09533GA-12M-AA-00
09533GA-12M-AA-00
    NMBTECHNOLOGIESCORPORATION
    风扇 鼓风机 12VDC 矩形/圆形 - 97mm 长 x 93.5mm 高 滚珠 28.6 CFM(0.801m³/min) 2 引线
09533GA-12M-AA-00 数据手册
09533GA-12x (95φ X 33L) NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: (in �H2O) Auto Restart/Polarity Protection 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s or AC 500V 1min Allowable Ambient Temperature Range: -10°C ~ +60°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) (Pa) 500 ��� 450 ��� 400 ��� 350 ��� 300 ��� 250 �� 200 �� 150 �� 100 �� 50 0 0 Expected Life Failure Rate: 10% 25°C 100,000 Hours Q Speed M Speed L Speed K Speed 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 (m3/min) (���) 0 ��� ��� ���� ���� ���� ���� ���� ���� ���� ���� �� Material Air Flow Q Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG26, +Red, -Black Outline Unit: mm (inch) (3.818) REF 97.0 (0.177) 2-φ4.5 THROUGH HOLE IMPELLER ROTATION 39.0±0.3 (1.535) (1.299) 33.0±0.5 50.0±0.3 (1.968) REF 27.0 (1.062) (11.811) min 300 (0.984) REF 25 NAME PLATE (2.086) REF 53.0 AIRFLOW (3.681) REF 93.5 (1.289) 32.0±0.3 (1.535) 39.0±0.3 (2.283) 58.0±0.5 AIR AIR (1.259) 32.0±0.3 Name Plate U.S.PATENT FILE NO. LOT NO. U.S. Patent RE39, 117 E NO SOLDER FACTORY ID. 7:CHINA C:JAPAN U : CAMBODIA U.S. Patent RE39,117 E 7 MODEL 12V (A) DC (A) (B) Model Name Current 09533GA-12K-AA 0.52 09533GA-12L-AA 0.84 09533GA-12M-AA 1.34 09533GA-12Q-AA 2.10 (B) A EP 00 MADE IN +:RED,-:BLACK R Specifications VDE CE MARK CHINA or JAPAN or CAMBODIA US 94518 VDE MARK Rated Operating Voltage Voltage (V) (V) (A)*1 (W)*1 09533GA-12K-AA-00 12 6.0 ~ 13.8 0.40 4.80 2700 09533GA-12L-AA-00 09533GA-12M-AA-00 12 0.64 7.68 12 6.0 ~ 13.8 6.0 ~ 12.6 1.03 09533GA-12Q-AA-00 12 9.5 ~ 13.2 1.40 MODEL C Current Input Speed Power cULus MARK Max. Max. Static Air Flow Pressure Noise Mass (m3/min) (in H2O) (Pa) (dB)*1 (g) 20.48 0.58 0.61 152 47.5 210 3200 24.72 0.70 0.90 225 51.5 210 12.36 3700 28.60 0.81 1.37 342 54.5 210 16.80 5200 38.14 1.08 1.89 470 61.0 210 (min-1)*1 (CFM) *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available DC Blower Static Pressure Ps Insulation Resistance: ���
09533GA-12M-AA-00 价格&库存
很抱歉,暂时无法提供与“09533GA-12M-AA-00”相匹配的价格&库存,您可以联系我们找货
