TKSS-F
TKSS-F
    O.C.WHITE
    视频检测系统 CMOS,5MP 1x ~ 40x 12" LCD
TKSS-F 数据手册
Assembly Instructions FOR SUPER-SCOPE® AND MACROZOOM SERIES These assembly instructions will help you get up and running quickly. The products covered with these instructions are depicted below. If these instructions do not match your product, or you are unable to find the information you need, please call customer service at (413) 289-1751. Super-Scope ® HD INTEGRATED INSPECTION MacroZoom VIDEO INSPECTION SYSTEM For troubleshooting or to report an issue please contact us at: info@ocwhite.com or call (413) 289-1751. Assembly Instructions FOR SUPER-SCOPE® AND MACROZOOM SERIES O.C. White Ball Bearing Base Assembly E Parts List A) Base & Post Assembly B) Safety Collar & Handle C) Glide Arm Assembly D) Large Handle E) Large Handle F) Small Handle G) 20mm Drop Arm Assembly H) Safety Stop I) Hex Key - 8mm C D F G B H A E F D I H G C For troubleshooting or to report an issue please contact us at: info@ocwhite.com or call (413) 289-1751. Assembly Instructions FOR SUPER-SCOPE® AND MACROZOOM SERIES Locking Safety Collar 1. Place the base stand on a sturdy level surface and position Safety Collar at approximate working distance. Tighten lock handle firmly. 2. Insert Locking Handles into Glide Arm locations shown and screw in several turns. Do not tighten. 3. Slide Glide Arm down post to Safety Ring. Tighten post locking handle firmly. Tighten Lock Handle Then Tighten Hex Bolt Firmly 4. Slide Drop Arm into socket at the end of the Glide Arm. Loosen the locking bolt with the 8mm Hex Key to position shaft plumb to the floor. Tighten very firmly. Locking Knob 5. Slide microscope Focusing Mount up onto shaft. Tighten the Locking Knob lightly. Tighten Safety Stop Tighten Swivel Locking Knob 6. Screw Safety Stop onto end of shaft tightly. Reposition Focusing Mount down to Safety Stop and tighten. Adjust position of Focusing Mount and tighten the Swivel Locking Knob. For troubleshooting or to report an issue please contact us at: info@ocwhite.com or call (413) 289-1751. Assembly Instructions FOR SUPER-SCOPE® AND MACROZOOM SERIES O.C. White Articulating Arm Components E J I K Parts List A) Base Clamp B) Main Post C) Locking Safety Collar D) Post Mount E) Articulating Arm F) Locking Handle G) Locking Handle H) Swivel Lock Knob I) Swivel Lock Knob J) Drop Arm Assembly K) Safety Stop L) Hex Key - 8mm H D F G C B A E I H C F G H D I G F A C B L K J For troubleshooting or to report an issue please contact us at: info@ocwhite.com or call (413) 289-1751. Assembly Instructions FOR SUPER-SCOPE® AND MACROZOOM SERIES Main Post Base Clamp Post Mount Make full contact with table edge Maximum Opening of 3 15/32 or 88mm 1. Screw Main Post into top of Base Clamp. Slide jaw of Base Clamp onto edge of table top. Ensure full contact of the clamp to the edge of the table. Tighten clamp handle firmly until unit is held securely. Slide into Articulating Arm Socket Post Mount Locking Handle Articulating Arm Locking Handle Locking Safety Collar Handle 2. Position Safety Collar at approximate working distance. Tighten it’s locking handles firmly. Insert locking handles into Articulating Arm locations shown and screw in several turns, but do not tighten. 3. Slide Articulating Arm into Flex Arm socket. Tighten post locking handle firmly. 1. Slide Focus Mount onto Shaft Tighten Lock Handle 2. Tighten Safety Stop 3. Reposition Mount to Bottom of Shart Then Tighten Hex Bolt Firmly Articulating Arm Locking Handle 4. The angle adjustment of the Articulating Arm is secured by the Locking Handle. Loosen counter-clockwise to desired angle and tighten firmly. Tighten Safety Stop 5. Slide Drop Arm into socket at end of Articulating Arm. Loosen hex bolt and position shaft plumb to floor. Tighten locking handle first, then tighten hex nut very firmly. Tighten Swivel Locking Knob 6. Slide Focus Mount onto Drop Arm shaft. Lightly tighten knob. Screw Safety Stop onto end of shaft firmly. Reposition Focusing Mount down to Safety Stop and tighten knob. Slide microscope head into Focus Mount opening and secure small locking knob. For troubleshooting or to report an issue please contact us at: info@ocwhite.com or call (413) 289-1751. Assembly Instructions FOR SUPER-SCOPE® AND MACROZOOM SERIES Super-Scope® HD Video Components A) 12” Monitor w/ Mount B) 5MP Hybrid Digital Camera C) Screen to Case Mounting Screws D) SD Card - 8 Gb E) Screen Mounting Bracket Attach with Mounting Screws Finger Tight F) 100-240v (50/60hz) Transformer G) “Y” Power Splitter H) Cord for Transformer I) USB Cord J) HDMI “L” Adapter 12V DC Inputs Screw Lens into Camera Clockwise 1. Attach monitor to camera with both mounting screws turned finger tight. Attach lens to camera by turning counter clockwise until seated. K) Long HDMI Cable L) Short HDMI Cable M) Wireless Mouse N) Mouse Receiver (Ships in bottom of mouse) O) “AA” Mouse Battery Wireless Mouse Receiver HDMI Monitor Cable & Adapter 2. Slide Camera & Monitor Assembly into the Stand Assembly Focus Mount. Attach cables as shown. Insert Wireless Mouse Receiver into USB port on camera. 3. Turn ON Camera & Screen. Using the mouse, toggle left hand side hidden window. Open the Settings tab, and select 60hz for optimum performance. For troubleshooting or to report an issue please contact us at: info@ocwhite.com or call (413) 289-1751. Assembly Instructions FOR SUPER-SCOPE® AND MACROZOOM SERIES How to Parfocal your Super-Scope® Why Parfocal your Microzoom? Parfocaling enables you to cycle through your microscope’s zoom range without losing focus. APERTURE RING Turn Aperture Ring Past Middle Detent ZOOM RING Set Working Height between 6” and 12” 1. Set working height of Super-Scope® to preferred distance between 6-12”. If 12”+ is required, remove lower Close-up lens. Turn to Focus FOCUS RING 2. Turn the Aperture Ring to First Indicator Dot (halfway open). Then close slightly as shown (white line before indicator). Rotate the Zoom Ring to its highest zoom setting. Turn the Focus Ring until image on screen is in focus. Chrome Lens Mount 3. Turn the Zoom Ring to its lowest zoom setting (do not adjust aperture or focus ring). If image is out of focus, you will need to adjust Chrome mount at bottom of camera. Remove lens from focusing arm and remove lens from camera. 4. Unscrew the 3 hex bolts from mount. Rotate chrome mount in or out and reinstall (1) bolt. Reassemble lens, camera, and screen and recheck focus using steps above. Repeat and readjust (if necessary) until field is focused at both high and low zoom (reinstall remaining bolts at this time). For troubleshooting or to report an issue please contact us at: info@ocwhite.com or call (413) 289-1751. Assembly Instructions FOR SUPER-SCOPE® AND MACROZOOM SERIES AIMS Advanced Imaging & Measurement Suite INTEGRATED SOFTWARE FUNCTIONS FOR ALL CAMERA BASED SYSTEMS Our exclusive Ultra-Cam II™ 5MP Hybrid HDMI/USB Camera pulls double duty for both production and quality assurance needs. The AIMS System’s Software documentation as well as PC software suite are available for download at https://support.ocwhite.com. Featuring both HDMI and USB outputs, its integrated smart camera controls include a host of onboard software features including: Image Capture Calibrated Measure Quickly capture image and videos while inspecting directly to the 8GB SD card. Sort and archive to a PC. An entire array of Measurement Tools for high precision and repeatable measurements without a PC! Real Time Compare Ultra-High Sensitivity Compare live video feed with previous captured images. Search and sort for instant comparison. Industry leading low light sensitivity allows for crystal clear images where competitors cameras fail. More sensitivity requires less light for less glare! AIMS PC SUITE ! NEW ADDS REMARKABLE FEATURES TO AIMS FOR MAXIMUM PRODUCTIVITY AND PRECISION! Extended Depth of Focus Ultra-High Sensitivity This specialized tool allows for ‘stacking’ of multiple image captures of tall objects taken at various focal lengths, into a single super high clarity image. Inspecting something that is just too big to view all at once? Capture multiple images of the object, then ‘stitch’ them together digitally to create a single extra-large image. For troubleshooting or to report an issue please contact us at: info@ocwhite.com or call (413) 289-1751.
TKSS-F 价格&库存
很抱歉,暂时无法提供与“TKSS-F”相匹配的价格&库存,您可以联系我们找货
TKSS-F
  • 1+51660.013281+6715.63455
