 40 60 Duty (%) 80 100 DC Axial Fans Speed (min-1) 14000 20000 18000 16000 14000 12000 10000 8000 6000 4000 2000 0
03828DA-12R-AU-00 价格&库存
很抱歉,暂时无法提供与“03828DA-12R-AU-00”相匹配的价格&库存,您可以联系我们找货
03828DA-12R-AU-00
  • 1+175.498781+22.73323
  • 10+141.5797510+18.33953
  • 25+128.9991725+16.70991
  • 50+120.0260650+15.54758
  • 175+112.91036175+14.62584
库存:6
