TELECOM
NE
W
12038MA (120 X 38L)
NMBTC.COM / 248.919.2250
Characteristic Curves
Motor Protection:
Auto Restart/Polarity Protection
Insulation Resistance:
10M Ω or over with a DC500V Megger
Static Pressure
-10°C ~ +70°C (Operating)
-30°C ~ +70°C (Storage)
(non-condensing environment)
Ps
Expected Life
40°C
(Pa)
P-Q Curve
Speed Curve
4.01
1000
10,000
3.61
900
9,000
3.21
800
8,000
2.81
700
7,000
2.41
600
6,000
2.01
500
5,000
1.60
400
4,000
1.20
300
3,000
0.80
200
2,000
0.40
100
1,000
40,000 Hours (L10)
2.0
3.0
4.0
5.0
6.0 (m3/min)
70.63 105.94 141.26 176.57 211.89 CFM
Air Flow
Material
Outline
Casing : Aluminum (Black)
Impeller : Plastic (Black) UL94V-0
Bushing : Plastic (Black) UL94V-2
Bearing : Ball Bearing
Lead Wire : UL10368, AWG22, +Red, -Black
(8-
Panel Cut-Outs
.17
4.3± 0.3)
11.81
min (300)
NO SOLDER
ROTATION
4.13
(105.0)
AIR
4.13
(105.0)
PLATE
0.20
(5.0)
.604
(38.0± 0.5)
4.13
(105.0)
INLET SIDE
NAME
4.72
(120± 0.5)
.169
(4 – φ4.3)
(φ1
4.63
(117.6)
8
5.3 6.6)
3
(φ1
4.63
(117.6)
.169
(4 – φ4.3)
4.13
(105.0)
4.63
(117.6)
4.63
(117.6)
4.13
(105± 0.3)
inch
Units: (mm)
0.20
(5.0)
4.13
(105± 0.3)
4.72
(120± 0.5)
OUTLET SIDE
Specifications
MODEL
12038MA-48R-EE-00
Rotation: Clockwise
Rated
Operating
Voltage
Voltage
Current
Input
(V)
(V)
(A)*1
(W)*1
48
38.0 ~ 60.0
0.82
39.36
Speed
Power
Airflow Outlet: Air Out Over Struts
Max.
Max. Static
Air Flow
Pressure
Noise
(min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
9000
185.4
*1: Average Values in Free Air
5.25
2.97
740
72.0
Mass
(g)
580
Note: PWM/Locked Rotor/Tach Available
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
In H2O
Speed
General Specifications
很抱歉,暂时无法提供与“12038MA-48R-EE-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+605.054001+78.37566
