12537JE-12P-BA-F0
12537JE-12P-BA-F0
    NMBTECHNOLOGIESCORPORATION
    风扇 管轴式 12VDC 方形 - 125.4mm 长 x 125.4mm 高 滚珠 76.6 CFM(2.14m³/min) 2 引线
12537JE-12P-BA-F0 数据手册
REFRIGERATION NE W ! 12537JE (125 X 37L) NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: P-Q Curve In H2O Insulation Resistance: 10M Ω or over with a DC500V Megger Static Pressure -40°C ~ +40°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Ps 60 0.20 50 0.16 40 0.12 30 1,500 0.08 20 1,000 0.04 10 0 0 Expected Life -20°C 3,000 0.24 P 2,000 M M 0 0.5 0 17.66 500 P N 1.0 1.5 2.0 2.5 (m3/min) 35.31 52.97 70.63 88.29 CFM Air Flow 70,000 Hours (L10) Material Outline Casing : Plastic (Black) PBT UL94V-0 Impeller : Plastic (Black) PBT UL94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG26, +Red, -Black ROTATION 4.94 +1.0 (125.4 -1.5) 4.45 +1.0 (113.0 -1.5) .16 (4-R5) Panel Cut-Outs inch Units: (mm) 2,500 N NAME PLATE NO SOLDER .18 (4- 4.5) .18 .5 ) 4 (4- 4.45 +1.0 (113.0 -1.5) 11.81 min (300) .39 (10) 4.82 (122.4) ( 1.26 (113.0) 5 13 .12 0. 0) 4.94 +1.0 (125.4 -1.5) 1.26 (113.0) 4.82 (122.4) .79 (20± 0.5) INLET SIDE 1.46 (37± 1) Specifications MODEL Rated Operating Current Input Speed Max. Max. Static Noise Voltage Voltage Power Air Flow Pressure (V) (V) (A)*1 (W)*1 (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 Mass (g) 12537JE-12M-BA-F0 12 7.0 ~ 13.2 0.07 0.84 1900 57.21 1.62 .10 24.8 26.0 220 12537JE-12N-BA-F0 12 7.0 ~ 13.2 0.10 1.20 2300 69.22 1.96 .15 36.6 32.0 220 12537JE-12P-BA-F0 12 7.0 ~ 13.2 0.14 1.69 2550 76.63 2.17 .17 42.9 35.0 220 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available DC Axial Fans Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: Speed Curve (Pa) Speed Auto Restart
12537JE-12P-BA-F0 价格&库存
很抱歉,暂时无法提供与“12537JE-12P-BA-F0”相匹配的价格&库存,您可以联系我们找货
