06015VA (60 X 15L)
NMBTC.COM / 818.341.3355
Characteristic Curves
Motor Protection:
In H2O
Auto Restart/Polarity Protection
Insulation Resistance:
10M Ω or over with a DC500V Megger
Static Pressure
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
Ps
Expected Life
70
.24
60
.20
Speed Curve
7000
50
.16
40
.12
30
.08
P
N
5000
M
L
4000
3000
P
2000
N
M
Failure Rate: 10%
60°C 40,000 Hours
.04
10
.00
L
1000
0.20
0.30
0.40
0.50
0.60
7.06
10.59
14.12
17.65
21.18
(m3/min)
CFM
inch
Units: (mm)
AIR
.169
(4 – φ4.3)
NAME
PLATE
.169
(4 – φ4.3)
40 0)
2. 61.
(φ
1.97
(50.0)
2.28
(58.0)
48 0)
2. 63.
(φ
1.97
(50.0)
2.28
(58.0)
ROTATION
0.169
(4−φ4.3± 0.2)
Panel Cut-Outs
7.88
min (200)
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL3385, AWG26, +Red, -Black
2.36
(60.0± 0.3)
Outline
1.97
(50.0± 0.3)
Material
Air Flow
0.59
(15.0± 0.5)
1.97
(50.0)
1.97
(50.0)
2.28
(58.0)
2.28
(58.0)
INLET SIDE
OUTLET SIDE
1.97
(50.0± 0.3)
2.36
(60.0 ± 0.3)
Specifications
Rated
Operating
Current
Input
Speed
Max.
Max. Static
Noise
MODEL
Voltage
Voltage
Power
Air Flow
Pressure
(V)
(V)
(A)*1
(W)*1
06015VA-12L-AA-00
12
6.0 ~ 13.8
0.08
0.96
4100
14.5
0.41
0.16
06015VA-12M-AA-00
12
6.0 ~ 13.8
0.11
1.32
4600
15.9
0.45
0.19
06015VA-12N-AA-00
12
6.0 ~ 13.8
0.12
1.44
5100
17.6
0.50
06015VA-12P-AA-00
12
6.0 ~ 13.8
0.13
1.56
5600
19.4
06015VA-24L-AA-00
24
10.0 ~ 27.6
0.04
0.96
4100
06015VA-24M-AA-00
24
10.0 ~ 27.6
0.05
1.20
06015VA-24N-AA-00
24
10.0 ~ 27.6
0.06
06015VA-24P-AA-00
24
10.0 ~ 27.6
06015VA-24Q-AA-00
24
10.0 ~ 26.4
Rotation: Clockwise
(dB)*1
(g)
38.8
28.5
55
48.3
31.0
55
0.23
57.5
33.5
55
0.55
0.27
67.7
36.5
55
14.5
0.41
0.16
38.8
28.5
55
4600
15.9
0.45
0.19
48.3
31.0
55
1.44
5100
17.6
0.50
0.23
57.5
33.5
55
0.07
1.68
5600
19.4
0.55
0.27
67.7
36.5
55
0.08
1.92
6100
21.2
0.60
0.30
75.4
40.0
55
Airflow Outlet: Air Out Over Struts
(min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1
Mass
*1: Average Values in Free Air
Note: Locked Rotor/Tach Available
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
.28
P-Q Curve
(Pa)
Speed
General Specifications
很抱歉,暂时无法提供与“2406VL-05W-B69-B50”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+127.995781+16.57163
- 10+103.5457110+13.40608
- 25+94.4113025+12.22344
- 50+87.8738450+11.37704
- 150+80.93894150+10.47918
