SLEEVE BEARING
NE
W
06025SS (60 X 25L)
NMBTC.COM / 248.919.2250
Characteristic Curves
Motor Protection:
Auto Restart/Polarity Protection
In H2O
(Pa)
0.56
140
Insulation Resistance:
10M Ω or over with a DC500V Megger
Static Pressure
K ~ M Class:
-10°C ~ +70°C (Operating)
N ~ R Class:
-10°C ~ +60°C (Operating)
All Class:
-40°C ~ +70°C (Storage)
(non-condensing environment)
0.48
120
0.40
100
0.32
80
0.24
60
Ps 0.16
40
0.08
Expected Life
40°C
Speed Curve
7,000
R
6,000
5,000
N
M
4,000
L
3,000
K
2,000
M
K L
50,000 Hours (L10)
0.2
N
1,000
R
0.4
0.6
0.8
1.0
(m3/min)
14.1
21.2
28.3
35.3
CFM
Air Flow
Material
Outline
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Sleeve Bearing
Lead Wire : UL1007, AWG26, +Red, -Black, (tach) White
11.81
min (300)
NO SOLDER
Panel Cut-Outs
.17
(4- 4.3)
AIR
NAME
PLATE
2.
5
65 6
2.28
(58)
1.97
(50)
2.28
(58)
2.
5
65 6
1.97
(50)
2.36
(60± 0.5)
.17
(4- 4.3)
1.97
(50± 0.3)
inch
Units: (mm)
.17
(4- 4.3± 0.2)
ROTATION
1.97
(50)
1.97
(50)
2.28
(58)
2.28
(58)
INLET SIDE
OUTLET SIDE
.98
(25± 0.5)
1.97
(50± 0.3)
2.36
(60± 0.5)
Specifications
MODEL
Rated
Operating
Voltage
Voltage
Current
Input
(V)
(V)
(A)*1
(W)*1
Speed
Power
Max.
Max. Static
Air Flow
Pressure
Noise
(min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
Mass
(g)
06025SS-12K-AT-D0
12
6.0 ~ 13.8
0.08
0.96
3000
14.48
.41
.10
26.0
21.0
65
06025SS-12L-AT-D0
12
6.0 ~ 13.8
0.09
1.08
3500
16.95
.48
.14
35.0
23.5
65
06025SS-12M-AT-D0
12
6.0 ~ 13.8
0.12
1.44
4000
19.78
.56
.18
46.0
27.5
65
06025SS-12N-AT-D0
12
6.0 ~ 13.2
0.18
2.16
4700
23.31
.66
.25
63.0
33.0
65
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
*1: Average Values in Free Air
Note: PWM/Locked Rotor/Tach Available
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
P-Q Curve
Speed
General Specifications
SLEEVE BEARING
NE
W
06025SS (60 X 25L)
Specifications
MODEL
Rated
Operating
Current
Input
Speed
Max.
Max. Static
Noise
Voltage
Voltage
Power
Air Flow
Pressure
(V)
(V)
(A)*1
(W)*1
Mass
(g)
06025SS-24K-AT-D0
24
10.0 ~ 27.6
0.04
0.96
3000
14.48
.41
.10
26.0
21.0
65
06025SS-24L-AT-D0
24
10.0 ~ 27.6
0.05
1.20
3500
16.95
.48
.14
35.0
23.5
65
06025SS-24M-AT-D0
24
10.0 ~ 27.6
0.06
1.44
4000
19.78
.56
.18
46.0
27.5
65
06025SS-24N-AT-D0
24
10.0 ~ 26.4
0.09
2.16
4700
23.31
.66
.25
63.0
33.0
65
06025SS-24R-AT-D0
24
10.0 ~ 26.4
0.15
3.60
6000
30.02
.85
.41
101.0
38.5
65
Rotation: Clockwise
很抱歉,暂时无法提供与“06025SS-24R-AT-D0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+92.147991+11.94414
- 10+74.8109510+9.69693
- 25+68.2698825+8.84908
- 50+63.5709250+8.24000
- 130+57.51761130+7.45538
- 260+57.27339260+7.42373
