2406VL-04W-B59-B00
2406VL-04W-B59-B00
    NMBTECHNOLOGIESCORPORATION
    FAN 12VDC 60X15MM 3WR
2406VL-04W-B59-B00 数据手册
06015VA (60 X 15L) NMBTC.COM / 818.341.3355 Characteristic Curves Motor Protection: In H2O Auto Restart/Polarity Protection Insulation Resistance: 10M Ω or over with a DC500V Megger Static Pressure -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Ps Expected Life 70 .24 60 .20 Speed Curve 7000 50 .16 40 .12 30 .08 20 6000 P N 5000 M L 4000 3000 P 2000 N M Failure Rate: 10% 60°C 40,000 Hours .04 10 .00 0 L 1000 0 0.10 0.20 0.30 0.40 0.50 0.60 0 3.53 7.06 10.59 14.12 17.65 21.18 0 (m3/min) CFM inch Units: (mm) AIR .169 (4 – φ4.3) NAME PLATE .169 (4 – φ4.3) 40 0) 2. 61. (φ 1.97 (50.0) 2.28 (58.0) 48 0) 2. 63. (φ 1.97 (50.0) 2.28 (58.0) ROTATION 0.169 (4−φ4.3± 0.2) Panel Cut-Outs 7.88 min (200) Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL3385, AWG26, +Red, -Black 2.36 (60.0± 0.3) Outline 1.97 (50.0± 0.3) Material Air Flow 0.59 (15.0± 0.5) 1.97 (50.0) 1.97 (50.0) 2.28 (58.0) 2.28 (58.0) INLET SIDE OUTLET SIDE 1.97 (50.0± 0.3) 2.36 (60.0 ± 0.3) Specifications Rated Operating Current Input Speed Max. Max. Static Noise MODEL Voltage Voltage Power Air Flow Pressure (V) (V) (A)*1 (W)*1 06015VA-12L-AA-00 12 6.0 ~ 13.8 0.08 0.96 4100 14.5 0.41 0.16 06015VA-12M-AA-00 12 6.0 ~ 13.8 0.11 1.32 4600 15.9 0.45 0.19 06015VA-12N-AA-00 12 6.0 ~ 13.8 0.12 1.44 5100 17.6 0.50 06015VA-12P-AA-00 12 6.0 ~ 13.8 0.13 1.56 5600 19.4 06015VA-24L-AA-00 24 10.0 ~ 27.6 0.04 0.96 4100 06015VA-24M-AA-00 24 10.0 ~ 27.6 0.05 1.20 06015VA-24N-AA-00 24 10.0 ~ 27.6 0.06 06015VA-24P-AA-00 24 10.0 ~ 27.6 06015VA-24Q-AA-00 24 10.0 ~ 26.4 Rotation: Clockwise (dB)*1 (g) 38.8 28.5 55 48.3 31.0 55 0.23 57.5 33.5 55 0.55 0.27 67.7 36.5 55 14.5 0.41 0.16 38.8 28.5 55 4600 15.9 0.45 0.19 48.3 31.0 55 1.44 5100 17.6 0.50 0.23 57.5 33.5 55 0.07 1.68 5600 19.4 0.55 0.27 67.7 36.5 55 0.08 1.92 6100 21.2 0.60 0.30 75.4 40.0 55 Airflow Outlet: Air Out Over Struts (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 Mass *1: Average Values in Free Air Note: Locked Rotor/Tach Available DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: .28 P-Q Curve (Pa) Speed General Specifications
2406VL-04W-B59-B00 价格&库存
很抱歉,暂时无法提供与“2406VL-04W-B59-B00”相匹配的价格&库存,您可以联系我们找货
