15047JA-12K-YA-00
15047JA-12K-YA-00
    NMBTECHNOLOGIESCORPORATION
    FAN AXIAL 150X47MM 12VDC WIRE
15047JA-12K-YA-00 数据手册
REFRIGERATION NE W ! 15047JA (150 X 47L) NMBTC.COM / 248.919.2250 Characteristic Curves Motor Protection: Auto Restart (Pa) .16 40 .12 30 Insulation Resistance: 10M Ω or over with a DC500V Megger Static Pressure Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: J Class: -10°C ~ +70°C (Operating) K Class: -10°C ~ +60°C (Operating) All Class: -40°C ~ +70°C (Storage) (non-condensing environment) P-Q Curve Speed Curve 1,800 K Class .08 20 .04 10 0 0 800 400 K Class Ps J Class Expected Life 25°C 1,200 J Class 100,000 Hours (L10) 0 0.5 1.0 0 17.66 35.31 1.5 2.0 52.97 70.63 2.5 3.0 88.29 105.94 (m3/min) CFM Air Flow Material Outline Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG24, +Red, -Black ROTATION 3.94 (100± 0.1) 5.91 (150+1 -2 ) 1 ) .8 00 11 (3 in m Panel Cut-Outs .24 (MAX 6) AIR NAME PLATE inch Units: (mm) 3.94 (100± 0.1) 1.06 (27± 0.8) 1.85 (47± 0.1) 5 14 .71 5. 0) 5.91 (150+1 -2 ) ( ROTATION .24 (MAX 6) 3.94 (100± 0.1) 5.91 (150+1 -2 ) 1 ) .8 00 11 (3 n i m AIR NAME PLATE INLET SIDE 3.94 (100± 0.1) 1.06 (27± 0.8) 1.85 (47± 0.1) 5.91 (150+1 -2 ) Specifications Rated Operating Voltage Voltage (V) (V) (A)*1 (W)*1 15047JA-12J-YA-00 12 8.0 ~ 13.8 0.12 1.44 1150 75.93 2.15 .06 14.6 25.5 315 15047JA-12K-YA-00 12 8.0 ~ 13.8 0.19 2.28 1400 91.82 2.60 .09 21.5 32.0 315 MODEL Rotation: Clockwise DC Axial Fans In H2O Speed General Specifications Current Input Speed Power Airflow Outlet: Air Out Over Struts Max. Max. Static Air Flow Pressure Noise (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 *1: Average Values in Free Air Mass (g) Note: PWM/Locked Rotor/Tach Available
15047JA-12K-YA-00 价格&库存
很抱歉,暂时无法提供与“15047JA-12K-YA-00”相匹配的价格&库存,您可以联系我们找货
