08025SS-12N-AT-D0
08025SS-12N-AT-D0
    NMBTECHNOLOGIESCORPORATION
    风扇 管轴式 12VDC 정사각형 - 80mm 长 x 80mm 高 套管 41.3 CFM(1.16m³/min) 3 引线
08025SS-12N-AT-D0 数据手册
SLEEVE BEARING NE W ! 08025SS (80 X 25L) NMBTC.COM / 248.919.2250 Characteristic Curves Motor Protection: In H2O Auto Restart/Polarity Protection Insulation Resistance: 10M Ω or over with a DC500V Megger Static Pressure K ~ M Class: -10°C ~ +70°C (Operating) N ~ Q Class: -10°C ~ +60°C (Operating) All Class: -40°C ~ +70°C (Storage) (non-condensing environment) Ps Expected Life 40°C .40 100 .32 80 .24 60 Speed Curve 5,000 Q 4,000 N 3,000 M .16 40 .08 20 0 0 L 2,000 K 1,000 K 50,000 Hours (L10) L M Q N 0 0.5 1.0 1.5 2.0 (m3/min) 0 17.66 35.31 52.97 70.63 CFM Air Flow Material Outline 11.81 min (300) Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Sleeve Bearing Lead Wire : UL1007, AWG26, +Red, -Black, (tach) White .17 (8- 4.3± 0.2) AIR NAME PLATE 2.81 (71.5± 0.3) ( ( 3.3 5 85 ) 3.3 9 86 ) 2.81 (71.5) 3.02 (76.8) 3.07 (80.0± 0.5) .17 (4- 4.3) .17 (4- 4.3) 2.81 (71.5) 3.02 (76.8) inch Units: (mm) 2.81 (71.5± 0.3) Panel Cut-Outs ROTATION 2.81 (71.5) 2.81 (71.5) 3.02 (76.8) 3.02 (76.8) INLET SIDE OUTLET SIDE .16 (4.0± 0.2) .16 (4.0± 0.2) .48 (25.0± 0.5) 3.07 (80.0± 0.5) Specifications MODEL Rated Operating Voltage Voltage (V) (V) Current Input Speed Power (A)*1 (W)*1 Max. Max. Static Air Flow Pressure Noise (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 Mass (g) 08025SS-12K-AT-D0 12 6.0 ~ 13.8 0.06 0.72 2000 26.13 0.74 .07 16.5 19.0 80 08025SS-12L-AT-D0 12 6.0 ~ 13.8 0.08 0.96 2300 30.37 0.86 .09 21.5 22.0 80 08025SS-12M-AT-D0 12 6.0 ~ 13.8 0.11 1.32 2700 36.02 1.02 .12 29.0 26.0 80 08025SS-12N-AT-D0 12 6.0 ~ 13.8 0.16 1.92 3100 41.32 1.17 .15 37.5 30.0 80 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: P-Q Curve (Pa) Speed General Specifications 08025SS (80 X 25L) NE W ! SLEEVE BEARING NMBTC.COM / 248.919.2250 Specifications MODEL Rated Operating Voltage Voltage (V) (V) Current Input Speed Power (A)*1 (W)*1 Max. Max. Static Air Flow Pressure Noise (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 Mass (g) 08025SS-24K-AT-D0 24 10.0 ~ 27.6 0.04 0.96 2000 26.13 0.74 .07 16.5 19.0 80 08025SS-24L-AT-D0 24 10.0 ~ 27.6 0.05 1.20 2300 30.37 0.86 .09 21.5 22.0 80 08025SS-24M-AT-D0 24 10.0 ~ 27.6 0.07 1.68 2700 36.02 1.02 .12 29.0 26.0 80 08025SS-24N-AT-D0 24 10.0 ~ 27.6 0.09 2.16 3100 41.32 1.17 .15 37.5 30.0 80 08025SS-24Q-AT-D0 24 10.0 ~ 26.4 0.21 5.04 4100 54.74 1.55 .27 68.0 39.5 80 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available
08025SS-12N-AT-D0 价格&库存
很抱歉,暂时无法提供与“08025SS-12N-AT-D0”相匹配的价格&库存,您可以联系我们找货
