06025SA-12T-AU-D3
06025SA-12T-AU-D3
    NMBTECHNOLOGIESCORPORATION
    风扇 管轴式 12VDC 方形 - 60mm 长 x 60mm 高 滚珠 37.8 CFM(1.06m³/min) 4 引线
06025SA-12T-AU-D3 数据手册
PWM 06025SA-12T (60 X 25) Pulse Width Modulation Axial Cooling Fan NMBTC.COM / 248.919.2250 General Specifications PWM Benefits & Applications Motor Type: PWM Benefits Increased Life Expectancy Energy Saving Lower Vibration Lower Noise Current Spike Prevention PWM Applications Routers Switches Storage Data Centers Optical Repeaters Broadcast Equipment Inverters UPS Battery Chargers Fuel Cells Industrial Power Supplies Welders Plasma Cutters Instrumentation Test Equipment Enclosures and more DC Brushless Motor Motor Protection: Auto Restart/Polarity Protection Motor withstands reverse connection for positive and negative leads. Insulation Resistance: 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s or 500V 1min Allowable Ambient Temperature Range: -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Characteristics Curves Customized fan performances at multiple operating points. Peak efficiency resulting in lower total ownership costs. Cost effective and better reliability. Life Expectancy L10 25°C 90,000 Hours Specifications MODEL Rated Operating Voltage Voltage (V) 06025SA-12T-AU-D3 12 (V) Current Avg (A) *1 10.8 ~ 13.2 0.43 Input Power Max (A) *1 0.66 Avg (W) *1 5.16 Speed Max. Static Air Flow Max *1 (min ) 7.92 7500 (W) Max. -1 *1 (CFM) (m /min) (inH2O) 1.07 Mass Pressure 3 37.8 Noise 0.64 (Pa) 158.5 (dB)*1 (g) 47.0 65 *1: Values in Free Air Page 1 of 3 PWM 06025SA-12T (60 X 25) NMBTC.COM / 248.919.2250 PWM Specifications Pulse Width Modulation Axial Cooling Fan PWM Characteristics Curve TACHO Specifications Page 2 of 3 PWM 06025SA-12T (60 X 25) NMBTC.COM / 248.919.2250 Panel Cut-Outs Pulse Width Modulation Axial Cooling Fan Materials Casing : Plastic (Black UL94V-0) Impeller : Plastic (Black UL94V-0) Bearing : Ball Bearing Lead Wire : UL10368 AWG26 (+) : Red (-) : Black PWM : Brown Tach : White Unit: mm (inch) Outline Unit: mm (inch) Page 3 of 3
06025SA-12T-AU-D3 价格&库存
很抱歉,暂时无法提供与“06025SA-12T-AU-D3”相匹配的价格&库存,您可以联系我们找货
