SLEEVE BEARING
NE
W
08025SS (80 X 25L)
NMBTC.COM / 248.919.2250
Characteristic Curves
Motor Protection:
In H2O
Auto Restart/Polarity Protection
Insulation Resistance:
10M Ω or over with a DC500V Megger
Static Pressure
K ~ M Class:
-10°C ~ +70°C (Operating)
N ~ Q Class:
-10°C ~ +60°C (Operating)
All Class:
-40°C ~ +70°C (Storage)
(non-condensing environment)
Ps
Expected Life
40°C
.40
100
.32
80
.24
60
Speed Curve
5,000
Q
4,000
N
3,000
M
.16
40
.08
L
2,000
K
1,000
K
50,000 Hours (L10)
L
M
Q
N
1.0
1.5
2.0
(m3/min)
35.31
52.97
70.63
CFM
Air Flow
Material
Outline
11.81
min (300)
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Sleeve Bearing
Lead Wire : UL1007, AWG26, +Red, -Black, (tach) White
.17
(8- 4.3± 0.2)
AIR
NAME
PLATE
2.81
(71.5± 0.3)
3.3
5
85
3.3
9
86
2.81
(71.5)
3.02
(76.8)
3.07
(80.0± 0.5)
.17
(4- 4.3)
.17
(4- 4.3)
2.81
(71.5)
3.02
(76.8)
inch
Units: (mm)
2.81
(71.5± 0.3)
Panel Cut-Outs
ROTATION
2.81
(71.5)
2.81
(71.5)
3.02
(76.8)
3.02
(76.8)
INLET SIDE
OUTLET SIDE
.16
(4.0± 0.2)
.16
(4.0± 0.2)
.48
(25.0± 0.5)
3.07
(80.0± 0.5)
Specifications
MODEL
Rated
Operating
Voltage
Voltage
(V)
(V)
Current
Input
Speed
Power
(A)*1
(W)*1
Max.
Max. Static
Air Flow
Pressure
Noise
(min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
Mass
(g)
08025SS-12K-AT-D0
12
6.0 ~ 13.8
0.06
0.72
2000
26.13
0.74
.07
16.5
19.0
80
08025SS-12L-AT-D0
12
6.0 ~ 13.8
0.08
0.96
2300
30.37
0.86
.09
21.5
22.0
80
08025SS-12M-AT-D0
12
6.0 ~ 13.8
0.11
1.32
2700
36.02
1.02
.12
29.0
26.0
80
08025SS-12N-AT-D0
12
6.0 ~ 13.8
0.16
1.92
3100
41.32
1.17
.15
37.5
30.0
80
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
*1: Average Values in Free Air
Note: PWM/Locked Rotor/Tach Available
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
P-Q Curve
(Pa)
Speed
General Specifications
08025SS (80 X 25L)
NE
W
SLEEVE BEARING
Specifications
MODEL
Rated
Operating
Voltage
Voltage
(V)
(V)
Current
Input
Speed
Power
(A)*1
(W)*1
Max.
Max. Static
Air Flow
Pressure
Noise
Mass
(g)
08025SS-24K-AT-D0
24
10.0 ~ 27.6
0.04
0.96
2000
26.13
0.74
.07
16.5
19.0
80
08025SS-24L-AT-D0
24
10.0 ~ 27.6
0.05
1.20
2300
30.37
0.86
.09
21.5
22.0
80
08025SS-24M-AT-D0
24
10.0 ~ 27.6
0.07
1.68
2700
36.02
1.02
.12
29.0
26.0
80
08025SS-24N-AT-D0
24
10.0 ~ 27.6
0.09
2.16
3100
41.32
1.17
.15
37.5
30.0
80
08025SS-24Q-AT-D0
24
10.0 ~ 26.4
0.21
5.04
4100
54.74
1.55
.27
68.0
39.5
80
Rotation: Clockwise
很抱歉,暂时无法提供与“08025SS-24Q-AT-D0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+99.798351+12.90474
