06020SA-12M-AA-00
06020SA-12M-AA-00
    NMBTECHNOLOGIESCORPORATION
    风扇 管轴式 12VDC 方形 - 60mm 长 x 60mm 高 滚珠 18.4 CFM(0.515m³/min) 2 引线
06020SA-12M-AA-00 数据手册
06020SA-12x (60 X 20L) NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: P−Q CURVE (in H2O) (Pa) .24 60 .20 50 Insulation Resistance: 5000 N 10M Ω or over with a DC500V Megger Allowable Ambient Temperature Range: -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) .16 40 .12 30 .08 20 3500 K 3000 J 2500 2000 M Expected Life Failure Rate: 10% .04 10 0 0 40,000 Hours (AA/EA) Material K 1500 N 1000 L 500 J 0.2 0.3 0.4 0.5 0.6 0.7 0 0 0 .1 0 3.53 7.06 10.59 14.12 17.65 21.18 24.71 (m3/min) (CFM) Air Flow Q Outline Min 300 (11.82) Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL3385, AWG26, +Red, -Black Panel Cut-Outs 4-ø4.3 ±0.2 (0.169) Rotation 0 5. ) φ6 2.56 ( 50.0 (1.97) 0 5. ) φ6 .56 (2 AIR NAME PLATE (1.97) 50.0. ±0.3 (.169) (2.36) 4 – φ4.3 (.169) 58.0 (2.28) 4 – φ4.3 60.0. ±0.5 Units: mm (inch) 58.0 (2.28) 50.0 (1.97) 4000 L Static Pressure Ps AC 700V 1s or AC 500V 1min 4500 M REF 4.0 50.0. ±0.3 20.0 ±0.5 (0.78) (1.97) 60.0. ±0.5 50.0 (1.97) (2.36) 50.0 (1.97) 58.0 (2.28) ***Outline is A (Rib) Type 58.0 (2.28) INLET SIDE Name Plate OUTLET SIDE FACTORY ID. 7:CHINA C:JAPAN U : CAMBODIA LOT NO. 7 ******* MODEL 12V (A) DC (B) A EP 00 Specifications □ = Casing Form - - - A: Rib Type, MODEL 06020SA-12K- A-00 □ 06020SA-12L-□A-00 06020SA-12M-□A-00 06020SA-12N-□A-00 (0.157) MADE IN +:RED,-:BLACK (A) (B) Model Name Current 06020SA-12J-□A 0.08 06020SA-12K-□A 0.08 06020SA-12L-□A 0.09 06020SA-12M-□A 0.11 0.14 06020SA-12N-□A R VDE C US CHINA or JAPAN or CAMBODIA 94518 CE MARK VDE MARK □ = Casing Form - - - A : Rib Type, E : F lange Type cULus MARK E: F lange Type Current Input Speed Noise Mass (dB)*1 (g) 21.2 21.5 56 27.6 23.5 56 34.7 26.0 56 0.17 42.6 28.5 56 0.21 52.1 30.5 56 Rated Operating Voltage Voltage (V) (V) (A)*1 (W)*1 12 6.0 ~ 13.8 0.05 2800 0.36 0.09 12 6.0 ~ 13.8 0.05 3200 0.41 0.11 12 6.0 ~ 13.8 0.06 0.72 3600 0.47 0.14 12 6.0 ~ 13.8 0.08 0.96 4000 0.52 12 6.0 ~ 13.8 0.09 1.08 4400 20.48 0.58 Power Max. Max. Static Air Flow Pressure (min-1)*1 (m3/min) *1: Average Values in Free Air (in H2O) Note: PWM/Locked Rotor/Tach Available DC Axial Fans Dielectric Withstand Voltage: 60°C (min-1) SPEED CURVE Speed N Auto Restart/Polarity Protection
06020SA-12M-AA-00 价格&库存
很抱歉,暂时无法提供与“06020SA-12M-AA-00”相匹配的价格&库存,您可以联系我们找货
06020SA-12M-AA-00
库存:133
