SLEEVE BEARING
NE
W
06015SS (60 X 15L)
NMBTC.COM / 248.919.2250
Characteristic Curves
Motor Protection:
In H2O
Auto Restart/Polarity Protection
Insulation Resistance:
10M Ω or over with a DC500V Megger
Static Pressure
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
Ps
Expected Life
40°C
0.20
50
0.18
45
0.16
40
0.14
35
0.12
30
0.10
25
0.08
15
0.04
10
0.02
5
40,000 Hours (L10)
Speed Curve
5,000
4,500
N
4,000
M
3,500
L
3,000
K
2,500
2,000
N
1,500
M
L
1,000
K
500
0.4
0.5
0.6
0.7
0.2
7.06 10.59 14.13 17.66 21.19 24.72
(m3/min)
CFM
Air Flow
Material
Outline
7.87
min (200)
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Sleeve Bearing
Lead Wire : UL1061, AWG26, +Red, -Black
ROTATION
.137
(4- 4.3)
.17
(4- 4.3)
AIR
NAME
PLATE
1.97
(50)
2.28
(58.0)
1.97
(50)
2.28
(58.0)
2.
64 53
.2
2.
64 52
.1
.17
(4- 4.3)
2.36
(60± 0.5)
inch
Units: (mm)
1.97
(50± 0.3)
Panel Cut-Outs
1.97
(50.0)
1.97
(50± 0.3)
.59
(15± 0.5)
1.97
(50.0)
2.36
(60± 0.5)
2.28
(58)
2.28
(58)
INLET SIDE
OUTLET SIDE
Specifications
Rated
Operating
Voltage
Voltage
(V)
(V)
(A)*1
(W)*1
06015SS-12K-AT-00
12
6.0 ~ 13.8
0.05
0.60
2800
14.83
.42
.07
17.3
23.0
37
06015SS-12L-AT-00
12
6.0 ~ 13.8
0.08
0.96
3200
16.95
.48
.09
22.4
26.0
37
06015SS-12M-AT-00
12
6.0 ~ 13.8
0.11
1.32
3700
19.78
.56
.12
30.8
30.0
37
06015SS-12N-AT-00
12
6.0 ~ 13.8
0.17
2.04
4200
22.60
.64
.16
38.8
34.0
37
MODEL
Rotation: Clockwise
Current
Input
Speed
Power
Airflow Outlet: Air Out Over Struts
Max.
Max. Static
Air Flow
Pressure
Noise
(min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
*1: Average Values in Free Air
Mass
(g)
Note: PWM/Locked Rotor/Tach Available
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
P-Q Curve
(Pa)
Speed
General Specifications
06015SS (60 X 15L)
NE
W
SLEEVE BEARING
Specifications
Rated
Operating
Voltage
Voltage
(V)
(V)
(A)*1
(W)*1
06015SS-24K-AT-00
24
15.0 ~ 26.4
0.04
0.96
2800
14.83
.42
.07
17.3
23.0
37
06015SS-24L-AT-00
24
10.0 ~ 26.4
0.05
1.20
3200
16.95
.48
.09
22.4
26.0
37
06015SS-24M-AT-00
24
10.0 ~ 26.4
0.06
1.44
3700
19.78
.56
.12
30.8
30.0
37
06015SS-24N-AT-00
24
10.0 ~ 26.4
0.10
2.40
4200
22.60
.64
.16
38.8
34.0
37
MODEL
Rotation: Clockwise
Current
Input
Speed
Power
Max.
Max. Static
Air Flow
Pressure
Noise
Mass
(g)
很抱歉,暂时无法提供与“06015SS-12N-AT-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+77.352711+10.01988
