NE
W
09238RA (92 X 38L)
IP69K
NMBTC.COM / 248.919.2250
Characteristic Curves
Motor Protection:
Auto Restart/Polarity Protection
(Pa)
1.60
400
1.40
350
Insulation Resistance:
10M Ω or over with a DC500V Megger
Static Pressure
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
IP Code: IP69K
300
1.00
250
0.80
200
0.60
100
0.20
50
Q
N
L
5,000
4,000
Q
P
3,000
N
2,000
M
L
1,000
1.0
2.0
3.0
4.0
0.0
35.31
70.63
5.0 (m3/min)
105.94
141.26
176.57 CFM
Air Flow
Outline
AIR
NAME
PLATE
3.62
(92± 0.5)
ROTATION
3.25
(82.5± 0.3)
Panel Cut-Outs
11.81
min (300)
NO SOLDER
0.17
(8−φ4.3± 0.3)
.17
(4- 4.3)
.17
(4- 4.3)
3.25
(82.5± 0.3)
4.
13
10
02 2)
10
4.
3.25
(82.5)
3.50
(88.8)
3.50
(88.8)
INLET SIDE
OUTLET SIDE
3.50
(88.8)
3.25
(82.5)
3.50
(88.8)
3.25
(82.5)
.16
(4± 0.3)
.16
(4± 0.3)
1.51
(38.4± 0.5)
3.62
(92± 0.5)
5)
3.25
(82.5)
6,000
M
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL3385, AWG26, +Red, -Black
inch
Units: (mm)
7,000
P
100,000 Hours (L10)
Material
Speed Curve
150
Ps 0.40
Expected Life
25°C
1.20
P-Q Curve
Specifications
MODEL
Rated
Operating
Voltage
Voltage
(V)
(V)
Current
Input
Speed
Power
(A)*1
(W)*1
Max.
Max. Static
Air Flow
Pressure
Noise
(min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
Mass
(g)
09238RA-24L-GA-00
24
14.0 ~ 27.6
0.40
9.60
5000
103.83
2.94
0.57
142.0
52.5
250
09238RA-24M-GA-00
24
14.0 ~ 27.6
0.56
13.44
5700
118.66
3.36
0.75
187.0
56.5
250
09238RA-24N-GA-00
24
14.0 ~ 27.6
0.71
17.04
6200
129.96
3.68
0.89
222.0
59.0
250
09238RA-24P-GA-00
24
14.0 ~ 27.6
0.92
22.08
6700
141.26
4.00
1.04
260.0
61.0
250
09238RA-24Q-GA-00
24
14.0 ~ 26.4
1.13
27.12
7200
152.56
4.32
1.20
300.0
62.5
250
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
*1: Average Values in Free Air
Note: PWM/Locked Rotor/Tach Available
Extreme Environment
In H2O
Speed
General Specifications
很抱歉,暂时无法提供与“09238RA-24P-GA-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+413.959061+53.55193
