S4BMFG-P41MCD9-0270
S4BMFG-P41MCD9-0270
    ODU(欧度)
    41 针位圆形连接器 插头,公引脚 焊杯
S4BMFG-P41MCD9-0270 数据手册
S4BMFG-P41MCD9-0270 ODU MEDI-SNAP®, Straight plug for cable bend relief General information Part number S4BMFG-P41MCD9-0270 Termination Solder Size 3.5 Locking principle Push-Pull Keying F (90°) Cable Diameter 9.1 – 10.5 mm Cable outlet For cable bend relief Contact insert description Number of contacts 41 Contact type Pins Contact diameter 0.5 mm Insulator material PEEK Wire cross section AWG 26 Termination Solder Termination diameter 0.6 mm Technical information Max. creepage and air clearance distance 0.5 mm (Contact to contact) Nominal current single contact 6A IEC 60512-5-2:2002 (DIN EN 60512-5-2:2003) Nominal current insert 2.4 A VDE 0298-4:2003 A Test voltage 0.75 kV AC EIA-364-20F:2019-02 All shown connectors are rated to a safety extra low voltage (SELV) of less than 50 V AC / 75 V DC, according to IEC 61140:2016 (VDE 0140-1:2016) Protection against electric shock - Common aspects for installation and equipment. In case other standards rule a specific use of the connector, the application specific safety criteria shall be considered first. In this context, lower voltage ratings may be valid. Warning: Danger to life for operating voltages above 50 V AC / 120 V DC! Mechanical and environmental data Degree of protection* IP68 Operating temperature -50 °C – 120 °C Mating cycles 2000 *mated condition S4BMFG-P41MCD9-0270 ODU MEDI-SNAP®, Straight plug for cable bend relief 230221 1/2 Insulator materials MEDI-SNAP® Standard Flammability rating PEEK UL 94 V-0/1.5 Operation temperature -50 to +250 °C Dielectric strength IEC 60243-1:2013 (VDE 0303-21:2014) 19 kV/mm Comparative figure of the creep resistance CTI IEC 60112: 2009 (VDE 0303-11:2010) 175 Water absorption ASTM D 570:1998 / ISO 62:2008 0.1 % Sterilization (autoclaving)* DIN EN 13060:2019-02 > 200 cycles Insulation resistance IEC 60512-3-1:2002 (DIN EN 60512-3-1:2003-01) > 1 x 10 Ω 12 *this applies to the entire connector Material and surface treatments Housing PEI gray Contact material Cu-alloy with gold finish The contact arrangement of an ODU data transmission connector differs from a standard data transmission connector due to the robust ODU specific design. However, the ODU design meets the electrical specifications of the respective standard data transmission protocol. All shown connectors are defined without breaking capacity (COC) according to IEC 61984:2008 (VDE 0627:2009). The contact arrangement of an ODU data transmission connector differs from a standard data transmission connector due to the robust ODU specific design. However, the ODU design meets the electrical specifications of the respective standard data transmission protocol. ODU MEDI-SNAP® and MINI-SNAP® are UL-approved (E110586). ODU reserves the right to make changes based on the current state of knowledge without prior notice without being obliged to provide replacement deliveries or refinements of older designs. S4BMFG-P41MCD9-0270 ODU MEDI-SNAP®, Straight plug for cable bend relief 230221 2/2
S4BMFG-P41MCD9-0270 价格&库存
很抱歉,暂时无法提供与“S4BMFG-P41MCD9-0270”相匹配的价格&库存,您可以联系我们找货
