UV2000-B
UV2000-B
    O.C.WHITE
    LED 环形管灯
UV2000-B 数据手册
American Designed, American Craftsmanship BONKOTE AMERICA Flux Dispensing Pens These new handy Bon Pens allow for very accurate flux dispensing on the work area, while eliminating dripping and flooding. You have total control at your finger tips, unlike all of the messy dispensing bottles on the market. Made in Japan. Very easily cleaned and maintained with alcohol or water, depending on Flux use. • Re-usable flux applicator • Replaceable tips & cartridge • Low cost, 7CC capacity • Fine point or broad point • Flexible shafts • Controlled application / no mess • Used with non-wash, wash or strong acid flux • Excellent for spot soldering on IC chips • All units sold in 5 packs Replacement Tips N NYLO 102T BON N NYLO 102K BON N NYLO 102D BON FELT 102F BON FELT 102B BON N NYLO 102S BON N NYLO 102 BON ge rtrid nt Ca ceme epla 02 R CA-1 See the Complete Lineup at www.ocwhite.com Distributed By: or Call: 413-289-1751 for a Representative Near You OCWMAINCAT-0916 2017 Industrial Catalog Green-Lite ® L E D I N S P E C T I O N AMERICAN DESIGNED, AMERICAN CRAFTSMANSHIP. M A G N I F I E R S Patent #D723,081 S The Industry Standard The Dollars and Sense of Buying Quality Best Return On Investment 82400-4-USA The Green-Lite® series from O.C. White is the world’s most energy efficient, highest output, and longest lasting line of professional inspection magnifiers. Immediate improvements in productivity and quality control inspection equal real bottom line savings. Intuitive Lighting Controls Our specialized rugged membrane switch controls all aspects of lighting. Our patented features include 100-5% dimming, 5 specialized contrast lit views, integrated shut-off timer for energy savings, and light memory… complete control is at your fingertips. This multifunction membrane is also back-lit for increased visibility in darker installations. DIMMABLE: Control Lighting Intensity Smoothly - 5% to 100% CONTRAST: Control Lighting Contrast Quickly - 5 Contrast Views Optional Add-On Lenses 4 Diopter (2x) AO-4D & 6 Diopter (2.5x) AO-6D with Silicone gasket Crown White Glass ESD SAFE Productivity Improvement With unmatched standard 4 Diopter (2x) magnification & advanced lighting controls, let us help you catch in-process defects before they reach your customer 2 Standard in all O.C. White models, this highest resolution glass puts us leaps and bounds ahead of competition who continue to choose poor quality green tinted glass. If crystal clear resolution and superb color rendition are critical to your inspection, only O.C. White can satisfy. Unmatched Efficiency With efficiency being a paramount concern in today’s manufacturing environment, all Green-Lite® models are up to the task. Our 12 LED models consume only 8w at high, and our 6 LED models consume a mere 4 watts! Lighting Specifications: Optical Specifications: Exceeds all other magnifiers with over (4X) the lumen output of competition. Precision ground, crown white optical grade glass provides the highest image resolution with no ghosting or chromatic separation. • Reduced glare, heat and energy consumption • Multi-angle LEDs for shadowless lighting at a full range of focal lengths and heights • User controlled LED groups shine contrasting light exactly where required • Auto-Timer shut-off (user activated) • Low 24v design makes this the world’s safest Benefits: • No Bulbs = $0 Replacement Cost • Ideal color temperature for accurate colors • Reduction or elimination of eyestrain • More easily see defects during QA • The largest lenses in the industry. • Four lens sizes to choose from:  7” x 5.25” Rectangle Lens  7.5” Round Lens  6” Round Lens  5” Round Lens • Standard 4 diopter (2x) lens (an O.C. White exclusive)  Optional (2.25X) lens available Benefits: • Best balance of working distance, magnification and field of view • Most lens size choices in the industry • Unrivaled lens clarity • See what you’ve been missing 3 Green-Lite ® L E D I N S P E C T I O N AMERICAN DESIGNED, AMERICAN CRAFTSMANSHIP. M A G N I F I E R S Patent #D723,081 S The Industry Standard The Dollars and Sense of Buying Quality Best Return On Investment 82400-4-USA The Green-Lite® series from O.C. White is the world’s most energy efficient, highest output, and longest lasting line of professional inspection magnifiers. Immediate improvements in productivity and quality control inspection equal real bottom line savings. Intuitive Lighting Controls Our specialized rugged membrane switch controls all aspects of lighting. Our patented features include 100-5% dimming, 5 specialized contrast lit views, integrated shut-off timer for energy savings, and light memory… complete control is at your fingertips. This multifunction membrane is also back-lit for increased visibility in darker installations. DIMMABLE: Control Lighting Intensity Smoothly - 5% to 100% CONTRAST: Control Lighting Contrast Quickly - 5 Contrast Views Optional Add-On Lenses 4 Diopter (2x) AO-4D & 6 Diopter (2.5x) AO-6D with Silicone gasket Crown White Glass ESD SAFE Productivity Improvement With unmatched standard 4 Diopter (2x) magnification & advanced lighting controls, let us help you catch in-process defects before they reach your customer 2 Standard in all O.C. White models, this highest resolution glass puts us leaps and bounds ahead of competition who continue to choose poor quality green tinted glass. If crystal clear resolution and superb color rendition are critical to your inspection, only O.C. White can satisfy. Unmatched Efficiency With efficiency being a paramount concern in today’s manufacturing environment, all Green-Lite® models are up to the task. Our 12 LED models consume only 8w at high, and our 6 LED models consume a mere 4 watts! Lighting Specifications: Optical Specifications: Exceeds all other magnifiers with over (4X) the lumen output of competition. Precision ground, crown white optical grade glass provides the highest image resolution with no ghosting or chromatic separation. • Reduced glare, heat and energy consumption • Multi-angle LEDs for shadowless lighting at a full range of focal lengths and heights User controlled LED groups shine contrasting • light exactly where required • Auto-Timer shut-off (user activated) • Low 24v design makes this the world’s safest Benefits: • No Bulbs = $0 Replacement Cost • Ideal color temperature for accurate colors • Reduction or elimination of eyestrain • More easily see defects during QA • The largest lenses in the industry. • Four lens sizes to choose from: • 7” x 5.25” Rectangle Lens • 7.5” Round Lens • 6” Round Lens • 5” Round Lens Standard 4 diopter (2x) lens • (an O.C. White exclusive) • Optional (2.25X) lens available Benefits: • Best balance of working distance, magnification and field of view • Most lens size choices in the industry • Unrivaled lens clarity • See what you’ve been missing 3 Green-Lite ® L E D I N S P E C T I O N AMERICAN DESIGNED, AMERICAN CRAFTSMANSHIP. M A G N I F I E R S Quality Comes Standard! Pure Durability Delivers Low Cost of Ownership! Better By Design 82400-4-SB ESD SAFE Plenty of reach for the widest range of inspection. With any world class product, it is no individual detail that reigns supreme. To be the best, every aspect of your product needs to be industry leading. From offering the largest and clearest lenses available, to energy consumption 8 watts and under, robust military-grade mechanical construction and light adjustability never before available, you owe it to yourself to only use the best. Every model is built standard with 100-240v (50/60hz) auto switching transformer for worldwide use, so now companies with worldwide manufacturing sites can standardize their visual inspection with no worries. Heavy-Duty Arms High strength extruded aluminum design for ultimate precision and holding power. Magnification Standard 4 Diopter (2x) for optimum balance of magnification and working distance. 82400-4-MW shown on optional 11469-MW Base 82400-4-BR / 43” Arm ESD SAFE No-Tip Rolling Stand Roll your magnifier from task to task with ease. The No-Tip base features 6 large diameter caster wheels and a 35 lb. counter-weight for smooth and safe movement. ESD SAFE 81600-4 / 30” Arm with Weighted Base Built for smaller footprint applications. Hi-Tech Shade Industrial grade die-cast aluminum shade doubles as a heat-sink providing long LED life and comfortable handles for maneuverability. Single Piece CNC Machined Base Block High strength at a critical joint for long life and image stability. 4 ESD SAFE 82400-4-UV / Ultraviolet Featuring 8 UV LEDs (395nm) ganged with 4 White LEDs. Easily switch from UV-left, UV-right, White only and UV with White light. UV ONLY WHITE ONLY WHITE & UV Choice of 10 Standard Finishes B RG SB CM S MW SW BY BO BR 5 Green-Lite ® L E D I N S P E C T I O N AMERICAN DESIGNED, AMERICAN CRAFTSMANSHIP. M A G N I F I E R S Quality Comes Standard! Pure Durability Delivers Low Cost of Ownership! Better By Design 82400-4-SB ESD SAFE Plenty of reach for the widest range of inspection. With any world class product, it is no individual detail that reigns supreme. To be the best, every aspect of your product needs to be industry leading. From offering the largest and clearest lenses available, to energy consumption 8 watts and under, robust military-grade mechanical construction and light adjustability never before available, you owe it to yourself to only use the best. Every model is built standard with 100-240v (50/60hz) auto switching transformer for worldwide use, so now companies with worldwide manufacturing sites can standardize their visual inspection with no worries. Heavy-Duty Arms High strength extruded aluminum design for ultimate precision and holding power. Magnification Standard 4 Diopter (2x) for optimum balance of magnification and working distance. 82400-4-MW shown on optional 11469-MW Base 82400-4-BR / 43” Arm ESD SAFE No-Tip Rolling Stand Roll your magnifier from task to task with ease. The No-Tip base features 6 large diameter caster wheels and a 35 lb. counter-weight for smooth and safe movement. ESD SAFE 81600-4 / 30” Arm with Weighted Base Built for smaller footprint applications. Hi-Tech Shade Industrial grade die-cast aluminum shade doubles as a heat-sink providing long LED life and comfortable handles for maneuverability. Single Piece CNC Machined Base Block High strength at a critical joint for long life and image stability. 4 ESD SAFE 82400-4-UV / Ultraviolet Featuring 8 UV LEDs (395nm) ganged with 4 White LEDs. Easily switch from UV-left, UV-right, White only and UV with White light. UV ONLY WHITE ONLY WHITE & UV Choice of 10 Standard Finishes B RG SB CM S MW SW BY BO BR 5 Green-Lite ® L E D I N S P E C T I O N AMERICAN DESIGNED, AMERICAN CRAFTSMANSHIP. M A G N I F I E R S Patent #D656,527 S Bigger IS Better! One BIG Beautiful Magnifier. The 7.5” LED Big Eye™ The Biggest in the Industry! ESD SAFE Viewing Area Than Standard 5” Round Magnifiers Lighting Control Heavy-Duty Arms Specialized membrane switch provides smooth light level control from 100%-5% with special contrast and timer functions built-in. High strength extruded aluminum design for ultimate precision & holding power. 7.5” ROUND Crown White Glass Huge Optical Quality Lens for the widest working view with the highest visual resolution available anywhere. Hi-Tech Shade Industrial grade die-cast aluminum heat-sink shade provides long LED life and easy handling. Up to 225% LARGER 62400-4-BO 12 LED Equipped with the largest, highest resolution lens available, this next generation, surface mount LEDs, is the new standard for illuminated magnifiers. Quickly pays for itself with superior productivity and energy savings. Features the highest lumen output in a lighted magnifier, the user controlled LED groups shine desired level of light and illumination contrast exactly how and where you need it. Standard 5” Round 19.625 in2 % 87 BIGGER % 225 BIGGER 7” x 5.25” Rectangle 36.75 in2 7.5” Round 44.14 in2 % 44 BIGGER 6” Round 28.26 in2 NO COMPARISON: HEAD TO HEAD SHOWDOWN 22400-4-BY 5” Round 6 LED 42400-4-SB 6” Round 6 LED It doesn’t get any clearer than this! Shown below is our best-selling Green-Lite® Rectangle LED magnifier lens, next to a leading competitor’s largest rectangle magnifier lens. A Full 33% Thicker Glass! The Industry’s Biggest Glass Comes Standard! Green-Lite® RECTANGLE ESD SAFE 6” Round Magnifier with 6 LEDs 6” Round with 12 LEDs also available 6 ESD SAFE 5” Round Magnifier with 6 LEDs % 21 LARGER Field of View COMPETITOR’S LARGEST RECTANGLE 7 Green-Lite ® L E D I N S P E C T I O N AMERICAN DESIGNED, AMERICAN CRAFTSMANSHIP. M A G N I F I E R S Patent #D656,527 S Bigger IS Better! One BIG Beautiful Magnifier. The 7.5” LED Big Eye™ The Biggest in the Industry! ESD SAFE Viewing Area Than Standard 5” Round Magnifiers Lighting Control Heavy-Duty Arms Specialized membrane switch provides smooth light level control from 100%-5% with special contrast and timer functions built-in. High strength extruded aluminum design for ultimate precision & holding power. 7.5” ROUND Crown White Glass Huge Optical Quality Lens for the widest working view with the highest visual resolution available anywhere. Hi-Tech Shade Industrial grade die-cast aluminum heat-sink shade provides long LED life and easy handling. Up to 225% LARGER 62400-4-BO 12 LED Equipped with the largest, highest resolution lens available, this next generation, surface mount LEDs, is the new standard for illuminated magnifiers. Quickly pays for itself with superior productivity and energy savings. Features the highest lumen output in a lighted magnifier, the user controlled LED groups shine desired level of light and illumination contrast exactly how and where you need it. Standard 5” Round 19.625 in2 % 87 BIGGER % 225 BIGGER 7” x 5.25” Rectangle 36.75 in2 7.5” Round 44.14 in2 % 44 BIGGER 6” Round 28.26 in2 NO COMPARISON: HEAD TO HEAD SHOWDOWN 22400-4-BY 5” Round 6 LED 42400-4-SB 6” Round 6 LED It doesn’t get any clearer than this! Shown below is our best-selling Green-Lite® Rectangle LED magnifier lens, next to a leading competitor’s largest rectangle magnifier lens. A Full 33% Thicker Glass! The Industry’s Biggest Glass Comes Standard! Green-Lite® RECTANGLE ESD SAFE 6” Round Magnifier with 6 LEDs 6” Round with 12 LEDs also available 6 ESD SAFE 5” Round Magnifier with 6 LEDs % 21 LARGER Field of View COMPETITOR’S LARGEST RECTANGLE 7 Vision-Lite Magnilite ® SHADOWLESS FLUORESCENT MAGNIFIER FLUORESCENT INSPECTION MAGNIFIERS Machining Perfection Keeps Getting Better The Perfect Inspection Tool for the Machining Industry The Largest Round Lens Fluorescent Magnifier Available for Industry Heavy-Duty Arms World’s Only High strength extruded aluminum design for ultimate precision & holding power. Choice of 30” and 43” reach Unrivaled Lens Size TRUE RECTANGULAR Magnification Huge 7.5” Round 4 Diopter (2x) crown white glass lens provides the clearest and widest field of view M A G N I F I E R A DIFFERENCE YOU CAN TRUELY SEE! Exclusive 3 Diopter (1.75x) TRUE Rectangular lens provides vivid resolution and clarity with zero distortion edge to edge 7.5 x 6.25” Crown White Glass Excellent optics for excellent inspection. . Big Eye™ T5 Fluorescent Magnifier ESD SAFE In a World of Copycats and Knockoffs, Vision-Lite® is a Groundbreaker. One of the key design features is the ONLY TRUE RECTANGULAR LENS. All other manufacturers who advertise ‘rectangular’ magnifiers are only telling you half the truth. What they are offering is a round lens, with two sides cut flat. You still get edge distortion, and other less desirable optical effects from this. With Vision-Lite® you can get the same level of clarity side to side… we dare you to compare! 8 SEEING IS BELIEVING Our Glass is BETTER! Thicker and More Poweful! % 39 TALLER Compared to Competitors VIEWING AREA COMPETITOR’S LARGEST RECTANGLE 52400-4 This classic design features an updated slim T5 bulb and high output electronic transformer. Available in standard 4 Diopter (2x) as well as optional 5 Diopter (2.25x) lens. We have also slimmed the overall height of the shade for a sleeker appearance and better functionality. ESD Safe. 72400-B See the Difference for Yourself This excellent inspection tool is perfect for the machining industry. If you are inspecting polished metal components, exotic materials, or if inspecting surface quality are key to your job, the Vision-Lite® has no equal. The unique 3-sided bulb offers soft, shadowless illumination that will make the smallest details stand out. ® ESD SAFE Heavy-Duty Arms High strength extruded aluminum design for ultimate precision & holding power. Choice of 30” and 43” reach arms. Standard Magnilite® 5” Round Magnifier Our original Magnilite®… an industrial standard since the 1960s. This model has also been updated to include heavy duty tri-axis die cast locking swivel and new electronic transformer. Available in standard 3 Diopter (1.75x) as well as 5 Diopter (2.25x). ESD Safe 32400 ESD SAFE 9 Vision-Lite Magnilite ® SHADOWLESS FLUORESCENT MAGNIFIER FLUORESCENT INSPECTION MAGNIFIERS Machining Perfection Keeps Getting Better The Perfect Inspection Tool for the Machining Industry The Largest Round Lens Fluorescent Magnifier Available for Industry Heavy-Duty Arms World’s Only High strength extruded aluminum design for ultimate precision & holding power. Choice of 30” and 43” reach Unrivaled Lens Size TRUE RECTANGULAR Magnification Huge 7.5” Round 4 Diopter (2x) crown white glass lens provides the clearest and widest field of view M A G N I F I E R A DIFFERENCE YOU CAN TRUELY SEE! Exclusive 3 Diopter (1.75x) TRUE Rectangular lens provides vivid resolution and clarity with zero distortion edge to edge 7.5 x 6.25” Crown White Glass Excellent optics for excellent inspection. . Big Eye™ T5 Fluorescent Magnifier ESD SAFE In a World of Copycats and Knockoffs, Vision-Lite® is a Groundbreaker. One of the key design features is the ONLY TRUE RECTANGULAR LENS. All other manufacturers who advertise ‘rectangular’ magnifiers are only telling you half the truth. What they are offering is a round lens, with two sides cut flat. You still get edge distortion, and other less desirable optical effects from this. With Vision-Lite® you can get the same level of clarity side to side… we dare you to compare! 8 SEEING IS BELIEVING Our Glass is BETTER! Thicker and More Poweful! % 39 TALLER Compared to Competitors VIEWING AREA COMPETITOR’S LARGEST RECTANGLE 52400-4 This classic design features an updated slim T5 bulb and high output electronic transformer. Available in standard 4 Diopter (2x) as well as optional 5 Diopter (2.25x) lens. We have also slimmed the overall height of the shade for a sleeker appearance and better functionality. ESD Safe. 72400-B See the Difference for Yourself This excellent inspection tool is perfect for the machining industry. If you are inspecting polished metal components, exotic materials, or if inspecting surface quality are key to your job, the Vision-Lite® has no equal. The unique 3-sided bulb offers soft, shadowless illumination that will make the smallest details stand out. ® ESD SAFE Heavy-Duty Arms High strength extruded aluminum design for ultimate precision & holding power. Choice of 30” and 43” reach arms. Standard Magnilite® 5” Round Magnifier Our original Magnilite®… an industrial standard since the 1960s. This model has also been updated to include heavy duty tri-axis die cast locking swivel and new electronic transformer. Available in standard 3 Diopter (1.75x) as well as 5 Diopter (2.25x). ESD Safe 32400 ESD SAFE 9 Ultra Exhaust Task Lighting HIGH OUTPUT BENCH & FUME FAN UNMATCHED INDUSTRIAL QUALITY Making Light Work World’s Best Bench Fan Longline® Draftsman Lamp 20700 While the days of mechanical drafting by pencil and table might be behind us, the need for quality task lighting isn’t. It is more critical than ever to have proper light on your work surface. Parts are getting smaller, and real production time costs are increasingly scrutinized. For welding or large fume removal jobs, our 550 CFM unit blows it all away. The UL/CSA fan and finger guards provide excellent protection from both operator, and debris. Fan may be adjusted to move air in either direction. Mounted on our 43” long Ultraflex® arms for dependability, strength and easy movement. Standard overhead 4ft. bench lighting simply doesn’t provide adequate light at the work surface. Our twin tube, 30 watt Longline® has set the standard for quality, function, and durability. A superior multiform one-piece stamped steel shade offers utmost rigidity and heft in any industrial lighting application. Our die-cast triple axis adjustable swivel assembly ensures that the light will stay where you set it. Ships with (2) 15W HO fluorescent tubes. 120V only ESD SAFE Machinists Heavy Duty Task Light 25800 Heavy Gauge Handspun Shade Rigid 8” spun aluminum shade with vertical heat venting offers high performance with bright white reflective inner liner Single Piece CNC Machined Base Block High strength at a critical joint ESD SAFE 10 Ultra Exhaust is the Ultimate Bench Exhaust Fan! A shop floor staple, our heavy duty machinists task light has been proudly helping machinists and other shop floor production engineers illuminate their work since the 1960s. This industrial quality light has provided unwavering durability and operation in the harshest of environments, at an attractive price. The light features our handspun 8” rigid aluminum shade with venting and bright white inner liner for light reflectivity. This liner also helps isolate heat from the bulb, so it keeps the shade cool to the touch! Bulb is not included with this light, but it will readily accept most incandescent, compact fluorescent (CFL) and new LED screw in bulbs. We have also updated this light with new die-cast triple axis adjustable swivel and one-piece CNC machined base pin. See the quality difference for yourself! This is the most robust, highest quality exhaust fan you can find on the market, bar none. Fume Absorber Exhaust Fan with Activated Carbon Filter 50010 • ESD Safe • 10” 550 CFM fan with UL/CSA dual finger guards • Heavy cast 10” housing for maximum airflow • 43” Ultraflex® Arm Reach • New die-cast 3 axis locking swivel for ultimate articulation • 5 Year Mechanical Warranty • 120V Only ESD SAFE 50020 Our ESD Safe fume absorber fan features an activated carbon filter, which neutralizes hundreds of noxious fumes that would otherwise cause headaches, nausea and eye irritation. Competitive units are not activated carbon… a major performance difference. 5” 100 CFM fan may be positioned easily from either side to keep your work area fume free and uncluttered. All Metal Construction with ESD Safety. 120V Only. ESD SAFE 11 Ultra Exhaust Task Lighting HIGH OUTPUT BENCH & FUME FAN UNMATCHED INDUSTRIAL QUALITY Making Light Work World’s Best Bench Fan Longline® Draftsman Lamp 20700 While the days of mechanical drafting by pencil and table might be behind us, the need for quality task lighting isn’t. It is more critical than ever to have proper light on your work surface. Parts are getting smaller, and real production time costs are increasingly scrutinized. For welding or large fume removal jobs, our 550 CFM unit blows it all away. The UL/CSA fan and finger guards provide excellent protection from both operator, and debris. Fan may be adjusted to move air in either direction. Mounted on our 43” long Ultraflex® arms for dependability, strength and easy movement. Standard overhead 4ft. bench lighting simply doesn’t provide adequate light at the work surface. Our twin tube, 30 watt Longline® has set the standard for quality, function, and durability. A superior multiform one-piece stamped steel shade offers utmost rigidity and heft in any industrial lighting application. Our die-cast triple axis adjustable swivel assembly ensures that the light will stay where you set it. Ships with (2) 15W HO fluorescent tubes. 120V only ESD SAFE Machinists Heavy Duty Task Light 25800 Heavy Gauge Handspun Shade Rigid 8” spun aluminum shade with vertical heat venting offers high performance with bright white reflective inner liner Single Piece CNC Machined Base Block High strength at a critical joint ESD SAFE 10 Ultra Exhaust is the Ultimate Bench Exhaust Fan! A shop floor staple, our heavy duty machinists task light has been proudly helping machinists and other shop floor production engineers illuminate their work since the 1960s. This industrial quality light has provided unwavering durability and operation in the harshest of environments, at an attractive price. The light features our handspun 8” rigid aluminum shade with venting and bright white inner liner for light reflectivity. This liner also helps isolate heat from the bulb, so it keeps the shade cool to the touch! Bulb is not included with this light, but it will readily accept most incandescent, compact fluorescent (CFL) and new LED screw in bulbs. We have also updated this light with new die-cast triple axis adjustable swivel and one-piece CNC machined base pin. See the quality difference for yourself! This is the most robust, highest quality exhaust fan you can find on the market, bar none. Fume Absorber Exhaust Fan with Activated Carbon Filter 50010 • ESD Safe • 10” 550 CFM fan with UL/CSA dual finger guards • Heavy cast 10” housing for maximum airflow • 43” Ultraflex® Arm Reach • New die-cast 3 axis locking swivel for ultimate articulation • 5 Year Mechanical Warranty • 120V Only ESD SAFE 50020 Our ESD Safe fume absorber fan features an activated carbon filter, which neutralizes hundreds of noxious fumes that would otherwise cause headaches, nausea and eye irritation. Competitive units are not activated carbon… a major performance difference. 5” 100 CFM fan may be positioned easily from either side to keep your work area fume free and uncluttered. All Metal Construction with ESD Safety. 120V Only. ESD SAFE 11 Ultima EPS Ultima SMS ™ ™ ERGONOMIC PRODUCTION SOLUTIONS Workplace Ergonomics 101 Maximize Efficiency and Operator Comfort A pretty simple concept, but with far reaching implications. Ultima™ EPS marries our award-winning arm technology and world renowned lighting and inspection products together for industry exclusive performance and ultimate ergonomic safety. Custom Fit to Each Operator No two users are alike… let Ultima™ EPS show you that this is no longer an issue. Ultimate adjustability and repositioning allows for users of all heights to quickly and precisely set the inspection tool to their desired location. Free Up Work Space Is your bench STUFFED? Let Ultima™ liberate your work space! Bulky microscope stands, small instrumentation, user input controls… get them all up and out of the way! Keyboard & Mouse Tray SCALABLE MONITOR SUPPORT Professional Grade Scalable Monitor Support for Industry “Future-Proof” Scalable Design Scaleable to meet both today’s needs and room for growth tomorrow. Modular function means you’re only limited by your imagination. SMS-LD-1 Holds Up To (6) 20 lb. Screens At Once! When we say professional grade, we mean it. Our robust build quality allows for up to 120 lbs. of monitors to be mounted at once. Integral Wire Management Declutter your workspace with our specialized internal wiring channels. Copyholder SMS-LD-2 Many Additional Accessories! Contact Us for More Details 12 SMS-LD-3 SMS-LD-4 SMS-LD-5 SMS-LD-6 13 Ultima EPS Ultima SMS ™ ™ ERGONOMIC PRODUCTION SOLUTIONS Workplace Ergonomics 101 Maximize Efficiency and Operator Comfort A pretty simple concept, but with far reaching implications. Ultima™ EPS marries our award-winning arm technology and world renowned lighting and inspection products together for industry exclusive performance and ultimate ergonomic safety. Custom Fit to Each Operator No two users are alike… let Ultima™ EPS show you that this is no longer an issue. Ultimate adjustability and repositioning allows for users of all heights to quickly and precisely set the inspection tool to their desired location. Free Up Work Space Is your bench STUFFED? Let Ultima™ liberate your work space! Bulky microscope stands, small instrumentation, user input controls… get them all up and out of the way! Keyboard & Mouse Tray SCALABLE MONITOR SUPPORT Professional Grade Scalable Monitor Support for Industry “Future-Proof” Scalable Design Scalable to meet both today’s needs and room for growth tomorrow. Modular function means you’re only limited by your imagination. SMS-LD-1 Holds Up To (6) 20 lb. Screens At Once! When we say professional grade, we mean it. Our robust build quality allows for up to 120 lbs. of monitors to be mounted at once. Integral Wire Management Declutter your workspace with our specialized internal wiring channels. Copyholder SMS-LD-2 Many Additional Accessories! Contact Us for More Details 12 SMS-LD-3 SMS-LD-4 SMS-LD-5 SMS-LD-6 13 High Output LED Machine I P 6 7 14 R A T E D L I N E A R M A C H I N E L E D L I G H T I N G 15 High Output LED Machine I P 6 7 14 R A T E D L I N E A R M A C H I N E L E D L I G H T I N G 15 High Output LED Machine I P 6 7 R A T E D L I N E A R M A C H I N E L E D L I G H T I N G SERIOUSLY BRIGHT! Our Industrial Strength Break-Through Military Grade Construction Low Voltage with Worldwide Appeal The O.C. White High Output LED linear machine light represents the pinnacle of American made quality, sleek design, and outstanding performance. The solid die-cast aluminum body construction is for more than just show! It is an integral feature of this light, acting as the heat sink for the LED arrays. This light also features tempered safety glass and a slim, nickel plated bezel. It is engineered to withstand even the harshest conditions. Unlike the plastic and thin-walled extrusions our competitors use, this light is made to last a lifetime. This light can be used on virtually any mill, lathe, grinder, or a variety of other machines in service across the world. Our solid state LED design runs at 24V DC, which increases operator safety compared to 110/220v lighting! Each light only consumes 38w (1.6A) also making it one of the most efficient. 90 ° R OTATI O N Adjustable To Any Angle You can adjust the angle of light 45° in each direction (90° total). This opens up limitless installation possibilities, while still putting the light exactly where you want it. Tru Tech Revolution T23X shown with LED-1936 Lighting Exclusive Quick Magnetic Mount or Permanent Installation With O.C. White, the choice is yours. Each mounting foot comes complete with a pair of high strength Neodymium magnets preinstalled. These allow for a quick magnet mount installation. Limitless Installation Possibilities The specialized design of this light allows for up to (3) fixtures to be run from a single power point. This drastically reduces wire clutter and affords a much faster installation. Standard Configuration LED-1936-24V 19.0 in / 483 mm 2.5 in / 64 mm Our Super High Output LED linear machine lighting is the most energy efficient, highest output, and longest lasting machine tool lighting in the world. It will quickly pay for itself through lower operating costs, longer lifespans and improved productivity. Die-cast aluminum body with tempered safety glass ensures reliable performance in the harshest environments. P/N: LED-1936 1 Light 24V DC Kit P/N: 13065 24V Cable (12 ft / 3.7 m) 14.5 in / 368 mm “Green” Long Before It Was Fashionable LED-1936-120V This light features exclusive “Patent Pending” thermal dimming controls. If the light gets too hot, it will automatically dim itself to cool down, and greatly extend its service life. Also due to our best-in-class engineering, these fixtures have TWICE the light output from the same wattage compared to our competition, and far exceeds the old style fluorescent lights. P/N: LED-1936 1 Light AC Kit Optional Configuration LED-1936-2-24V P/N: LED-1936 2 Light 24V DC Kit P/N: 13065 24V Cable (12 ft / 3.7 m) LIGHT OUTPUT at 18” (45.75 cm) LIGHT OUTPUT at 36” (91.5 cm) LED-1936-2-120V P/N: 13113-2 100-240V Power Supply (12ft. / 3.7m) P/N: LED-1936 3 Light 24V DC Kit P/N: 13065 24V Cable (12 ft / 3.7 m) LED-1936-3-120V 3 Light 120V AC Kit P/N: LED-1936 P/N: 13063 Interconnect Cable (6 ft / 1.8 m) P/N: LED-1936 2 Light 120V AC Kit LED-1936-3-24V P/N: LED-1936 P/N: 13063 Interconnect Cable (6 ft / 1.8 m) P/N: LED-1936 P/N: 13063 Interconnect Cable (6 ft / 1.8 m) P/N: LED-1936 P/N: 13113-3 100-240V Power Supply (12ft. / 3.7m) 16 3.38 in / 86 mm P/N: 13113-2 100-240V Power Supply (12ft. / 3.7m) P/N: 13070 Extension Cable (6 ft / 1.8 m) Use in between interconnect cable and light P/N: LED-1936 P/N: 13063 Interconnect Cable (6 ft / 1.8 m) 4.00 in / 102mm 4.76 in / 121mm Mounting Holes P/N: LED-1936 P/N: 13063 Interconnect Cable (6 ft / 1.8 m) P/N: LED-1936 P/N: 13063 Interconnect Cable (6 ft / 1.8 m) P/N: DIM-1936 Dimmer Module and Cord (6 ft / 1.8 m) Install in-line to add dimmer function 17 High Output LED Machine I P 6 7 R A T E D L I N E A R M A C H I N E L E D L I G H T I N G SERIOUSLY BRIGHT! Our Industrial Strength Break-Through Military Grade Construction Low Voltage with Worldwide Appeal The O.C. White High Output LED linear machine light represents the pinnacle of American made quality, sleek design, and outstanding performance. The solid die-cast aluminum body construction is for more than just show! It is an integral feature of this light, acting as the heat sink for the LED arrays. This light also features tempered safety glass and a slim, nickel plated bezel. It is engineered to withstand even the harshest conditions. Unlike the plastic and thin-walled extrusions our competitors use, this light is made to last a lifetime. This light can be used on virtually any mill, lathe, grinder, or a variety of other machines in service across the world. Our solid state LED design runs at 24V DC, which increases operator safety compared to 110/220v lighting! Each light only consumes 38w (1.6A) also making it one of the most efficient. 90 ° R OTATI O N Adjustable To Any Angle You can adjust the angle of light 45° in each direction (90° total). This opens up limitless installation possibilities, while still putting the light exactly where you want it. Tru Tech Revolution T23X shown with LED-1936 Lighting Exclusive Quick Magnetic Mount or Permanent Installation With O.C. White, the choice is yours. Each mounting foot comes complete with a pair of high strength Neodymium magnets preinstalled. These allow for a quick magnet mount installation. Limitless Installation Possibilities The specialized design of this light allows for up to (3) fixtures to be run from a single power point. This drastically reduces wire clutter and affords a much faster installation. Standard Configuration LED-1936-24V 19.0 in / 483 mm 2.5 in / 64 mm Our Super High Output LED linear machine lighting is the most energy efficient, highest output, and longest lasting machine tool lighting in the world. It will quickly pay for itself through lower operating costs, longer lifespans and improved productivity. Die-cast aluminum body with tempered safety glass ensures reliable performance in the harshest environments. P/N: LED-1936 1 Light 24V DC Kit P/N: 13065 24V Cable (12 ft / 3.7 m) 14.5 in / 368 mm “Green” Long Before It Was Fashionable LED-1936-120V This light features exclusive “Patent Pending” thermal dimming controls. If the light gets too hot, it will automatically dim itself to cool down, and greatly extend its service life. Also due to our best-in-class engineering, these fixtures have TWICE the light output from the same wattage compared to our competition, and far exceeds the old style fluorescent lights. P/N: LED-1936 1 Light AC Kit Optional Configuration LED-1936-2-24V P/N: LED-1936 2 Light 24V DC Kit P/N: 13065 24V Cable (12 ft / 3.7 m) LIGHT OUTPUT at 18” (45.75 cm) LIGHT OUTPUT at 36” (91.5 cm) LED-1936-2-120V P/N: 13113-2 100-240V Power Supply (12ft. / 3.7m) P/N: LED-1936 3 Light 24V DC Kit P/N: 13065 24V Cable (12 ft / 3.7 m) LED-1936-3-120V 3 Light 120V AC Kit P/N: LED-1936 P/N: 13063 Interconnect Cable (6 ft / 1.8 m) P/N: LED-1936 2 Light 120V AC Kit LED-1936-3-24V P/N: LED-1936 P/N: 13063 Interconnect Cable (6 ft / 1.8 m) P/N: LED-1936 P/N: 13063 Interconnect Cable (6 ft / 1.8 m) P/N: LED-1936 P/N: 13113-3 100-240V Power Supply (12ft. / 3.7m) 16 3.38 in / 86 mm P/N: 13113-2 100-240V Power Supply (12ft. / 3.7m) P/N: 13070 Extension Cable (6 ft / 1.8 m) Use in between interconnect cable and light P/N: LED-1936 P/N: 13063 Interconnect Cable (6 ft / 1.8 m) 4.00 in / 102mm 4.76 in / 121mm Mounting Holes P/N: LED-1936 P/N: 13063 Interconnect Cable (6 ft / 1.8 m) P/N: LED-1936 P/N: 13063 Interconnect Cable (6 ft / 1.8 m) P/N: DIM-1936 Dimmer Module and Cord (6 ft / 1.8 m) Install in-line to add dimmer function 17 High Output LED Machine I P 6 7 18 R A T E D S P O T - L I T E M A C H I N E L E D L I G H T I N G 19 High Output LED Machine I P 6 7 18 R A T E D S P O T - L I T E M A C H I N E L E D L I G H T I N G 19 High Output LED Machine IP67 RATED SPOT-LITE MACHINE LED LIGHTING Compact & Powerful LED Lighting for Swiss-style Machining Next Generation LED Spot Lighting The new Spot-Lite is the perfect addition to any CNC machine enclosed or not! Our LED Spot-Lite builds on our sophisticated LED technology to provide users with unrivaled lighting. 3” Neodymium Magnet Your choice between permanent screw mount or magnet. Competitive units can’t match the holding power. Minimal Maintenance Locking Die-cast Swivel Base Locks up solid at any angle 180º Adjustment Range LED-WSL-SS -10-24v It is up to the operator to regularly clean rear heat fins to ensure long service life. Cool LEDs are happy LEDs. Compatible with LED-1936 Linear The light can be daisychained into series with our high output linear LED (end position). This allows you to light the largest cabinets, but also provide spot light exactly where required. Say Goodbye to Your Old Halogen! Hot and dangerous bulbs are a thing of the past! Upgrade your machine to cool LED lighting - you’ll see immediate improvements in set-up times and no loss of production time replacing bulbs! Integrated Dimming Each IP67 light features a built-in dimming switch with a 100-5% dimming range. Mounting Choices • • • IP67 Gasketing Specialized design ensures leak-proof performance over the entire life of the light. “Head Only” Magnet & Swivel 12 or 18” Gooseneck 30 or 43” Spring Arm LED-WSL-MG18-10-24v 270º Swivel Tempered Safety Glass Anything can happen in a CNC enclosure - you’ll appreciate this added safety and piece of mind. THERE’S MORE ONLINE! 10º Precision Focused LEDs 20 Great care and thought went into designing this spotlight. Maximum light with even spread ensures ideal lighting for any machine. For complete specifications on all OC White machine lighting including accessories, please visit: www.ocwhite.com 21 High Output LED Machine IP67 RATED SPOT-LITE MACHINE LED LIGHTING Compact & Powerful LED Lighting for Swiss-style Machining Next Generation LED Spot Lighting. The new Spot-Lite is the perfect addition to any CNC machine enclosed or not! Our LED Spot-Lite builds on our sophisticated LED technology to provide users with unrivaled lighting. 3” Neodymium Magnet Your choice between permanent screw mount or magnet. Competitive units can’t match the holding power. Minimal Maintenance Locking Die-cast Swivel Base Locks up solid at any angle 180º Adjustment Range LED-WSL-SS -10-24v It is up to the operator to regularly clean rear heat fins to ensure long service life. Cool LEDs are happy LEDs. Compatible with LED-1936 Linear The light can be daisychained into series with our high output linear LED (end position). This allows you to light the largest cabinets, but also provide spot light exactly where required. Say Goodbye to Your Old Halogen! Hot and dangerous bulbs are a thing of the past! Upgrade your machine to cool LED lighting - you’ll see immediate improvements in set-up times and no loss of production time replacing bulbs! Integrated Dimming Each IP67 light features a built-in dimming switch with a 100-5% dimming range. Mounting Choices • • • IP67 Gasketing Specialized design ensures leak-proof performance over the entire life of the light. “Head Only” Magnet & Swivel 12 or 18” Gooseneck 30 or 43” Spring Arm LED-WSL-MG18-10-24v 270º Swivel Tempered Safety Glass Anything can happen in a CNC enclosure - you’ll appreciate this added safety and piece of mind. THERE’S MORE ONLINE! 10º Precision Focused LEDs 20 Great care and thought went into designing this spotlight. Maximum light with even spread ensures ideal lighting for any machine. For complete specifications on all OC White machine lighting including accessories, please visit: www.ocwhite.com 21 ® HD INTEGRATED INSPECTION V i d e o Simply Better. Competes with Inspection Stations over $10k… at a Fraction of the Price! Super-Scope® stands heads and shoulders above its competition. This unique inspection system boasts features found on much more expensive equipment. Its freestanding design allows for use anywhere on the manufacturing floor… no need for a PC! TKSS (shown with optional LV2000-B) Unmatched Working Distance! 6” to Infinity! ESD SAFE Ultimate Ergonomics Ergonomic design and operator comfort go hand in hand. Unlike microscopes with restrictive eyepieces, Super-Scope® features ‘heads up’ viewing for greatly reduced eyestrain, neck fatigue, and improved posture. The large working distance range means that any height operator can readjust to fit them easily. EH&S personnel can see immediate benefit. 22 The heart of the Super-Scope® is our 5MP Hybrid HDMI/USB camera with 12” Integrated LED screen. Featuring full 1080 resolution (300dpi) for super detailed ‘heads up’ viewing, this camera features onboard tools including Image & Video capture, calibrated measurement, split screen live view, and more! An 8GB SD Card is included standard for easy transfer. This system features our exclusive varifocal lens technology, which allows for up to 80x magnification and working distances that can be measured in FEET not inches! Each system ships standard with our 24” tall double ball bearing base (other mounting styles available). • Infinite Focal Length Inspect from 6” Working Distance to Infinity • 5MP Hybrid HDMI/USB Camera Exclusive Design Works without a PC • 1-40x Standard Magnification Up to 80x with Options • Built-in Software No PC Needed! See full features list on the following pages • No Light Needed Industry-Leading Low Light Sensitivity Need Up to 400X Magnification? • Split Screen Display Captured vs. Live CONTACT US FOR DETAILS ON THE NEW SUPER-SCOPE® MICRO ZOOM INSPECTION SYSTEM! • Built with ESD Safety Construction and Image Comparison Tool Materials I n s p e c t i o n S y s t e m Unlimited Inspection Applications Our MacroZoom series is a specialized ergonomic inspection system that pairs a large magnification range (up to 80x), with unheard of working distance, depth of field (area vertically in focus) and user control. These systems fill the need for large field of view inspection, high magnification, and almost unlimited working distance. Unlike a microscope, which limits you to strict working distances, MacroZoom’s one-touch variable focal optical design allows for refocusing in a flash, at any working height! Built with ESD Safety Construction and Materials. STANDARD FEATURES • 5MP Hybrid HDMI/USB Camera with • Extended Height 24” Ball Bearing Advanced Onboard Imaging Controls • Unlimited Working Distance 6” to ∞ Base for Increased Adjustability ESD SAFE TKMACZ with 22” LED Monitor (shown with optional LV2000-B) • Range up to 120x with options ONBOARD SOFTWARE FEATURES • Image & Video Capture • Browse Saved Images • Split-Screen Compare • Calibrated Measurement • Digital Zoom with H/V Image Invert • Region of Interest Cropping • Crosshair Overlay • Calibration Bar • Data Export to Excel or TXT File • And More! EXCLUSIVE FEATURES INCLUDED WITH OUR HD2 ADVANCED IMAGING & MEASUREMENT PC SUITE: • Extended Depth of Focus Stacking • Advanced Fluorescence Imaging Controls (HDR) • Image Stitching Combines Multiple Images for Super-Large Field of View • Multiple Advanced Measurement Tools with Micron-Level Accuracy (down to 10nm) • Region of Interest Cropping • Crosshair Overlay • Calibration Bar • Data Export to Excel or TXT File • Learn More About It on the Following Pages! TKDMACZ (shown with optional LV2000-B) ESD SAFE 23 ® HD INTEGRATED INSPECTION V i d e o Simply Better. Competes with Inspection Stations over $10k… at a Fraction of the Price! Super-Scope® stands heads and shoulders above its competition. This unique inspection system boasts features found on much more expensive equipment. Its freestanding design allows for use anywhere on the manufacturing floor… no need for a PC! TKSS (shown with optional LV2000-B) Unmatched Working Distance! 6” to Infinity! ESD SAFE Ultimate Ergonomics Ergonomic design and operator comfort go hand in hand. Unlike microscopes with restrictive eyepieces, Super-Scope® features ‘heads up’ viewing for greatly reduced eyestrain, neck fatigue, and improved posture. The large working distance range means that any height operator can readjust to fit them easily. EH&S personnel can see immediate benefit. 22 The heart of the Super-Scope® is our 5MP Hybrid HDMI/USB camera with 12” Integrated LED screen. Featuring full 1080 resolution (300dpi) for super detailed ‘heads up’ viewing, this camera features onboard tools including Image & Video capture, calibrated measurement, split screen live view, and more! An 8GB SD Card is included standard for easy transfer. This system features our exclusive varifocal lens technology, which allows for up to 80x magnification and working distances that can be measured in FEET not inches! Each system ships standard with our 24” tall double ball bearing base (other mounting styles available). • Infinite Focal Length Inspect from 6” Working Distance to Infinity • 5MP Hybrid HDMI/USB Camera Exclusive Design Works without a PC • 1-40x Standard Magnification Up to 80x with Options • Built-in Software No PC Needed! See full features list on the following pages • No Light Needed Industry-Leading Low Light Sensitivity Need Up to 400X Magnification? • Split Screen Display Captured vs. Live CONTACT US FOR DETAILS ON THE NEW SUPER-SCOPE® MICRO ZOOM INSPECTION SYSTEM! • Built with ESD Safety Construction and Image Comparison Tool Materials I n s p e c t i o n S y s t e m Unlimited Inspection Applications Our MacroZoom series is a specialized ergonomic inspection system that pairs a large magnification range (up to 80x), with unheard of working distance, depth of field (area vertically in focus) and user control. These systems fill the need for large field of view inspection, high magnification, and almost unlimited working distance. Unlike a microscope, which limits you to strict working distances, MacroZoom’s one-touch variable focal optical design allows for refocusing in a flash, at any working height! Built with ESD Safety Construction and Materials. STANDARD FEATURES • 5MP Hybrid HDMI/USB Camera with • Extended Height 24” Ball Bearing Advanced Onboard Imaging Controls • Unlimited Working Distance 6” to ∞ Base for Increased Adjustability ESD SAFE TKMACZ with 22” LED Monitor (shown with optional LV2000-B) • Range up to 120x with options ONBOARD SOFTWARE FEATURES • Image & Video Capture • Browse Saved Images • Split-Screen Compare • Calibrated Measurement • Digital Zoom with H/V Image Invert • Region of Interest Cropping • Crosshair Overlay • Calibration Bar • Data Export to Excel or TXT File • And More! EXCLUSIVE FEATURES INCLUDED WITH OUR HD2 ADVANCED IMAGING & MEASUREMENT PC SUITE: • Extended Depth of Focus Stacking • Advanced Fluorescence Imaging Controls (HDR) • Image Stitching Combines Multiple Images for Super-Large Field of View • Multiple Advanced Measurement Tools with Micron-Level Accuracy (down to 10nm) • Region of Interest Cropping • Crosshair Overlay • Calibration Bar • Data Export to Excel or TXT File • Learn More About It on the Following Pages! TKDMACZ (shown with optional LV2000-B) ESD SAFE 23 AIMS ADVANCED IMAGING &MEASUREMENT SUITE INTEGRATED SOFTWARE FUNCTIONS FOR ALL CAMERA BASED SYSTEMS Full Functionality Without Using a PC! Calibrated Onboard Measurement Couldn’t Be Easier! An Entire Array of Measurement Tools for High Precision, Repeatable Measurements. All Without Using a PC! The Built-In Advanced Imaging & Measurement Suite Comes Out of the Box Ready for Bench Production. Browse Captured Images Quickly scan through previously saved image and video captures. This full field archive allows for quick image pull-up and the ability to sort and delete images no longer needed. An 8GB SD card is included with every system to transfer images and videos from system to remote PC for archiving, emailing, etc. Compare While Working Upper Right-hand window features the live video feed, while all previously captured images are tiled around it. This feature allows for real-time searching of previously captured good (or bad) examples for instant comparison. Exclusive Features Found Only in Advanced Imaging & Measurement PC Suite Split Screen Viewing Excellent training tool! Pull up a previously saved capture (left pane) and compare with live image on the right! This interactive screen is excellent for showcasing pass/fail to multiple people at once. Ever have to train a group of new employees all at once? It has never been easier for all employees to see the same details, at the same time. 24 Extended Depth of Focus This specialized tool allows for ‘stacking’ of multiple image captures taken at various focal lengths, into a single super clear image. This tool is excellent for showcasing super high clarity images of tall items that are outside of the capabilities of optical clarity alone. No longer must you settle with images that are good enough… make them great! Image Stitching Inspecting something that is just too big to view all at once? This handy feature allows you to capture multiple images of the part, then ‘stitch’ them together digitally to create a single extra-large image. This technology is now available to you, with all of the quality you expect from O.C. White. 25 AIMS ADVANCED IMAGING &MEASUREMENT SUITE INTEGRATED SOFTWARE FUNCTIONS FOR ALL CAMERA BASED SYSTEMS Full Functionality Without Using a PC! Calibrated Onboard Measurement Couldn’t Be Easier! An Entire Array of Measurement Tools for High Precision, Repeatable Measurements. All Without Using a PC! The Built-In Advanced Imaging & Measurement Suite Comes Out of the Box Ready for Bench Production. Browse Captured Images Quickly scan through previously saved image and video captures. This full field archive allows for quick image pull-up and the ability to sort and delete images no longer needed. An 8GB SD card is included with every system to transfer images and videos from system to remote PC for archiving, emailing, etc. Compare While Working Upper Right-hand window features the live video feed, while all previously captured images are tiled around it. This feature allows for real-time searching of previously captured good (or bad) examples for instant comparison. Exclusive Features Found Only in Advanced Imaging & Measurement PC Suite Split Screen Viewing Excellent training tool! Pull up a previously saved capture (left pane) and compare with live image on the right! This interactive screen is excellent for showcasing pass/fail to multiple people at once. Ever have to train a group of new employees all at once? It has never been easier for all employees to see the same details, at the same time. 24 Extended Depth of Focus This specialized tool allows for ‘stacking’ of multiple image captures taken at various focal lengths, into a single super clear image. This tool is excellent for showcasing super high clarity images of tall items that are outside of the capabilities of optical clarity alone. No longer must you settle with images that are good enough… make them great! Image Stitching Inspecting something that is just too big to view all at once? This handy feature allows you to capture multiple images of the part, then ‘stitch’ them together digitally to create a single extra-large image. This technology is now available to you, with all of the quality you expect from O.C. White. 25 ProZoom 4.5 ® M I C R O S C O P E S Industry Standard Performance O.C. White Value ProZoom® 4.5 is the Industry Standard for High Precision and Long Service Life. The ProZoom® 4.5 Stereo-Zoom Binocular Microscope family combines durability, low cost and performance. With magnification and performance on par with much more expensive microscopes, it can be adapted for most industrial needs. • • • • • • • • • • 7 - 45x Standard Magnification Range 3.5 - 225x Available with Options Extra Large 22mm 10x Eyepieces for Ergonomic Comfort .5x Objective Lens Included at No Charge (a $125 VALUE) 90-250mm Working Distance ±5 Diopter Adjustable Eyepiece Tubes for Clarity Eyetube Inclination of 45° Easy 360° Main Body Rotation Built with ESD Safety Construction and Materials 5 Year Mechanical Warranty TKSZ-L-LV2 ESD SAFE ESD SAFE TKSZ-FA-LV2 Laboratory Base for Limited Space This package is perfect for any user who has limited installation space, or does not require the vertical adjustibility our other bases offer. 7-45x is standard and available with a choice of illuminators (shown with Micro-Lite® LED ring light). Built with ESD Safety Construction and Materials. Our Most Popular Standard in this system is our silky smooth precision-glide ball bearing arm base assembly, and our heavy duty weighted base. Combining all of the optical features above with this rock solid base assembly and our Micro-Lite® LED ring illuminator... and you have a package that is perfectly suited for any inspection task. Built with ESD Safety Materials and Construction. This specialized articulating arm is great for customers who simply cannot mount a base anywhere on their worksurface (convenient table edge clamp mount), or that regularly inspect both very large and very small parts. Also available with choice of illuminators (shown with Micro-Lite® LED ring light). Built with ESD Safety Construction and Materials. ProZoom® 4.5 Technical Data Eyepiece TKSZ-LV2 0.5X 0.75X 1X 1.5X 2X Main Body SZ-OB-050 SZ-OB-075 SZ-OB-100 SZ-OB-150 SZ-OB-200 10X MAG: FOV: 7-45X 31.4-4.9mm 3.5-22.5X 62.8-9.8mm 5.3-33.8X 41.9-6.5mm 7-45X 31.4-4.9mm 10.6-68X 20.9-3.3mm 14-90X 15.7-2.5mm 15X MAG: FOV: 10.5-67.5X 21.4-3.4mm 5.3-33.8X 42.8-6.7mm 7.9-50.6X 28.5-4.4mm 10.5-67.5X 21.4-3.4mm 15.8-101.2X 14.2-2.3mm 21-135X 10.7-1.7mm 20X MAG: FOV: 14-90X 17.1-2.7mm 7-45X 34.2-5.3mm 10.6-67.5X 22.9-3.6mm 14-90X 17.1-2.7mm 21.2-135X 11.4-1.8mm 28-180X 8.5-1.4mm 25X MAG: FOV: 17.5-112.5X 12.8-2mm 8.8-56.3X 25.7-4mm 13.1-84.4X 17.1-2.7mm 17.5-112.5X 12.8-2mm 26.3-168.8X 8.5-1.4mm 35-225X 6.4-1mm 88 mm 137 mm 103 mm 88 mm 38 mm 29 mm ESD SAFE Working Distance 26 Articulating Arm for Adjustable Height 27 ProZoom 4.5 ® M I C R O S C O P E S Industry Standard Performance O.C. White Value ProZoom® 4.5 is the Industry Standard for High Precision and Long Service Life. The ProZoom® 4.5 Stereo-Zoom Binocular Microscope family combines durability, low cost and performance. With magnification and performance on par with much more expensive microscopes, it can be adapted for most industrial needs. • • • • • • • • • • 7 - 45x Standard Magnification Range 3.5 - 225x Available with Options Extra Large 22mm 10x Eyepieces for Ergonomic Comfort .5x Objective Lens Included at No Charge (a $125 VALUE) 90-250mm Working Distance ±5 Diopter Adjustable Eyepiece Tubes for Clarity Eyetube Inclination of 45° Easy 360° Main Body Rotation Built with ESD Safety Construction and Materials 5 Year Mechanical Warranty TKSZ-L-LV2 ESD SAFE ESD SAFE TKSZ-FA-LV2 Laboratory Base for Limited Space This package is perfect for any user who has limited installation space, or does not require the vertical adjustibility our other bases offer. 7-45x is standard and available with a choice of illuminators (shown with Micro-Lite® LED ring light). Built with ESD Safety Construction and Materials. Our Most Popular Standard in this system is our silky smooth precision-glide ball bearing arm base assembly, and our heavy duty weighted base. Combining all of the optical features above with this rock solid base assembly and our Micro-Lite® LED ring illuminator... and you have a package that is perfectly suited for any inspection task. Built with ESD Safety Materials and Construction. This specialized articulating arm is great for customers who simply cannot mount a base anywhere on their worksurface (convenient table edge clamp mount), or that regularly inspect both very large and very small parts. Also available with choice of illuminators (shown with Micro-Lite® LED ring light). Built with ESD Safety Construction and Materials. ProZoom® 4.5 Technical Data Eyepiece TKSZ-LV2 0.5X 0.75X 1X 1.5X 2X Main Body SZ-OB-050 SZ-OB-075 SZ-OB-100 SZ-OB-150 SZ-OB-200 10X MAG: FOV: 7-45X 31.4-4.9mm 3.5-22.5X 62.8-9.8mm 5.3-33.8X 41.9-6.5mm 7-45X 31.4-4.9mm 10.6-68X 20.9-3.3mm 14-90X 15.7-2.5mm 15X MAG: FOV: 10.5-67.5X 21.4-3.4mm 5.3-33.8X 42.8-6.7mm 7.9-50.6X 28.5-4.4mm 10.5-67.5X 21.4-3.4mm 15.8-101.2X 14.2-2.3mm 21-135X 10.7-1.7mm 20X MAG: FOV: 14-90X 17.1-2.7mm 7-45X 34.2-5.3mm 10.6-67.5X 22.9-3.6mm 14-90X 17.1-2.7mm 21.2-135X 11.4-1.8mm 28-180X 8.5-1.4mm 25X MAG: FOV: 17.5-112.5X 12.8-2mm 8.8-56.3X 25.7-4mm 13.1-84.4X 17.1-2.7mm 17.5-112.5X 12.8-2mm 26.3-168.8X 8.5-1.4mm 35-225X 6.4-1mm 88 mm 137 mm 103 mm 88 mm 38 mm 29 mm ESD SAFE Working Distance 26 Articulating Arm for Adjustable Height 27 ProZoom 6.5 ® M I C R O S C O P E S PROZOOM® 6.5 TRINOCULAR STANDARD FEATURES Big Results Made Easy Each system ships with our exclusive 5MP Hybrid HDMI/USB Camera. This exceptional smart camera pulls double duty for both production and quality assurance needs. It features both HDMI and USB outputs, and has integrated smart camera controls with a host of onboard software features including: TKPZ-LV2 Next-Level Performance Meets Budget-Friendly Price Compare live video feed with previous captured images. Search and sort for instant comparison. Calibrated Measure • 5 - 65x Standard Magnification Range (up to 390x w/options) • Super Wide 28mm High Eye Point and Wide Field Eyepieces • Eye-tube Inclination of 45° with 360° rotation of Main Body • 190mm of Working Distance with 0.5x Objective Lens • ±6 Diopter Adjustment Range • Interpupillary Distance Adjustment on Eyepiece Tubes • Built with ESD Safety Construction and Materials • Trinocular Package includes 0.3x CCD adapter • All Trinocular Packages include our 5MP Hybrid HDMI/USB camera with Advanced Onboard Imaging Controls • Precision-glide Ball Bearing Arm Base Assembly • 5 Year Mechanical Warranty (1 Year Electrical) ProZoom® 6.5 Technical Data 0.7X 1.0X 2.0X Main Body PZ-OB-037 PZ-OB-050 PZ-OB-070 PZ-OB-100 PZ-OB-200 10X MAG: FOV: 10-65X 23~3.5mm 3.7-24.1X 62.2-9.6mm 5-32.5X 46-7mm 7-46X 32.9-5mm 10-65X 23-3.5mm 20-130X 11.5-1.8mm 15X MAG: FOV: 15-97.5X 17-2.6mm 5.55-36.1X 45.9-7.1mm 7.5-48.8X 34-5.2mm 10.5-69X 24.3-3.7mm 15-97.5X 17-2.6mm 30-195X 8.5-1.3mm 20X MAG: FOV: 20-130X 14-2.2mm 7.4-48.1X 37.8-5.8mm 10-65X 28-4.2mm 14-92X 20-3.1mm 20-130X 14-2.2mm 40-260X 7-1.1mm 30X MAG: FOV: 30-195X 9-1.4mm 11.1-72.2X 24.3-3.7mm 15-97.5X 18-2.7mm 21-138X 12.9-2mm 30-195X 9.0-1.4mm 60-390X 4.5-0.7mm 110 mm 275 mm 195 mm 145 mm 110 mm 35 mm Working Distance 28 0.5X TKDPZT-LV2 Quickly capture image and videos while inspecting directly to the 8GB SD card. Sort and archive to a PC. Real Time Compare The ProZoom® 6.5 family outperforms stereo microscopes costing twice as much. ProZoom® 6.5 provides the Largest Standard Working Distance, the Largest Magnification Range and Largest Eyepieces available on modern stereo microscopes. Eyepiece ESD SAFE Image Capture ESD SAFE 0.37X ProZoom® 6.5 Trinocular with Ultra-Cam II™ An entire array of Measurement Tools for high precision and repeatable measurements without a PC! Ultra-High Sensitivity Industry leading low light sensitivity allows for crystal clear images where competitors cameras fail. More sensitivity equals less light required… which means less glare! At the heart of every ProZoom® 6.5 trinocular system is our exclusive 5MP Hybrid HDMI/USB Camera with Onboard Image Controls. This system above includes microscope, base assembly, LED ring light, 5MP Hybrid HDMI/USB Camera as well as our FREE HD2 Advanced Imaging & Measurement Software Suite (a $595 value) ProZoom® 6.5 Trinocular with Ultra-Cam II™ & 22” LED Monitor TKPZT-LV2 ADVANCED IMAGING & MEASUREMENT PC SUITE EXCLUSIVE FEATURES ESD SAFE Extended Depth of Focus This specialized tool allows for ‘stacking’ of multiple image captures of tall objects taken at various focal lengths, into a single super high clarity image. Image Stitching Inspecting something that is just too big to view all at once? Capture multiple images of the object, then ‘stitch’ them together digitally to create a single extra-large image. This system includes all of the features and benefits shown for the TKDPZT-LV2 system, but also includes a 22” HD LED screen. We have matched the specifications of this screen to be the perfect companion to our 5MP Camera. Not all flat screens are created equal. Also Available with 12” Integrated Screen! (TKPZT-HU-LV2) 29 ProZoom 6.5 ® M I C R O S C O P E S PROZOOM® 6.5 TRINOCULAR STANDARD FEATURES Big Results Made Easy Each system ships with our exclusive 5MP Hybrid HDMI/USB Camera. This exceptional smart camera pulls double duty for both production and quality assurance needs. It features both HDMI and USB outputs, and has integrated smart camera controls with a host of onboard software features including: TKPZ-LV2 Next-Level Performance Meets Budget-Friendly Price Compare live video feed with previous captured images. Search and sort for instant comparison. Calibrated Measure • 5 - 65x Standard Magnification Range (up to 390x w/options) • Super Wide 28mm High Eye Point and Wide Field Eyepieces • Eye-tube Inclination of 45° with 360° rotation of Main Body • 190mm of Working Distance with 0.5x Objective Lens • ±6 Diopter Adjustment Range • Interpupillary Distance Adjustment on Eyepiece Tubes • Built with ESD Safety Construction and Materials • Trinocular Package includes 0.3x CCD adapter • All Trinocular Packages include our 5MP Hybrid HDMI/USB camera with Advanced Onboard Imaging Controls • Precision-glide Ball Bearing Arm Base Assembly • 5 Year Mechanical Warranty (1 Year Electrical) ProZoom® 6.5 Technical Data 0.7X 1.0X 2.0X Main Body PZ-OB-037 PZ-OB-050 PZ-OB-070 PZ-OB-100 PZ-OB-200 10X MAG: FOV: 10-65X 23~3.5mm 3.7-24.1X 62.2-9.6mm 5-32.5X 46-7mm 7-46X 32.9-5mm 10-65X 23-3.5mm 20-130X 11.5-1.8mm 15X MAG: FOV: 15-97.5X 17-2.6mm 5.55-36.1X 45.9-7.1mm 7.5-48.8X 34-5.2mm 10.5-69X 24.3-3.7mm 15-97.5X 17-2.6mm 30-195X 8.5-1.3mm 20X MAG: FOV: 20-130X 14-2.2mm 7.4-48.1X 37.8-5.8mm 10-65X 28-4.2mm 14-92X 20-3.1mm 20-130X 14-2.2mm 40-260X 7-1.1mm 30X MAG: FOV: 30-195X 9-1.4mm 11.1-72.2X 24.3-3.7mm 15-97.5X 18-2.7mm 21-138X 12.9-2mm 30-195X 9.0-1.4mm 60-390X 4.5-0.7mm 110 mm 275 mm 195 mm 145 mm 110 mm 35 mm Working Distance 28 0.5X TKDPZT-LV2 Quickly capture image and videos while inspecting directly to the 8GB SD card. Sort and archive to a PC. Real Time Compare The ProZoom® 6.5 family outperforms stereo microscopes costing twice as much. ProZoom® 6.5 provides the Largest Standard Working Distance, the Largest Magnification Range and Largest Eyepieces available on modern stereo microscopes. Eyepiece ESD SAFE Image Capture ESD SAFE 0.37X ProZoom® 6.5 Trinocular with Ultra-Cam II™ An entire array of Measurement Tools for high precision and repeatable measurements without a PC! Ultra-High Sensitivity Industry leading low light sensitivity allows for crystal clear images where competitors cameras fail. More sensitivity equals less light required… which means less glare! At the heart of every ProZoom® 6.5 trinocular system is our exclusive 5MP Hybrid HDMI/USB Camera with Onboard Image Controls. This system above includes microscope, base assembly, LED ring light, 5MP Hybrid HDMI/USB Camera as well as our FREE HD2 Advanced Imaging & Measurement Software Suite (a $595 value) ProZoom® 6.5 Trinocular with Ultra-Cam II™ & 22” LED Monitor TKPZT-LV2 ADVANCED IMAGING & MEASUREMENT PC SUITE EXCLUSIVE FEATURES ESD SAFE Extended Depth of Focus This specialized tool allows for ‘stacking’ of multiple image captures of tall objects taken at various focal lengths, into a single super high clarity image. Image Stitching Inspecting something that is just too big to view all at once? Capture multiple images of the object, then ‘stitch’ them together digitally to create a single extra-large image. This system includes all of the features and benefits shown for the TKDPZT-LV2 system, but also includes a 22” HD LED screen. We have matched the specifications of this screen to be the perfect companion to our 5MP Camera. Not all flat screens are created equal. Also Available with 12” Integrated Screen! (TKPZT-HU-LV2) 29 Ergo-Zoom ® ERGONOMIC MACROSCOPES Comfort is Our Main Objective Ergo-Zoom® 8-50x Trinocular with Ultra-Cam II™ Ergo-Zoom® Combines Comfort with the Highest Quality Image Possible from a Microscope! Ergo-Zoom® microscopes set a new standard for industry, offering scientific grade Common Main Objective (CMO) optical design at very attractive price points. This optical design delivers distortion free, high resolution flat field images. If you are inspecting mission-critical parts, there is no finer solution. Ergonomic design includes 0-35° adjustable angle eyepiece; neck fatigue and eye strain are a thing of the past! Wide focus, large diameter 10x eyepieces and 1x Auxiliary lenses are included in standard packages. TKEZ-850-LV2 ESD SAFE Ergo-Zoom® is a modular microscope line which can grow with you, and be outfitted to match your exact needs. Your custom is our standard. It is available in three standard zoom tiers (8-50x, 8-65x, and 8-80x), and features detented zoom stops for repeatable magnification location. You can configure Ergo-Zoom® to reach up to 320x! • • • • • • • • • • 30 This specialized system includes our world renowned Ergo-Zoom® 8-50x optics, trinocular splitter assembly, .5x CCD adapter and our new and exclusive 5MP Hybrid HDMI/USB Camera with Onboard Image Controls. This system also includes our FREE HD2 Advanced Imaging & Measurement software suite (a $595 value). ESD SAFE THE ONBOARD IMAGE CONTROLS INCLUDE: IMAGE CAPTURE REAL TIME COMPARE TKDEZT-850-LV2 Ergo-Zoom® 8-50x Trinocular with Ultra-Cam II™ & 22” LED Monitor This system includes all of the features and benefits shown for the TKDEZT-850-LV2 system, but also includes a 22” HD LED screen. We have matched the specifications of this screen to be the perfect companion to our 5MP Camera. Not all flat screens are created equal, and when pairing with the world’s finest microscope optics, this is not an area where you want second-best. ESD SAFE TKEZT-850-LV2 PLAN APO LENSES ARE THE KEY TO CRITICAL QUALITY INSPECTION EZ-OB-050 EZ-OB-100 EZ-Dual Splitter EZ-OB-200 Supports TWO CAMERAS A T O N C E ! THE ULTIMATE COLLABORATIVE TRAINING OPTION The Precision Glide ball bearing arm gives effortless motion with 20” of horizontal movement - and rock solid stability. Built for years of perfect use. All Ergo-Zoom® microscopes are built with ESD Safety in mind. 8 -50x Standard Magnification Range Up to 320x with Options Wide focus, large diameter 10x eyepieces for all-day ergonomic comfort 32.5-200mm Working Distances (Based on Objective Lens) ±5 Diopter Adjustable Eyepiece Tubes for Clarity Eyetube Inclination of 0-35° Easy 360° Main Body Rotation ESD Safe Modular Designed System for expandable performance 5 Year Mechanical Warranty Full 35° Range of Motion! Even at Maximum Magnifcation ULTRA-HIGH SENSITIVITY CALIBRATED MEASURE Ergo-Zoom® EZ-850 Technical Data EZ-OB-050A Eyepiece EZ-OB-050 EZ-OB-100 EZ-OB-200 (.5x Achromatic) (.5x Plan APO) (1x Std. in Kit) (2x Plan APO) THERE’S MORE ONLINE! 10X MAG: FOV: 4-25X 60-9.6mm 4-25X 60-9.6mm 8-50X 30-4.8mm 16-100X 15-2.4mm 15X MAG: FOV: 6-37.5X 40-6.4mm 6-37.5X 40-6.4mm 12-75X 20-3.2mm 24-150X 10-1.6mm For complete optical data on all three Ergo-Zoom® microscope models including accessories, please visit: 20X MAG: FOV: 8-50X 30-4.8mm 8-50X 30-4.8mm 16-100X 15-2.4mm 32-200X 7.5-1.2mm www.ocwhite.com 126 mm 78 mm Working Distance 200 mm 32.5 mm 31 Ergo-Zoom ® ERGONOMIC MACROSCOPES Comfort is Our Main Objective Ergo-Zoom® 8-50x Trinocular with Ultra-Cam II™ Ergo-Zoom® Combines Comfort with the Highest Quality Image Possible from a Microscope! Ergo-Zoom® microscopes set a new standard for industry, offering scientific grade Common Main Objective (CMO) optical design at very attractive price points. This optical design delivers distortion free, high resolution flat field images. If you are inspecting mission-critical parts, there is no finer solution. Ergonomic design includes 0-35° adjustable angle eyepiece; neck fatigue and eye strain are a thing of the past! Wide focus, large diameter 10x eyepieces and 1x Auxiliary lenses are included in standard packages. TKEZ-850-LV2 ESD SAFE Ergo-Zoom® is a modular microscope line which can grow with you, and be outfitted to match your exact needs. Your custom is our standard. It is available in three standard zoom tiers (8-50x, 8-65x, and 8-80x), and features detented zoom stops for repeatable magnification location. You can configure Ergo-Zoom® to reach up to 320x! • • • • • • • • • • 30 This specialized system includes our world renowned Ergo-Zoom® 8-50x optics, trinocular splitter assembly, .5x CCD adapter and our new and exclusive 5MP Hybrid HDMI/USB Camera with Onboard Image Controls. This system also includes our FREE HD2 Advanced Imaging & Measurement software suite (a $595 value). ESD SAFE THE ONBOARD IMAGE CONTROLS INCLUDE: IMAGE CAPTURE REAL TIME COMPARE TKDEZT-850-LV2 Ergo-Zoom® 8-50x Trinocular with Ultra-Cam II™ & 22” LED Monitor This system includes all of the features and benefits shown for the TKDEZT-850-LV2 system, but also includes a 22” HD LED screen. We have matched the specifications of this screen to be the perfect companion to our 5MP Camera. Not all flat screens are created equal, and when pairing with the world’s finest microscope optics, this is not an area where you want second-best. ESD SAFE TKEZT-850-LV2 PLAN APO LENSES ARE THE KEY TO CRITICAL QUALITY INSPECTION EZ-OB-050 EZ-OB-100 EZ-Dual Splitter EZ-OB-200 Supports TWO CAMERAS A T O N C E ! THE ULTIMATE COLLABORATIVE TRAINING OPTION The Precision Glide ball bearing arm gives effortless motion with 20” of horizontal movement - and rock solid stability. Built for years of perfect use. All Ergo-Zoom® microscopes are built with ESD Safety in mind. 8 -50x Standard Magnification Range Up to 320x with Options Wide focus, large diameter 10x eyepieces for all-day ergonomic comfort 32.5-200mm Working Distances (Based on Objective Lens) ±5 Diopter Adjustable Eyepiece Tubes for Clarity Eyetube Inclination of 45° Easy 360° Main Body Rotation ESD Safe Modular Designed System for expandable performance 5 Year Mechanical Warranty Full 35° Range of Motion! Even at Maximum Magnifcation ULTRA-HIGH SENSITIVITY CALIBRATED MEASURE Ergo-Zoom® EZ-850 Technical Data EZ-OB-050A Eyepiece EZ-OB-050 EZ-OB-100 EZ-OB-200 (.5x Achromatic) (.5x Plan APO) (1x Std. in Kit) (2x Plan APO) THERE’S MORE ONLINE! 10X MAG: FOV: 4-25X 60-9.6mm 4-25X 60-9.6mm 8-50X 30-4.8mm 16-100X 15-2.4mm 15X MAG: FOV: 6-37.5X 40-6.4mm 6-37.5X 40-6.4mm 12-75X 20-3.2mm 24-150X 10-1.6mm For complete optical data on all three Ergo-Zoom® microscope models including accessories, please visit: 20X MAG: FOV: 8-50X 30-4.8mm 8-50X 30-4.8mm 16-100X 15-2.4mm 32-200X 7.5-1.2mm www.ocwhite.com 126 mm 78 mm Working Distance 200 mm 32.5 mm 31 Micro-Lite ® MICROSCOPE ILLUMINATION LED Microscope Lighting for Worldwide Use Micro-Lite® Illuminators Repel Static Charges, Surpassing the Most Stringent ESD Specifications! Adjustable 100-5% of ideal 5700K light! • Special ANTI-STATIC polymer repels any static build up. LV2000-B • 2.35” (60mm) mounting ring diameter, with optional No Hotspots 66mm now available Produces even lighting at • 9 LED surface mount array with exclusive thermal ESD SAFE any working distance! management system • 5700K Color Temperature Standard • New Optional 3500K Color Temperature Available Fits Most Popular Microscopes (LV3500 and LV3500-B) on the Market Today!! • Brighter than a 150w Halogen above 6” height • Exclusive larger and more even illuminated area - no hotspots from change in working distance • Dimmable, flicker-free light from 100-5% • No bulky desktop controller box • 100-240v (50/60hz) auto switchable power supply with worldwide approvals • Fits most microscopes with optional adapters • 5 Year/50,000 Hour warranty Micro-Lite® High Intensity 3500k LED Ring Illuminator LV2000-B Perfect, Dimmable White Light Featuring a long life span, low operating costs and high output, our LV2000 solves the three key problems in microscope illumination. It's ESD safe construction contains new surface mounted LED technology providing dimmable 5700K light with no hotspots, low power consumption, "instant-on" startup and zero desktop footprint. This is the world's best LED illuminator. 32 Micro-Lite® High Intensity 5700k LED Ring Illuminator LV3500 ESD SAFE Micro-Lite® High Intensity 5700k LED Ring Illuminator with 9 Extreme Output LEDs. This LED Illuminator is the brightest on the market, and rivals 150w Halogen illuminators! Energy Efficient with 5700K Color Temperature. Total Energy consumption of this unit is a scant 8w! Features a 100-240V (50/60Hz) Auto Switchable Transformer design. Available in black or white molded shades. ESD Safe. ESD SAFE Micro-Lite® High Intensity LED Ring Illuminator with 3500K color temperature. This LED Illuminator is the brightest on the market, and rivals 150w Halogen illuminators in it’s specific yellow hue. An excellent choice for medical device manufacturers. Total Energy consumption of this unit is a scant 8w! Features a 100-240V (50/60Hz) Auto Switchable Transformer design. Available in black or white molded shades. ESD Safe. SPECIALIZED ULTRAVIOLET LED LIGHTING Micro-Lite® Ultraviolet (395nm) LED Ring Illuminator Micro-Lite® High Intensity Black Ultraviolet LED Ring Illuminator with 9 Extreme Output LEDs. At Home in Many Industries, Our UV2000-B Features 395nm Ultraviolet Light (365nm available). ESD SAFE Specialized Market Applications Include: • • • • Conformal Coating Dye Penetrant Inspection Forgery Analysis Mineral & Gemstone Inspection • Crime Scene Forensics • Homeland Security UV2000-B 33 Micro-Lite ® MICROSCOPE ILLUMINATION LED Microscope Lighting for Worldwide Use Micro-Lite® Illuminators Repel Static Charges, Surpassing the Most Stringent ESD Specifications! Adjustable 100-5% of ideal 5700K light! • Special ANTI-STATIC polymer repels any static build up. LV2000-B • 2.35” (60mm) mounting ring diameter, with optional No Hotspots 66mm now available Produces even lighting at • 9 LED surface mount array with exclusive thermal ESD SAFE any working distance! management system • 5700K Color Temperature Standard • New Optional 3500K Color Temperature Available Fits Most Popular Microscopes (LV3500 and LV3500-B) on the Market Today!! • Brighter than a 150w Halogen above 6” height • Exclusive larger and more even illuminated area - no hotspots from change in working distance • Dimmable, flicker-free light from 100-5% • No bulky desktop controller box • 100-240v (50/60hz) auto switchable power supply with worldwide approvals • Fits most microscopes with optional adapters • 5 Year/50,000 Hour warranty Micro-Lite® High Intensity 3500k LED Ring Illuminator LV2000-B Perfect, Dimmable White Light Featuring a long life span, low operating costs and high output, our LV2000 solves the three key problems in microscope illumination. It's ESD safe construction contains new surface mounted LED technology providing dimmable 5700K light with no hotspots, low power consumption, "instant-on" startup and zero desktop footprint. This is the world's best LED illuminator. 32 Micro-Lite® High Intensity 5700k LED Ring Illuminator LV3500 ESD SAFE Micro-Lite® High Intensity 5700k LED Ring Illuminator with 9 Extreme Output LEDs. This LED Illuminator is the brightest on the market, and rivals 150w Halogen illuminators! Energy Efficient with 5700K Color Temperature. Total Energy consumption of this unit is a scant 8w! Features a 100-240V (50/60Hz) Auto Switchable Transformer design. Available in black or white molded shades. ESD Safe. ESD SAFE Micro-Lite® High Intensity LED Ring Illuminator with 3500K color temperature. This LED Illuminator is the brightest on the market, and rivals 150w Halogen illuminators in it’s specific yellow hue. An excellent choice for medical device manufacturers. Total Energy consumption of this unit is a scant 8w! Features a 100-240V (50/60Hz) Auto Switchable Transformer design. Available in black or white molded shades. ESD Safe. SPECIALIZED ULTRAVIOLET LED LIGHTING Micro-Lite® Ultraviolet (395nm) LED Ring Illuminator Micro-Lite® High Intensity Black Ultraviolet LED Ring Illuminator with 9 Extreme Output LEDs. At Home in Many Industries, Our UV2000-B Features 395nm Ultraviolet Light (365nm available). ESD SAFE Specialized Market Applications Include: • • • • Conformal Coating Dye Penetrant Inspection Forgery Analysis Mineral & Gemstone Inspection • Crime Scene Forensics • Homeland Security UV2000-B 33 Micro-Lite ® MICROSCOPE ILLUMINATION Flicker-Free Fluorescent Patented Ballast Technology Can Even Be Used with Cameras – No Rolling Image! Micro-Lite® High/Low Ring Illuminator MICRO-LITE® 150W FIBER OPTIC ILLUMINATORS FL3000-A Micro-Lite® Fully Variable Ring Illuminator FV1000 FL1000 ESD SAFE ESD SAFE ESD SAFE Micro-Lite® High/Low Fluorescent Ring Illuminator is the highest quality fluorescent ring on the market. The exclusive 'flicker-free' design makes for fatigue free usage. Our specialized ballast technology eliminates flickering that can cause eye fatigue, and allows for more lumen output per watt used. This is in a class all its own. 60mm ID (66mm available), with a whole host of adapters available. ESD Safe Micro-Lite® Fully Variable Fluorescent Ring Illuminator offers exclusive dimming control, as well as flicker-free performance. Dimming range from 100-20%. The same ballast technology as our FL1000, zero flicker and highest lumen output per watt in the industry, this illuminator can work with almost any microscope on the market today. 60mm ID (66mm available). ESD Safe MICRO-LITE® HIGH QUALITY REPLACEMENT BULBS FL3000-D FL150 FL200 FL320 FL400 Ultraviolet (365nm) 3200° Kelvin 150w EKE The key to our success with the FL3000 series is not singular… the devil is in the details. Included standard on all Micro-Lite® Fiber Optic illuminators is an internal IR filter. This retains all heat to the power box, and allows cool, bright light to enter the fiber optic cable. The solid state design of the FL3000 series also provides up to 45% more light than the competition. The FL3000 is overbuilt, to stand up to years of use and abuse. Our annular ring light guides are machined for an extremely slim profile, to allow for maximum working distance when mounted underneath a microscope. One of the unique features of the FL3000 series is our Fully Variable Intensity Control. Our specialized circuitry features a ‘rolling start’ transformer. What this means, is that instead of being able to turn the light onto high intensity from the start, which greatly degrades the bulb and component life, the FL3000 circuits have a millisecond voltage ramp up, which greatly extends the life of the components and bulbs. ESD SAFE Deluxe White We offer three distinct fiber optic styles; annular ring, dual gooseneck, and new backlit stage. We offer numerous annular ring sizes, for lighting of various diameter lens systems. FL3000-BL • ESD Safe and RoHS Compliant • Many Different Nosepiece Diameters Available • • • • • ESD SAFE FL500 34 Deep Red (658nm) FL700 Deep Green (544nm) FL600 16517 Deep Tri-Band Blue (450nm) Replaces Stocker & Yale #973-510B • • • • (.192” - .998”) Intense, cool, bright light due to the internal IR filter Cool, solid state design with 45% more light Extremely slim profile of annular light guide for maximum working distance Dual Gooseneck Includes (2) Focusable Lenses Aluminum and Steel Construction for Years of Use and Abuse Silent fan provides quiet, vibration free operation Solid State Operation - no rheostats to heat up and fail Optional color filter kit (#CFK-3) 1 Year Electrical Warranty 35 Micro-Lite ® MICROSCOPE ILLUMINATION Flicker-Free Fluorescent Patented Ballast Technology Can Even Be Used with Cameras – No Rolling Image! Micro-Lite® High/Low Ring Illuminator MICRO-LITE® 150W FIBER OPTIC ILLUMINATORS FL3000-A Micro-Lite® Fully Variable Ring Illuminator FV1000 FL1000 ESD SAFE ESD SAFE ESD SAFE Micro-Lite® High/Low Fluorescent Ring Illuminator is the highest quality fluorescent ring on the market. The exclusive 'flicker-free' design makes for fatigue free usage. Our specialized ballast technology eliminates flickering that can cause eye fatigue, and allows for more lumen output per watt used. This is in a class all its own. 60mm ID (66mm available), with a whole host of adapters available. ESD Safe Micro-Lite® Fully Variable Fluorescent Ring Illuminator offers exclusive dimming control, as well as flicker-free performance. Dimming range from 100-20%. The same ballast technology as our FL1000, zero flicker and highest lumen output per watt in the industry, this illuminator can work with almost any microscope on the market today. 60mm ID (66mm available). ESD Safe MICRO-LITE® HIGH QUALITY REPLACEMENT BULBS FL3000-D FL150 FL200 FL320 FL400 Ultraviolet (365nm) 320ºK 150w EKE The key to our success with the FL3000 series is not singular… the devil is in the details. Included standard on all Micro-Lite® Fiber Optic illuminators is an internal IR filter. This retains all heat to the power box, and allows cool, bright light to enter the fiber optic cable. The solid state design of the FL3000 series also provides up to 45% more light than the competition. The FL3000 is overbuilt, to stand up to years of use and abuse. Our annular ring light guides are machined for an extremely slim profile, to allow for maximum working distance when mounted underneath a microscope. One of the unique features of the FL3000 series is our Fully Variable Intensity Control. Our specialized circuitry features a ‘rolling start’ transformer. What this means, is that instead of being able to turn the light onto high intensity from the start, which greatly degrades the bulb and component life, the FL3000 circuits have a millisecond voltage ramp up, which greatly extends the life of the components and bulbs. ESD SAFE Deluxe White We offer three distinct fiber optic styles; annular ring, dual gooseneck, and new backlit stage. We offer numerous annular ring sizes, for lighting of various diameter lens systems. FL3000-BL • ESD Safe and RoHS Compliant • Many Different Nosepiece Diameters Available • • • • • ESD SAFE FL500 34 Deep Red (658nm) FL700 Deep Green (544nm) FL600 16517 Deep Tri-Band Blue (450nm) Replaces Stocker & Yale #973-510B • • • • (.192” - .998”) Intense, cool, bright light due to the internal IR filter Cool, solid state design with 45% more light Extremely slim profile of annular light guide for maximum working distance Dual Gooseneck Includes (2) Focusable Lenses Aluminum and Steel Construction for Years of Use and Abuse Silent fan provides quiet, vibration free operation Solid State Operation - no rheostats to heat up and fail Optional color filter kit (#CFK-3) 1 Year Electrical Warranty 35 American Designed, American Craftsmanship BONKOTE AMERICA Flux Dispensing Pens These new handy Bon Pens allow for very accurate flux dispensing on the work area, while eliminating dripping and flooding. You have total control at your finger tips, unlike all of the messy dispensing bottles on the market. Made in Japan. Very easily cleaned and maintained with alcohol or water, depending on Flux use. • Re-usable flux applicator • Replaceable tips & cartridge • Low cost, 7CC capacity • Fine point or broad point • Flexible shafts • Controlled application / no mess • Used with non-wash, wash or strong acid flux • Excellent for spot soldering on IC chips • All units sold in 5 packs Replacement Tips N NYLO 102T BON N NYLO 102K BON N NYLO 102D BON FELT 102F BON FELT 102B BON N NYLO 102S BON N NYLO 102 BON ge rtrid nt Ca ceme epla 02 R CA-1 See the Complete Lineup at www.ocwhite.com Distributed By: or Call: 413-289-1751 for a Representative Near You OCWMAINCAT-0916 2017 Industrial Catalog
UV2000-B 价格&库存
很抱歉,暂时无法提供与“UV2000-B”相匹配的价格&库存,您可以联系我们找货
UV2000-B
    • 1+5713.563221+739.13663
