OWPB-909018S-40-03
OWPB-909018S-40-03
    OLEWOLFF
    压电 蜂鸣器 传感器,外部驱动 3 V 3mA 4kHz 77dB @ 12V,10cm 表面贴装型 焊盘
OWPB-909018S-40-03 数据手册
DATE PAGE 17 Sep, 15 1/7 SPECIFICATIONS OLE WOLFF INTERNATIONAL WWW.OWOLFF.COM DK PART NUMBER: OWPB-909018S-40-03 SPECIFICATIONS Piezo Transducer Part Number OWPB-909018S-40-03 Noted RoHS Compliant DRAWN CUSTOMER SIGN OLE WOLFF SIGN CHECKED APPROVED REVISION NOTES: Date Rev. No. Description of Revision OLE WOLFF ELEKTRONIK A/S Roedengvej 25 DK-4180 Soroe Denmark OLEWOLFF ELECTRONICS INC. 4340 Cross Street Downers Grove, Chicago IL 60515, USA OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLEWOLFF ELEKTRONIK Yliopistonkatu 26A, P.O. Box 257, FIN-40101 Jyväskylä, FINLAND OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +45 57833830 FAX: +45 57820019 TEL : +847 962 4169 FAX : +630 852 2520 TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156 DATE PAGE 17 Sep, 15 2/7 OLE WOLFF INTERNATIONAL WWW.OWOLFF.COM SPECIFICATIONS DK PART NUMBER: OWPB-909018S-40-03 1. SCOPE THIS SPECIFICATION IS APPLIED TO OLE WOLFF PIEZO TRANSDUCER UNIT OF MODEL: OWPB-909018S40-03 2. GENERAL REQUIREMENTS OPERATING TEMPERATURE RANGE: -40℃  +85℃ STORAGE TEMPERATUR RANGE: -40℃  +85℃ 3. MECHANICAL LAYOUT & DIMENSIONS DIMENSIONS: SHOWN IN FIGURE 4. WEIGHT:0.25g 4. ELECTRICAL CHARACTERISTICS NO. ITEM SPECIFICATION 1 OPERATING VOLTAGE 3Vp-p 2 RESONANT FREQUENCY 3 MAX INPUT VOLTAGE 4 CAPACITANCE AT 120HZ 5 * SOUND OUTPUT AT 10CM ≥65dB 6 * RATED CURRENT ≤3mA 7 HOUSING MATERIAL LCP 8 ROHS Yes 4000±500Hz 25Vp-p 12000pF±30% *Applying rated voltage (Resonant frequency, Square wave) OLE WOLFF ELEKTRONIK A/S Roedengvej 25 DK-4180 Soroe Denmark OLEWOLFF ELECTRONICS INC. 4340 Cross Street Downers Grove, Chicago IL 60515, USA OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLEWOLFF ELEKTRONIK Yliopistonkatu 26A, P.O. Box 257, FIN-40101 Jyväskylä, FINLAND OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +45 57833830 FAX: +45 57820019 TEL : +847 962 4169 FAX : +630 852 2520 TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156 DATE PAGE 17 Sep, 15 3/7 OLE WOLFF INTERNATIONAL WWW.OWOLFF.COM SPECIFICATIONS DK PART NUMBER: OWPB-909018S-40-03 5. RELIABILTY TEST - After Test All specifications must be satisfied after the test. 5.1 High temperature Storage Life Test Temperature: +85℃ Duration: 120HRS 5.2 Low temperature Storage Life Test Temperature: -30℃ Duration: 120HRS 5.3 Humidity Test Temperature: 40±2℃ Humidity: 90~95%RH Duration: 120HRS 5.4 Temperature cycling Test Temperature: -30±2℃ Duration: 30min Cycle: 5 cycles +20±5℃ 15min +85±2℃ 30min +20±5℃ 15min 5.5 Vibration Test Input power: 10~55Hz then 55~10Hz, Amplitude: 1.0mm, Duration: 2 hours per plane in each three mutually perpendicular 5.6 Shock Test Sounder shall be measured after being applied shock (980m/s²) for each three mutually perpendicular directions to each of 3 times by half sine wave. 5.7 Drop Test Dropped naturally from 700mm height onto the surface of 10mm thick wooden board. 2 directions-upper and side of the part are to be applied. 5.8 Lead pull The part shall be pushed with a force of 9.8N for 10±1 seconds behind the part. After the test part shall meet specifications without any degradation in appearance and performance. 5.9 Recommended temp. Profile for Reflow Oven Shown in Fig.1 Warranty: For a period of one year from date of manufacture under normal operations. OLE WOLFF ELEKTRONIK A/S Roedengvej 25 DK-4180 Soroe Denmark OLEWOLFF ELECTRONICS INC. 4340 Cross Street Downers Grove, Chicago IL 60515, USA OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLEWOLFF ELEKTRONIK Yliopistonkatu 26A, P.O. Box 257, FIN-40101 Jyväskylä, FINLAND OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +45 57833830 FAX: +45 57820019 TEL : +847 962 4169 FAX : +630 852 2520 TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156 DATE PAGE 17 Sep, 15 4/7 SPECIFICATIONS OLE WOLFF INTERNATIONAL WWW.OWOLFF.COM DK PART NUMBER: OWPB-909018S-40-03 6. RECOMMENDED TEMP. PROFILE FOR REFLOW OVEN (Figure 1) Profile Feature Pb-Free Assembly Average ramp-up rate(TL to Tp) 3℃/second max. Preheat -Temperature Min.(Tsmin) 150℃ -Temperature Min.(Tsmax) 200℃ 60~180 seconds -Temperature Min.(ts) Tsmax to TL -Ramp-up Rate 3℃/second max. Time maintained above: - Temperature(TL) 217℃ 60~150 seconds -Time(TL) Peak temperature(Tp) 245℃+0/-5℃ Time within 5℃of actual Peak temperature (tp) 6 seconds max. Ramp-down Rate 6℃/second max. 8 minutes max. Time 25℃ to Peak Temperature OLE WOLFF ELEKTRONIK A/S Roedengvej 25 DK-4180 Soroe Denmark OLEWOLFF ELECTRONICS INC. 4340 Cross Street Downers Grove, Chicago IL 60515, USA OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLEWOLFF ELEKTRONIK Yliopistonkatu 26A, P.O. Box 257, FIN-40101 Jyväskylä, FINLAND OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +45 57833830 FAX: +45 57820019 TEL : +847 962 4169 FAX : +630 852 2520 TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156 DATE PAGE 17 Sep, 15 5/7 SPECIFICATIONS OLE WOLFF INTERNATIONAL WWW.OWOLFF.COM DK PART NUMBER: OWPB-909018S-40-03 7. TEST METHOD (Figure 2) 8. DIMENSIONS (Figure 3) Unit: mm Tolerance: ±0.5mm Except Specified OLE WOLFF ELEKTRONIK A/S Roedengvej 25 DK-4180 Soroe Denmark OLEWOLFF ELECTRONICS INC. 4340 Cross Street Downers Grove, Chicago IL 60515, USA OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLEWOLFF ELEKTRONIK Yliopistonkatu 26A, P.O. Box 257, FIN-40101 Jyväskylä, FINLAND OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +45 57833830 FAX: +45 57820019 TEL : +847 962 4169 FAX : +630 852 2520 TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156 DATE PAGE 17 Sep, 15 6/7 SPECIFICATIONS OLE WOLFF INTERNATIONAL WWW.OWOLFF.COM DK PART NUMBER: OWPB-909018S-40-03 9. PACKING (Figure 4 & 5) OLE WOLFF ELEKTRONIK A/S Roedengvej 25 DK-4180 Soroe Denmark OLEWOLFF ELECTRONICS INC. 4340 Cross Street Downers Grove, Chicago IL 60515, USA OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLEWOLFF ELEKTRONIK Yliopistonkatu 26A, P.O. Box 257, FIN-40101 Jyväskylä, FINLAND OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +45 57833830 FAX: +45 57820019 TEL : +847 962 4169 FAX : +630 852 2520 TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156 DATE PAGE 17 Sep, 15 7/7 SPECIFICATIONS OLE WOLFF INTERNATIONAL WWW.OWOLFF.COM DK PART NUMBER: OWPB-909018S-40-03 OLE WOLFF ELEKTRONIK A/S Roedengvej 25 DK-4180 Soroe Denmark OLEWOLFF ELECTRONICS INC. 4340 Cross Street Downers Grove, Chicago IL 60515, USA OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLEWOLFF ELEKTRONIK Yliopistonkatu 26A, P.O. Box 257, FIN-40101 Jyväskylä, FINLAND OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. OLE WOLFF LTD. Unit 7A08, Block 2, Elite Building, Nanshan Avenue, Nanshan District, Shenzhen, PRC. TEL: +45 57833830 FAX: +45 57820019 TEL : +847 962 4169 FAX : +630 852 2520 TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 TEL: +852 2424 3274 FAX: +852 2424 2219 TEL: +86 755 82612542 TEL: +86 755 26406156
OWPB-909018S-40-03 价格&库存
很抱歉,暂时无法提供与“OWPB-909018S-40-03”相匹配的价格&库存,您可以联系我们找货
