REFRIGERATION
NE
W
08015JE (80 X 15L)
NMBTC.COM / 248.919.2250
Characteristic Curves
Motor Protection:
In H2O
Auto Restart
Insulation Resistance:
10M Ω or over with a DC500V Megger
Static Pressure
-40°C ~ +40°C (Operating)
-40°C ~ +60°C (Storage)
(non-condensing environment)
Ps
Expected Life
-20°C
Speed Curve
.16
40
4000
.14
35
3500
.12
30
3000
M
.10
25
.08
15
1500
.04
10
1000
.02
5
70,000 Hours (L10)
2500
K
2000
L
0.3
0.4
0.5
3000
500
M
K
L
0.2
0.6
0.7
7.06 10.59 14.13 17.66 21.19 24.72
(m3/min)
CFM
Air Flow
Material
Outline
11.81
min (300)
Casing : Plastic (Black) PBT UL94V-0
Impeller : Plastic (Black) PBT UL94V-0
Bearing : Ball Bearing
Lead Wire : UL1007, AWG26, +Red, -Black
Panel Cut-Outs
3)
3)
7
.1 4.
7
.1 4.
(4
3.
3
85 5
3.06
(77.6)
2.81
(71.5)
2.81
(71.5)
3.06
(77.6)
3.06
(77.6)
INLET SIDE
OUTLET SIDE
2.81
(71.5± 0.3)
.59
(15.0± 0.8)
2.81
(71.5)
2.81
(71.5)
7 )
.1 4.3
4
NAME
PLATE
3.
6
92 2
(4
3.06
(77.6)
3.15
(80± 0.5)
AIR
inch
Units: (mm)
2.81
(71.5± 0.3)
ROTATION
3.15
(80± 0.5)
Specifications
MODEL
Rated
Operating
Voltage
Voltage
Current
Input
(V)
(V)
(A)*1
(W)*1
Speed
Power
Max.
Max. Static
Air Flow
Pressure
Noise
(min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
Mass
(g)
08015JE-12K-BA-F0
12
7.0 ~ 13.2
0.04
0.48
2000
15.54
0.44
.05
13.6
23.5
55
08015JE-12L-BA-F0
12
7.0 ~ 13.2
0.07
0.84
2400
19.07
0.54
.08
19.4
28.0
55
08015JE-12M-BA-F0
12
7.0 ~ 13.2
0.10
1.20
2800
22.25
0.63
.10
25.0
32.0
55
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
*1: Average Values in Free Air
Note: PWM/Locked Rotor/Tach Available
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
P-Q Curve
(Pa)
Speed
General Specifications
很抱歉,暂时无法提供与“08015JE-12M-BA-F0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+134.772451+17.45775
- 10+108.9931910+14.11843
- 25+99.3648525+12.87123
- 50+92.4823450+11.97970
- 120+85.46254120+11.07039
