82400-4-UV-B
82400-4-UV-B
    O.C.WHITE
    灯,放大镜 4 度屈光(2x),7.00" 长 x 5.25" 宽(177.80mm x 133.35mm) LED,白色
82400-4-UV-B 数据手册
6” Round Crown White Glass The Green-Lite® series from O.C. White is the most energy efficient, highest output and longest lasting line of inspection lighting systems in the world. These exceptionally designed products offer important features & benefits available only from O.C. White. 42400-4-BY FEATURES: l l l l l l Arm Reach P 41300-5 P 41400-4 P 41400-5 P 41600-4 P 41600-5 P 5 Diopter (2.25x) Screw Down Table Edge Clamp P P P P 42400-4 P 42400-5 P 42600-4 P 42600-5 P BO Weighted Base BR P P P BY P P 42300-5 MW P P P S Mounting Style P 42300-4 CM P P P P P IN THE DE A US 41300-4 43” 4 Diopter (2x) RG DO 30” Magnification SB W IT H Part Number SW TS l B PA R l M ES GN l Standard 4 Diopter (2x) and optional 5 Diopter (2.25x) for optimum balance of magnification & working distance Highest lumen output in a lighted magnifier User controlled LED groups shine desired level of light exactly where required Superb dimming software via convenient, reliable membrane switch Precision ground, 6” round optical grade glass Color must be 6 LEDs standard – 12 LEDS models optional specified at time of order Auto shut off after 4 hours helps prevent energy waste (user activated after purchase) Add Color Code to End of High quality die cast aluminum shades and all metal arm Part Number components for ESD safety Example: Innovative 3 axis adjustable swivel arm 42400-4-BY 5 Year mechanical warranty… best in the business! MA l TIC & FOR EI P P P P P P P P Optional Add-On Lenses: 4 Diopter (1x) “AO-4D” and 6 Diopter (1.5x) “AO-6D” See our complete product lineup at: www.ocwhite.com or call 413-289-1751 O.C. White Co., 4226 Church St., Thorndike, MA 01079 ESD SAFE
82400-4-UV-B 价格&库存
很抱歉,暂时无法提供与“82400-4-UV-B”相匹配的价格&库存,您可以联系我们找货
82400-4-UV-B
库存:56
