2
3
5
4
Additional coding
View in direction A
6
50
60
10
M7x0.5
0.3
Keying indicationA
B
0.5
1.5
7.1+0.1
B
GKCW
BC-P07QB00-000L
6.6+0.1
Mechanical coding: B
Color coding: red
0.3
8.5
A
C
Color coding
Receptacle
GKCW
+0.3
1.5
4.5
A C-P07QB00-000L
O-ring
2.5
C
8
(6.6)
Mechanical coding: A
Color coding: light brown
Keying
indication
A
max.4
PCB-Layout
View in mating direction A
8:1
Nut
1)
Nutdriver: 713.098.001.000.000
Torque:
0.5 Nm
8.2
D
GKCW
1
C C-P07QB00-000L
3
Delivery condition
Technical information
F
A
GKCW
D C-P07QB00-000L
Mechanical coding: D
Color coding: green
1
2
3) For pcb assembling see pcb assembly instruction 009.410.120.000.000
3
4
3x n 0.6
E
Bei den hier dargestellten ODU-Steckverbindern handelt es sich nach
DIN EN 61984:2009 um Steckverbinder ohne Schaltleistung (COC) !
/the pictured ODU-connectors are in relation to DIN EN 61984:2009
connectors without switching capacity (COC) !
Print contacts
3)
Current load: 1A
@D t40 $ (Single contact)
Test voltage: 750V (acc. SAE AS 13441:1998, Contact to contact)
Rated voltage: 250V (acc. SAE AS 13441:1998)
2)
2) Maximal operating voltage at sea level up to 2.000 m.
Rated voltage applies no other electrical safety standard. In
case other standards rule a specific use of the connector, the
application specific safety criteria shall be considered first.
This must be evaluated in the frame of equipment engineering.
4
150 $
E
1) ODU recommend an additional locking of the nut with adhesive
(e.g. Loctite 2701) to the screw thread.
5
1.9
3:1
6
7
2
Mechanical coding: C
Color coding: blue
D
7x n 0.4
A
CAD: Creo Parametric
Color coding
60
6x
Nur rot gestempelte oder auf Laufkarte gedruckte Dokumente
unterliegen dem Aenderungsdienst und sind zur Fertigung freigegeben.
Only red stamped or on jobcard printed documents
are managed. These documents are approved for production.
10
30
Earth tag
Panel cut-out
A
All Rights reserved, including possible patents
or trademarks. Documents shall not be provided
to a third party or duplicated in any form
without prior written permission.
40
70
SW 6.5
A
8
7
9.9
Fuer
Fall
ohne
noch
diese Unterlage behalten wir uns alle Rechte vor, auch fuer den
der Patenterteilung oder Gebrauchsmustereintragung. Sie darf
unsere vorherige schriftliche Zustimmung weder vervielfaeltigt
sonstwie benutzt, noch Dritten zugaenglich gemacht werden.
1
Benennung/description:
R
Allgemeintoleranz/general tol.:
DIN ISO 2768-mH
Tolerierung / Tolerancing:
DIN ISO 8015
Status/state:
Version:
Approved revision:
Erstellt/prepared
14.01.2016spantze
Geraeteteil cpl.
A
CAD-Nr.:
design-ID:
ODU-MUEHLDORF
Ursprung/origin.:
Name/name
00101740
Teile-ID:
part-ID:
Oxaion-Nr.:
Datum/date
see BOM
Maßstab:
scale:
Receptacle
Geaendert/revised
20.02.2017cbauer
Freigabe/released
21.02.2017mmeier
Werkstoff:
material:
A
GKCW_C-P07QB00-000L
Format:
size:
6:1
Einheit:
dim.:
Bl.:
A3
mm
sheet: 1
GKCWAC-P07QB00-000L 价格&库存
很抱歉,暂时无法提供与“GKCWAC-P07QB00-000L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1080.898551+139.84308
