11938ME-24P-GA-00
11938ME-24P-GA-00
    NMBTECHNOLOGIESCORPORATION
    风扇 管轴式 24VDC 方形 - 119mm 长 x 119mm 高 滚珠 181.3 CFM(5.08m³/min) 2 引线
11938ME-24P-GA-00 数据手册
NE W ! 11938MA (119 X 38L) IP69K NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: Auto Restart/Polarity Protection (Pa) 1.00 250 0.80 200 0.60 150 0.40 100 0.20 50 P-Q Curve Speed Curve Insulation Resistance: Static Pressure -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) IP Code: IP69K Ps Expected Life 25°C 0 5,000 P N 4,000 M L 3,000 K M 2,000 N P 1,000 K L 0 100,000 Hours (L10) Speed 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: 0 0 1.0 2.0 0 35.31 70.63 3.0 4.0 5.0 105.94 141.26 176.57 (m3/min) CFM Air Flow Material Outline Casing : Aluminum (Black) Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG24, +Red, -Black 11.81 .20 (5.0) NAME PLATE .20 (5.0) 4.13 (105± 0.5) 4.69 (119± 0.5) 1.51 (38.4± 0.5) 4.13 (105.0) 4.13 (105.0) 4.57 (116.0) 4.57 (116.0) INLET SIDE OUTLET SIDE Specifications MODEL Rated Operating Voltage Voltage (V) (V) Current Input Speed Power (A)*1 (W)*1 4.69 (119± 0.5) ROTATION AIR 4R6 3. 0 4.13 (105.0) 4R6 2. 0 4.57 (116.0) 4.13 (105.0) 4.57 (116.0) .17 (4- 4.3) .17 (4- 4.3) 4.13 (105± 0.5) .17 (8- 4.3± 0.2) Panel Cut-Outs inch Units: (mm) min 300 NO SOLDER Max. Max. Static Air Flow Pressure Noise (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 Mass (g) 11938MA-12K-GA-00 12 8.0 ~ 13.8 0.48 5.76 2700 102.77 2.91 0.31 76.0 45.0 400 11938MA-12L-GA-00 12 8.0 ~ 13.8 0.66 7.92 3200 122.19 3.46 0.41 102.0 49.5 400 11938MA-12M-GA-00 12 8.0 ~ 13.8 1.00 12.00 3700 141.96 4.02 0.55 136.0 53.5 400 11938MA-12N-GA-00 12 8.0 ~ 13.2 1.46 17.50 4200 162.09 4.59 0.69 173.0 56.5 400 11938MA-12P-GA-00 12 8.0 ~ 12.9 1.92 23.00 4700 181.16 5.13 0.86 213.0 59.5 400 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available Extreme Environment In H2O 11938MA (119 X 38L) IP69K NMBTC.COM / 248.919.2250 Specifications Rated Operating Voltage Voltage (V) (V) Current Input Speed Power (A)*1 (W)*1 Max. Max. Static Air Flow Pressure Noise (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 Mass (g) 11938MA-24K-GA-00 24 15.0 ~ 27.6 0.26 6.24 2700 102.77 2.91 0.31 76.0 45.0 400 11938MA-24L-GA-00 24 15.0 ~ 27.6 0.35 8.40 3200 122.19 3.46 0.41 102.0 49.5 400 11938MA-24M-GA-00 24 15.0 ~ 27.6 0.52 12.50 3700 141.96 4.02 0.55 136.0 53.5 400 11938MA-24N-GA-00 24 15.0 ~ 27.6 0.74 17.80 4200 162.09 4.59 0.69 173.0 56.5 400 11938MA-24P-GA-00 24 15.0 ~ 26.4 0.93 22.40 4700 181.16 5.13 0.86 213.0 59.5 400 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available Extreme Environment MODEL
11938ME-24P-GA-00 价格&库存
很抱歉,暂时无法提供与“11938ME-24P-GA-00”相匹配的价格&库存,您可以联系我们找货
11938ME-24P-GA-00
  • 1+385.702121+50.12298
  • 20+273.4074920+35.53000
  • 40+270.6141640+35.16700
库存:80
