51900-B
51900-B
    O.C.WHITE
    臂,麦克风 29.0"(736.6mm)水平式,12.0"(304.8mm)垂直式
51900-B 数据手册
TM DESIGNED FOR MODULARITY The World’s Easiest & Most Expandable Monitor / Microphone System! The Ultima™ SMS Product Family is the most Scalable Monitor and Mic System that money can buy. All components drop together quickly. You can easily retrofit a single monitor and microphone unit to a complete 5 monitor and mic setup. Easily change a three-mic Round Table right into a two-monitor/two-microphone stand in minutes! Even the cables fit into hidden channels in seconds. It grows on you and with you! Easy System Expansion WORLD’S BEST MIC ARMS! by O.C. White Co. SMS-LD FlexArm™ comes with 8” horizontal arm Low Profile Design Hides From Camera View! The Ultima™ Systems begin with an Ultra Low Profile mic arm (the ULP lowers down to 5” from your table surface!). Your audience should see your talent, not your mic boom. Superior arms even let you move the arms while on the air without worrying about noise! From it’s Broadcast Black color to the easy wire management, the Ultima™ SMS is built for Professionals! Easy & Fast Wire Management Design Add up to six monitors instantly! SMS-LD monitor arms hold up 4-14 lbs each! Additional weight ranges available. Quick-release VESA brackets make mounting a snap! Wire Management is a Snap, with Easy-Access Hidden Channels and Lids. The System Expands and Rewires in Seconds! THE ULTIMATE DESIGN FOR LONGEVITY Time Proven to Outlast the Competition! The same legendary quality that you expect from O.C. White mic arms is built into all Ultima™ SMS products. With the highest quality products in the industry, our high standards make the longest lasting boom arms available! DESIGNED FOR TV AND BROADCAST Any Combination of Microphones and Monitors is Easily Assembled! Go From a Round Table to 3 hosts and Back! Shown: ULP-3RT Round Table Special with the NEW Mic-Lite™ ON AIR Alert Lights Only ULTIMA™ SMS Offers Such a WIDE RANGE OF MOTION for the Best Fit and Ideal Ergonomics DESIGNED FOR ERGONOMICS Unsurpassed Range of Motion for a Perfect Fit! Broadcasting has never been so comfortable! No matter if you’re tall, short, close, far, standing or sitting – Ultima™ SMS fits you and your guests with total comfort and ease of use. Ultima™ ULP mic arms and SMS monitor arms move to the best height and distance easily. Supports mics up to 0-6 lbs! by O.C.White Co. ULP-MB “ULTRA LOW PROFILE” *Microphone not included. 10” of Vertical Travel With over 12" of console clearance, the ULP-12R provides plenty of room for tight spaces. Wire management keeps a visually clean appearance. Signals Red & White Right Under Your Mic! *Microphones not included. *Microphones not included. *Microphone not included. *Microphone not included. Ultra Low Profile ULP-MB stays well out of view! Adjusts up to 5” from horizontal position. ULP-2RT FOR TWO GUESTS ULP-12MA FOR EXPANSION ULP-12R “UP & OVER ” World’s Best “ON-AIR” Light The remarkable Ultima™ system begins with the ULP-12MA, a one mic and a choice of 12” or 18“ bolt-through riser post that grows with your studio and your needs. With a ULP-2RT, you're ready for live guests now AND studio growth later. The interchangeble 18“ bolt-through riser post can also accept monitor arms as you need them. The ULP-3RT Round Table Special is a show-center, with three 29" mic arms for a total 58" reach. With it’s SMS 18“ bolt-through riser post, it can easily accomodate customization! COMING SOON!!! Supports monitors up to 4-14 lbs! SMS-LD-1-ULP *Microphones & monitors not included. SMS-LD-2-ULP TWO MONITOR / ONE MIC *Microphones & monitors not included. Add a monitor arm to expand your working Ultima™ SMS-LD-1-ULP is a single Mic & footprint. The SMS-LD-2-ULP comes ready Monitor system with an 18” clamp/bolt through riser. 29” Mic arm supports up to 6 for two monitors and one microphone. All Ultima™ LD arms feature hidden wire lb mics, Ultima™ LD arm supports up to management channels for a clean look. 4-14 lb monitors. SMS-LD-2-2ULP TWO MONITOR / TWO MICS *Microphones & monitors not included. Customize your Ultima™ SMS any way you need. This SMS-LD-2-2ULP shows how easy it is to add mic arms or monitor arms in minutes with fit-together joints and fast wire management channels. SMS-LD-3-3ULP THREE MONITOR / THREE MICS *Microphones & monitors not included. Three guests on one system! The Ultima™ SMS-LD-3-3ULP easily adapts in minutes. Point mics and monitors in any direction for the ultimate roundtable setup! SMS-LD-5-ULP FIVE MONITOR / ONE MIC *Microphones & monitors not included. The Ultima™ SMS-LD-5-ULP Five Monitor & Mic system surrounds the user with highly movable monitors. Share monitor views from any angle. Adapts to new arrangements in seconds! Build Your Setup Any Way You Need! All Components Are Interchangeble and Endlessly Expandable! See the Entire Lineup at www.OCWhite.com The 61900-SERIES Better By Design. It’s the industry favorite for a good reason. This pro-level performer is designed rugged and built to last. There’s a lot of technology built into that retro look. Music-wire springs, thick aluminium armatures, solid CNC machined base block, patented & clutter-reducing wire channels, adaptable & interchangeble springs. Every piece designed to give your microphone an ERGONOMIC, solid and silent foundation. Integrated XLR Cradle For Clean Through-Desk Wire Management. Wide Range Holding Capacity Elite® Arms Provide Squeek-Free Operation with 0-4 lb of Support Using Optional Springs! Tough & Rugged Industrial Armature Broadcast Microphone Arms For Every Studio and Station 51900-B Mic Arm Patented Wire Channel Technology Withstands Years of Abuse! Reduces Clutter and Noise! Music Wire Technology Eliminates Spring Noise! Huge Strength at a Critical Joint! A Solid Base for the Most Sensitive Microphones. The Industry’s Best! No-Squeek Solid Cast 15” Riser Eliminates Movement Noise! *Microphone and yoke not included. 14199-R-B Extended Single Piece CNC Machined Base Block Silent On-Air Performance Mounted on a 12” riser the 51900 series clears most consoles offering a 29” reach. Its Elite® arms offer the same channel management and sturdy build of the 61900. Also available in Black and Gold. 51900-3B Round Table *Microphone and yoke not included The ProBoom® 14199-B Extended Mic Arm, designed for studios where extra reach is required. It's 45" reach includes a 12" riser, but also fits our other mounts. Extra long Elite® arms have extra mount points to adjust spring for heavier mics. Available in Black and Gold. A triple12” riser holds three 29“ reach arms for this classic Round Table setup. It’s Elite® arms also offer the same channel management and sturdy build of the 61900. Also available in Black and Gold. *Microphone and yoke not included. 14192-R-B *Microphone and yoke not included. The ProBoom® 14192-B Extended Mic Arm, designed for studios where extra reach is required. It's 45" reach includes a 12" riser, but also fits our clamps, flat mounts and wall mounts. Also uses Elite®arms with the wire management and beefy build. Available in Black and Gold. The JUNIOR: Built for Podcaster Budgets 14198-R-B *Includes 12” riser *Microphone and yoke not included. Built for lightweight mics (to 1.25 lbs) with a 45” reach, the Junior is perfect for podcaster beginners. Also available with clamp (14198-C-B) Shown: 61900-BG Used By Pros World Wide! OC White ProBooms Are Industrial Tough and Engineered for Flawless ON AIR Performance! See the Entire Lineup at www.OCWhite.com Signal-Lite ™ ON-AIR & Alert Lighting Designed For Small Studios See our new modular Signal-Lite™ ! Configure them anyway you need! Numerous lighting and mounting options available. For more info, please consult O.C. White Co. NEW SHORT ARM MODELS NOW AVAILABLE! LOW PROFILE SINGLE ARM * Complete with clamp ** 12” Optional riser or table bushing available Our new Signal-Lite™ is a modular, stackable, multi-color customizable alert system. Mounts on a post, wall bracket or table mount . Also available to fit on our 12” , 18” or 30” Ultima™ SMS center post. Wire direct to your console and never miss a cue! Professional grade systems from O. C. White Co. Introducing our affordable product line for smaller studios. Unique designs to fit limited space like “The Shorty” with it’s double 10” arms or the 22” reach “Low Profile Single Arm” to stay out of camera view. They’re all tough, professional grade equipment built to last from O. C. White Co. DISTRIBUTED BY: Find More ONLINE at: www.OCWhite.com or CALL: 413-289-1751 OCW-BROADCAST-4-2016
51900-B 价格&库存
很抱歉,暂时无法提供与“51900-B”相匹配的价格&库存,您可以联系我们找货
51900-B
  • 1+2193.151911+283.71768
