12038GE-12N-YA-F0
12038GE-12N-YA-F0
    NMBTECHNOLOGIESCORPORATION
    风扇 管轴式 12VDC 圆形 - 120mm 直径 滚珠 45.0 CFM(1.26m³/min) 2 引线
12038GE-12N-YA-F0 数据手册
REFRIGERATION NE W ! 12038GE (120 X 38L) NMBTC.COM / 248.919.2250 Characteristic Curves Motor Protection: Auto Restart In H2O (Pa) .32 80 .28 70 .24 60 .20 50 .16 40 Insulation Resistance: 10M Ω or over with a DC500V Megger Static Pressure -40°C ~ +40°C (Operating) -40°C ~ +60°C (Storage) (non-condensing environment) 2,400 M N 2,100 1,800 L 1,500 1,200 N M 900 .12 30 Ps .08 20 600 .04 10 300 0 0 Expected Life -20°C Speed Curve L 70,000 Hours (L10) 0 0.2 0 7.06 0.4 0.6 0.8 1.0 1.2 1.4 (m3/min) 14.13 21.19 28.25 35.31 42.38 49.44 CFM Air Flow Material Outline 57 ) 6. 167 ( ( 5. 14 51 0± 1 ) 11.81 min (300) ( NO SOLDER 4. 12 88 4 ±0 .5 ) Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG26, +Red, -Black 9 ) 1.0 .7±5 27 (3- (3- .67 17 ± 0.5 ) 0° 12 12 0° NAME PLATE 1.1 (max 28) ROTATION 1.5 (38) .43 (11± 0.8) 4.72 ( 120.0± 1) .20 (5± 0.5) AIR .12 (3) Specifications Rated Operating Voltage Voltage (V) (V) (A)*1 (W)*1 12038GE-12L-YA-F0 12 7.0 ~ 13.2 0.15 1.80 1600 36.37 1.03 .20 50.0 32.0 175 12038GE-12M-YA-F0 12 7.0 ~ 13.2 0.21 2.52 1830 41.67 1.18 .26 64.0 36.0 175 12038GE-12N-YA-F0 12 7.0 ~ 13.2 0.24 2.88 1950 45.20 1.28 .31 76.0 38.0 175 MODEL Rotation: Clockwise Current Input Speed Power Airflow Outlet: Air Out Over Struts Max. Max. Static Air Flow Pressure Noise (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 *1: Average Values in Free Air Mass (g) Note: PWM/Locked Rotor/Tach Available DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: P-Q Curve Speed General Specifications
12038GE-12N-YA-F0 价格&库存
很抱歉,暂时无法提供与“12038GE-12N-YA-F0”相匹配的价格&库存,您可以联系我们找货
