09232JE-12M-BA-F0
09232JE-12M-BA-F0
    NMBTECHNOLOGIESCORPORATION
    风扇 管轴式 12VDC 方形 - 92mm 长 x 92mm 高 滚珠 43.8 CFM(1.23m³/min) 2 引线
09232JE-12M-BA-F0 数据手册
REFRIGERATION NE W ! 09232JE (92 X 32L) NMBTC.COM / 248.919.2250 Characteristic Curves Motor Protection: Auto Restart (Pa) 0.28 70 0.24 60 0.20 50 Insulation Resistance: 10M Ω or over with a DC500V Megger Static Pressure Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: -40°C ~ +40°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Ps 0.14 Speed Curve 3,500 0.12 30 0.08 20 0.04 10 0 0 70,000 Hours (L10) 1,500 L Class 1,000 K Class 500 0 0.5 0.0 17.66 1.0 1.5 35.31 52.97 (m3/min) CFM Outline 3.25 (82.5± 0.5) 3.53 (89.6) 3.25 (82.5± 0.5) 1.26 (32± 1.5) 11.81 (300± 15) 3.62 +1.0 (92.0 -1.5) .2 (5) 3.25 (82.5± 0.5) Specifications MODEL .39 (10) .73 (18.5± .8) NAME 3.53 (89.6) INLET SIDE ROTATION Rated Operating Current Input Speed Max. Max. Static Noise Voltage Voltage Power Air Flow Pressure (V) (V) (A)*1 (W)*1 1.26 (32± 1.5) .18 (4- 4.5± .3) PLATE 3.62 +1.0 (92.0 -1.5) ( 3.25 (82.5) 3 10 .94 0. 0) 3.62 +1.0 (92.0 -1.5) (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 Mass (g) 09232JE-12K-BA-F0 12 7.0 ~ 13.2 0.06 0.72 2400 29.66 0.84 .09 23.6 25.5 130 09232JE-12L-BA-F0 12 7.0 ~ 13.2 0.08 0.96 2800 35.31 1.00 .13 33.0 29.5 130 09232JE-12M-BA-F0 12 7.0 ~ 13.2 0.13 1.56 3350 43.79 1.24 .19 46.3 34.5 130 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available ± 3.25 (82.5± 0.5) 3.25 (82.5) .39 (10) .73 (18.5± .8) 11.81 .18 (4- 4.5) .2 (5) PLATE 3.62 +1.0 (92.0 -1.5) .18 (4- 4.5± .3) Panel Cut-Outs 2,000 M Class Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG26, +Red, -Black 2,500 L Class K Class Air Flow Material inch Units: (mm) 3,000 M Class 40 Expected Life -20°C P-Q Curve DC Axial Fans In H2O Speed General Specifications
09232JE-12M-BA-F0 价格&库存
很抱歉,暂时无法提供与“09232JE-12M-BA-F0”相匹配的价格&库存,您可以联系我们找货
