GKCWBC-P04QB00-000L
GKCWBC-P04QB00-000L
    ODU(欧度)
    4 针位圆形连接器 插座,母型插口 焊接
GKCWBC-P04QB00-000L 数据手册
2 3 5 4 Additional coding View in direction A 6 50 Nur rot gestempelte oder auf Laufkarte gedruckte Dokumente unterliegen dem Aenderungsdienst und sind zur Fertigung freigegeben. Only red stamped or on jobcard printed documents are managed. These documents are approved for production. Color coding 60 10 M7x0.5 0.3 Keying indicationA B 0.5 1.5 7.1+0.1 0 B GKCW BC-P04QB00-000L 6.6+0.1 0 Mechanical coding: B Color coding: red 0.3 8.5 A C GK0W +0.3 0 0.3 1.5 A max.4 4.5 A C-P04QB00-000L 2.5 C 8 (6.6) Mechanical coding: A Color coding: light brown Color coding Keying indication Receptacle O-ring Nut 1) Nutdriver: 713.098.001.000.000 Torque: 0.5 Nm PCB-Layout View in mating direction A 8:1 D D A CAD: Creo Parametric 10 30 20 Earth tag Panel cut-out A All Rights reserved, including possible patents or trademarks. Documents shall not be provided to a third party or duplicated in any form without prior written permission. 40 70 SW 6.5 A 8 7 9.9 Fuer Fall ohne noch diese Unterlage behalten wir uns alle Rechte vor, auch fuer den der Patenterteilung oder Gebrauchsmustereintragung. Sie darf unsere vorherige schriftliche Zustimmung weder vervielfaeltigt sonstwie benutzt, noch Dritten zugaenglich gemacht werden. 1 GKCW 8.2 C C-P04QB00-000L 4x n 0.4 Mechanical coding: C Color coding: blue Delivery condition - 2 Print contacts 3) Current load: 1A @D t40 $ (Single contact) Test voltage: 900V (acc. SAE AS 13441:1998, Contact to contact) Rated voltage: 300V (acc. SAE AS 13441:1998) 2) 2) Maximal operating voltage at sea level up to 2.000 m. Rated voltage applies no other electrical safety standard. In case other standards rule a specific use of the connector, the application specific safety criteria shall be considered first. This must be evaluated in the frame of equipment engineering. A GKCW D C-P04QB00-000L Mechanical coding: D Color coding: green 1 2 3) The recommended thickness of the PCB is about 1.2 mm. Other versions are available on request. Bei den hier dargestellten ODU-Steckverbindern handelt es sich nach DIN EN 61984:2009 um Steckverbinder ohne Schaltleistung (COC) ! /the pictured ODU-connectors are in relation to DIN EN 61984:2009 connectors without switching capacity (COC) ! 3 4 3 E 1.65 150 $ 1) ODU recommend an additional locking of the nut with adhesive (e.g. Loctite 2701) to the screw thread. F 4 3:1 Technical information E 1 3x n 0.6 Benennung/description: R Allgemeintoleranz/general tol.: DIN ISO 2768-mH Tolerierung / Tolerancing: DIN ISO 8015 Status/state: Version: Approved revision: Erstellt/prepared 14.01.2016spantze Geraeteteil cpl. A CAD-Nr.: design-ID: Teile-ID: part-ID: Oxaion-Nr.: ODU-MUEHLDORF Ursprung/origin.: Datum/date Name/name see BOM Maßstab: scale: Receptacle Geaendert/revised 20.02.2017cbauer Freigabe/released 21.02.2017mmeier Werkstoff: material: 00101733 GKCW_C-P04QB00-000L Format: size: 6:1 Einheit: dim.: Bl.: A3 mm sheet: 1
GKCWBC-P04QB00-000L 价格&库存
很抱歉,暂时无法提供与“GKCWBC-P04QB00-000L”相匹配的价格&库存,您可以联系我们找货
