06015SS-24N-AT-00
06015SS-24N-AT-00
    NMBTECHNOLOGIESCORPORATION
    风扇 管轴式 24VDC 方形 - 60mm 长 x 60mm 高 套管 22.6 CFM(0.633m³/min) 3 引线
06015SS-24N-AT-00 数据手册
SLEEVE BEARING NE W ! 06015SS (60 X 15L) NMBTC.COM / 248.919.2250 Characteristic Curves Motor Protection: In H2O Auto Restart/Polarity Protection Insulation Resistance: 10M Ω or over with a DC500V Megger Static Pressure -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Ps Expected Life 40°C 0.20 50 0.18 45 0.16 40 0.14 35 0.12 30 0.10 25 0.08 20 0.06 15 0.04 10 0.02 5 0 0 40,000 Hours (L10) Speed Curve 5,000 4,500 N 4,000 M 3,500 L 3,000 K 2,500 2,000 N 1,500 M L 1,000 K 500 0 0.3 0.4 0.5 0.6 0.7 0 0.1 0.2 0 3.53 7.06 10.59 14.13 17.66 21.19 24.72 (m3/min) CFM Air Flow Material Outline 7.87 min (200) Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Sleeve Bearing Lead Wire : UL1061, AWG26, +Red, -Black ROTATION .137 (4- 4.3) .17 (4- 4.3) AIR NAME PLATE ( 1.97 (50) 2.28 (58.0) ( 1.97 (50) 2.28 (58.0) 2. 64 53 .2 ) 2. 64 52 .1 ) .17 (4- 4.3) 2.36 (60± 0.5) inch Units: (mm) 1.97 (50± 0.3) Panel Cut-Outs 1.97 (50.0) 1.97 (50± 0.3) .59 (15± 0.5) 1.97 (50.0) 2.36 (60± 0.5) 2.28 (58) 2.28 (58) INLET SIDE OUTLET SIDE Specifications Rated Operating Voltage Voltage (V) (V) (A)*1 (W)*1 06015SS-12K-AT-00 12 6.0 ~ 13.8 0.05 0.60 2800 14.83 .42 .07 17.3 23.0 37 06015SS-12L-AT-00 12 6.0 ~ 13.8 0.08 0.96 3200 16.95 .48 .09 22.4 26.0 37 06015SS-12M-AT-00 12 6.0 ~ 13.8 0.11 1.32 3700 19.78 .56 .12 30.8 30.0 37 06015SS-12N-AT-00 12 6.0 ~ 13.8 0.17 2.04 4200 22.60 .64 .16 38.8 34.0 37 MODEL Rotation: Clockwise Current Input Speed Power Airflow Outlet: Air Out Over Struts Max. Max. Static Air Flow Pressure Noise (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 *1: Average Values in Free Air Mass (g) Note: PWM/Locked Rotor/Tach Available DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: P-Q Curve (Pa) Speed General Specifications 06015SS (60 X 15L) NE W ! SLEEVE BEARING NMBTC.COM / 248.919.2250 Specifications Rated Operating Voltage Voltage (V) (V) (A)*1 (W)*1 06015SS-24K-AT-00 24 15.0 ~ 26.4 0.04 0.96 2800 14.83 .42 .07 17.3 23.0 37 06015SS-24L-AT-00 24 10.0 ~ 26.4 0.05 1.20 3200 16.95 .48 .09 22.4 26.0 37 06015SS-24M-AT-00 24 10.0 ~ 26.4 0.06 1.44 3700 19.78 .56 .12 30.8 30.0 37 06015SS-24N-AT-00 24 10.0 ~ 26.4 0.10 2.40 4200 22.60 .64 .16 38.8 34.0 37 MODEL Rotation: Clockwise Current Input Speed Power Airflow Outlet: Air Out Over Struts Max. Max. Static Air Flow Pressure Noise (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 *1: Average Values in Free Air Mass (g) Note: PWM/Locked Rotor/Tach Available
06015SS-24N-AT-00 价格&库存
很抱歉,暂时无法提供与“06015SS-24N-AT-00”相匹配的价格&库存,您可以联系我们找货
