NE
W
11938MA (119 X 38L)
IP69K
NMBTC.COM / 248.919.2250
Characteristic Curves
General Specifications
Motor Protection:
Auto Restart/Polarity Protection
(Pa)
1.00
250
0.80
200
0.60
150
0.40
100
0.20
50
P-Q Curve
Speed Curve
Insulation Resistance:
Static Pressure
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
IP Code: IP69K
Ps
Expected Life
25°C
P
N
4,000
M
L
3,000
K
M
2,000
N
P
1,000
K
L
100,000 Hours (L10)
Speed
10M Ω or over with a DC500V Megger
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
2.0
70.63
3.0
4.0
5.0
105.94
141.26
176.57
(m3/min)
CFM
Air Flow
Material
Outline
Casing : Aluminum (Black)
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL1007, AWG24, +Red, -Black
11.81
.20
(5.0)
NAME
PLATE
.20
(5.0)
4.13
(105± 0.5)
4.69
(119± 0.5)
1.51
(38.4± 0.5)
4.13
(105.0)
4.13
(105.0)
4.57
(116.0)
4.57
(116.0)
INLET SIDE
OUTLET SIDE
Specifications
MODEL
Rated
Operating
Voltage
Voltage
(V)
(V)
Current
Input
Speed
Power
(A)*1
(W)*1
4.69
(119± 0.5)
ROTATION
AIR
4R6
3.
(105.0)
4R6
2.
(116.0)
4.13
(105.0)
4.57
(116.0)
.17
(4- 4.3)
.17
(4- 4.3)
4.13
(105± 0.5)
.17
(8- 4.3± 0.2)
Panel Cut-Outs
inch
Units: (mm)
min 300
NO SOLDER
Max.
Max. Static
Air Flow
Pressure
Noise
(min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
Mass
(g)
11938MA-12K-GA-00
12
8.0 ~ 13.8
0.48
5.76
2700
102.77
2.91
0.31
76.0
45.0
400
11938MA-12L-GA-00
12
8.0 ~ 13.8
0.66
7.92
3200
122.19
3.46
0.41
102.0
49.5
400
11938MA-12M-GA-00
12
8.0 ~ 13.8
1.00
12.00
3700
141.96
4.02
0.55
136.0
53.5
400
11938MA-12N-GA-00
12
8.0 ~ 13.2
1.46
17.50
4200
162.09
4.59
0.69
173.0
56.5
400
11938MA-12P-GA-00
12
8.0 ~ 12.9
1.92
23.00
4700
181.16
5.13
0.86
213.0
59.5
400
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
*1: Average Values in Free Air
Note: PWM/Locked Rotor/Tach Available
Extreme Environment
In H2O
11938MA (119 X 38L)
IP69K
Specifications
Rated
Operating
Voltage
Voltage
(V)
(V)
Current
Input
Speed
Power
(A)*1
(W)*1
Max.
Max. Static
Air Flow
Pressure
Noise
Mass
(g)
11938MA-24K-GA-00
24
15.0 ~ 27.6
0.26
6.24
2700
102.77
2.91
0.31
76.0
45.0
400
11938MA-24L-GA-00
24
15.0 ~ 27.6
0.35
8.40
3200
122.19
3.46
0.41
102.0
49.5
400
11938MA-24M-GA-00
24
15.0 ~ 27.6
0.52
12.50
3700
141.96
4.02
0.55
136.0
53.5
400
11938MA-24N-GA-00
24
15.0 ~ 27.6
0.74
17.80
4200
162.09
4.59
0.69
173.0
56.5
400
11938MA-24P-GA-00
24
15.0 ~ 26.4
0.93
22.40
4700
181.16
5.13
0.86
213.0
59.5
400
Rotation: Clockwise
Extreme Environment
MODEL
很抱歉,暂时无法提供与“11938MA-24N-EA-D0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+514.358381+66.62740
- 10+411.2125910+53.26642
