K1CWAC-P07LBC0-0000
K1CWAC-P07LBC0-0000
    ODU(欧度)
    7 针位圆形连接器 插座,母型插口 焊杯
K1CWAC-P07LBC0-0000 数据手册
3 Additional coding View in direction B 5 4 6 Keying indication 50 40 30 20 10 Color coding 9 5.6 8 A 8 7 A 9.8 2 B B Fuer Fall ohne noch diese Unterlage behalten wir uns alle Rechte vor, auch fuer den der Patenterteilung oder Gebrauchsmustereintragung. Sie darf unsere vorherige schriftliche Zustimmung weder vervielfaeltigt sonstwie benutzt, noch Dritten zugaenglich gemacht werden. 1 SW8 K1CWBC-P07LBC0-0000 Mechanical coding: B Color coding: red K1CWAC-P07LBC0-0000 0.8 Nur rot gestempelte oder auf Laufkarte gedruckte Dokumente unterliegen dem Aenderungsdienst und sind zur Fertigung freigegeben. Only red stamped or on jobcard printed documents are managed. These documents are approved for production. Mechanical coding: A Color coding: light brown 2.5 A C 0.8 18.7 B C Only insert View in direction A 10:1 In-Line-Receptacle Crimp sleeve 1) D Backshell 1) Keying indication pos. 6 Color coding pos. 1 D pos. 7 K1CWCC-P07LBC0-0000 Mechanical coding: C Color coding: blue Delivery condition CAD: Creo Parametric All Rights reserved, including possible patents or trademarks. Documents shall not be provided to a third party or duplicated in any form without prior written permission. 2:1 E E Technical information - Max. cable n 5.0mm (Based on cable with one braided shield) Solder contacts: AWG28 Current load: 1A@D t40 $ (Single contact) Test voltage: 750V (acc. SAE AS 13441:1998, Contact to contact) Rated voltage: 250V (acc. SAE AS 13441:1998)2) 1) For crimp information, torque, etc. see assembly instruction 010.650.001.000.002 F (www.odu.de/downloads) 2) Maximal operating voltage at sea level up to 2.000 m. Rated voltage applies no other electrical safety standard. In case other standards rule a specific use of the connector, the application specific safety criteria shall be considered first. This must be evaluated in the frame of equipment engineering. K1CWDC-P07LBC0-0000 Mechanical coding: D Color coding: green 1 2 3 4 Bei den hier dargestellten ODU-Steckverbindern handelt es sich nach DIN EN 61984:2009 um Steckverbinder ohne Schaltleistung (COC) ! /the pictured ODU-connectors are in relation to DIN EN 61984:2009 connectors without switching capacity (COC) ! Benennung/description: R Allgemeintoleranz/general tol.: DIN ISO 2768-mH Tolerierung / Tolerancing: DIN ISO 8015 Status/state: Version: Approved revision: Erstellt/prepared 12.01.2016prock Kabelteil cpl. A CAD-Nr.: design-ID: Teile-ID: part-ID: Oxaion-Nr.: ODU-MUEHLDORF Ursprung/origin.: Datum/date Name/name Maßstab: scale: In-Line Receptacle Geaendert/revised 20.06.2016mmeier Freigabe/released 20.06.2016mmeier Werkstoff: material: 00101625 K1CW_C-P07LBC0-0000 Format: size: 6:1 Einheit: dim.: Bl.: A3 mm sheet: 1
K1CWAC-P07LBC0-0000
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型集成电路,用于红外发射和接收。
3. 引脚分配:EL817有8个引脚,包括Vcc、Out、GND、Vo、RE、DE、IT和DT。
4. 参数特性:工作电压范围为3.8V-6V,工作电流为10mA,隔离电压为2.5kV。
5. 功能详解:EL817通过红外信号实现电信号的传输,具有抗干扰能力强、传输距离远等特点。
6. 应用信息:广泛应用于遥控器、无线通信、工业控制等领域。
7. 封装信息:EL817采用DIP-8封装。
K1CWAC-P07LBC0-0000 价格&库存
很抱歉,暂时无法提供与“K1CWAC-P07LBC0-0000”相匹配的价格&库存,您可以联系我们找货
K1CWAC-P07LBC0-0000
  • 1+1069.566381+139.07309
库存:2
